my LSJ build :D
Here is one of the earlier maps that i was working on to get the ethanol and etc to work good. (we werent done yet because he had to leave and etc)
Uploaded with ImageShack.us
Last edited by Chevycobaltss3; May 8, 2012 at 02:18 PM. Reason: Automerged Doublepost
yea man i have a good friend that is an awesome machinst we're going to figure out a way. joe is doing some calculations between the stock cam base circles and the gmrs to come up with a shim for the oe lash adjusters
They've already been tried and failed horribly. There was no good way to secure them properly from the oil pressure. The BLE lash adjusters seem to be a much better idea:
BLE Solid Lifter Kit Chevy Cobalt 05-UP 2.2L ECOTEC
No, if your machinist were to disassemble the factory lash adjuster, then weld on some material on the bottom half or fab a new bottom half in a different height, that would probably work out well. The other thought, was finding larger diameter follower bearings to make up for the smaller base circle. I looked extensively for such bearings without luck, but that doesn't mean they are not out there or that they couldn't be fabricated as well.
I wish i woukd have known about the ble adj before I bought bates solids that have to be machined for lash. If we can't get the oem ones to work maybe ill opt for those so no machining will be needed and will have an adjustment for lash further down the road
zzp valve springs ordered, arp head stud kit ordered. New valve seals, head gasket, rod bearings, rod bolts, sc gasket, exh gasket, and new revised timing chain tensioner all ordered. Last of the parts i had to buy to complete build
will be ordering the ATI super balancer as well when wallet recovers lol
