my LSJ build :D
Old Apr 20, 2012 | 02:13 PM
  #51
conerboner's Avatar
in like flinn
Old Apr 20, 2012 | 02:35 PM
  #52
Joemaster70's Avatar
Originally Posted by rcorona8
Im doing a simililar setup. And im shooting for 320whp.
Zzp stg 2 blower cams
Supertech valve springs
Balance shaft delete kit
Ported head
Ported m62
Meth
7800 rev
Stock block
i figured 320 on 93 octane and if i have enough fuel for e-85 ill try for 340-350
if all fails ill just hop on the nitrous train
Old Apr 20, 2012 | 02:57 PM
  #53
Bluelightning's Avatar
Got Bewst?
Originally Posted by zrated89
im still tempted to go kick of an 11 on stock internals first to have that record
You 100% no questions asked need to do this!!! The hype of it from the beginning needs to become a reality. If your time was any higher I would say screw it but you're so damn close!
Old Apr 20, 2012 | 03:07 PM
  #54
zrated89's Avatar
It's in the bag man never had a clean pass even with the 12.1 was having horrible spark blowout up top. That has since been corrected
Old Apr 20, 2012 | 03:14 PM
  #55
jbenso4's Avatar
sub'd good luck
Old Apr 20, 2012 | 03:23 PM
  #56
Got Bewst?
Lol make it official
Old Apr 20, 2012 | 04:18 PM
  #57
what would put down more power cams,pistons,port and polish head m62 with valve springs or a tvs?
Old Apr 20, 2012 | 05:32 PM
  #58
zrated89's Avatar
Tvs man get rid of the heaton first then do engine mods
Old Apr 20, 2012 | 06:12 PM
  #59
rcorona8's Avatar
for me it was easier to spend couple hundreds at a time then to pull $2k for the TVS. so that is why im doing engine mods first then im going to push for the TVS.
Old Apr 20, 2012 | 06:35 PM
  #60
only reason im building the motor is cause i blew it lol so.
plus i can always purchase a tvs later. Mind as well build the block while its out
Old Apr 21, 2012 | 01:15 AM
  #61
RooTBeeR's Avatar
Screw the TVS
if you want high HP from an sc go twin screw
1200 AX Supercharger | Lysholm
Old Apr 21, 2012 | 03:13 AM
  #62
Originally Posted by RooTBeeR
Screw the TVS
whats needed to make it a kit?
What do you gotta customize to fit it?
Old Apr 21, 2012 | 10:45 AM
  #63
BlackMagic's Avatar
Screw the TVS
I like the way you think
Old Apr 21, 2012 | 10:48 AM
  #64
BlackMagic's Avatar
An adapter plate, a custom sc inlet and a different bypass setup.
Old Apr 21, 2012 | 12:16 PM
  #65
zrated89's Avatar
cams and balance shafts will ship out today . gotta give a shout out to shabodah for the good price thanks man !
Old Apr 21, 2012 | 12:39 PM
  #66
zrated89's Avatar
Old Apr 21, 2012 | 09:01 PM
  #67
RooTBeeR's Avatar
Looks that same as on FB
oooo, pretty
Old Apr 21, 2012 | 10:43 PM
  #68
zrated89's Avatar
lol shut up youre one of the privileged ones i actually had to post them to fb first to get the url image code to post here since i was on my phone at work lol
Old Apr 21, 2012 | 11:50 PM
  #69
wat lifters u going with?
Old Apr 22, 2012 | 12:13 AM
  #70
zrated89's Avatar
solid lifters from bates. to my knowledge thats the only place to get them from. my buddy danew has some he never used new still ill probably pick up. just have to machine them to spec
Old Apr 23, 2012 | 01:52 AM
  #71
InfraRedline's Avatar
oooo, pretty
True dat
Old Apr 23, 2012 | 08:24 AM
  #72
zrated89's Avatar
you just got on my fb
Old Apr 23, 2012 | 03:00 PM
  #73
You just got on MY fb
Im an artard
Old Apr 23, 2012 | 03:34 PM
  #74
willie_panic's Avatar
Hope this doesn't make me look likea dumb@$$ but how are you going to change the pistons without pulling the block? Are you planning on remvoing the oil pan and doing everything under the car?
Old Apr 23, 2012 | 10:14 PM
  #75
RooTBeeR's Avatar
Yes.
