OFFICIAL Blown 4-banger build updates!
Old Sep 26, 2008 | 04:55 PM
  #1851
Area47's Avatar
Rent me! per hour
the 4274 is a wicked turbo. 740 awhp on a friends evo at 41 psi. with plenty of room to play still. this weekend we are putting it on 50psi and going for 850 to the tires. no timing added. only running 12 degree's. 11.3 afr. the egt's average 1200 at 170 mph.
i have some fucked up friends
you want power. you have to go big or go home.
also, brake boosting. you're going to learn the hard way about it. you will have to do it from a roll. a stage 2 car will jump out hard on you, while you sit there waiting.
Old Sep 26, 2008 | 05:03 PM
  #1852
DIPSET's Avatar
wow cameron thinking about a turbo?that must be good weed you smoked
Old Sep 26, 2008 | 06:07 PM
  #1853
06blackg85ss's Avatar
lol true, but it makes it more fun when you blow past them like their not even moving
Old Sep 26, 2008 | 06:23 PM
  #1854
BlackSS/SC's Avatar
Stock head and cams yes...
Paul, I thought you hit full boost at 5000 rpm by looking at your dyno graphs. Why am I only getting it at 4000rpm on a much smaller turbo?
Old Sep 26, 2008 | 06:24 PM
  #1855
4300 the wastegate is open, but i make peak TQ at 5200 rpm. Just because it's at full spool doesn't mean your making full power there.
as for your setup, depends on you hot side A/R, journal or ball bearing, and compressor specs
Old Sep 26, 2008 | 06:32 PM
  #1856
BlackSS/SC's Avatar
Yes you have ball bearings & I just have 360* journal. Forgot about that one.
Old Sep 26, 2008 | 06:46 PM
  #1857
well there ya go lol.
Old Sep 27, 2008 | 02:57 AM
  #1858
Blown 4-banger's Avatar
Well then I will loose a lot of races then won't I? If I decide on a turbo, I'm deciding on dealing with its gayness as well. I will never brake boost, end of story. I simply will not do that. I'll spray nitrous based on MAP pressure, once it hits a certain boost level it will stop spray, but I'll never brake boost.
Old Sep 27, 2008 | 10:37 AM
  #1859
lsjwannabe's Avatar
just like you'll never go turbo
Old Sep 27, 2008 | 10:45 AM
  #1860
06black's Avatar
if you wanna talk turbo, you know who to contact.
told you so.
Old Sep 27, 2008 | 10:46 AM
  #1861
Herndon_High_SS's Avatar
hahaha. I remember when cam was saying he would never consider going turbo too.
Old Sep 27, 2008 | 01:39 PM
  #1862
**** Yo COUCH!!! I would go TVS, but looking at the cost of thing, I might as well spend the money and get a big ass turbo and my **** loads of power, than get a TVS and make not that compared to the turbo. Trust me, it KILLS me to do this to my poor car.
told you so.
Congrats, your the first ******* to actually say it.
Old Sep 27, 2008 | 01:43 PM
  #1863
DIPSET's Avatar
just do it already dam your sc is restricting your motor
Old Sep 27, 2008 | 01:50 PM
  #1864
Well if anything its cause of the tiny like intake I have.
  #1865
lsjwannabe's Avatar
lol, you are right though.
Old Sep 27, 2008 | 02:11 PM
  #1866
Its sad too. **** IT!!!! 2.2L KB!!!!
Old Sep 27, 2008 | 02:14 PM
  #1867
lsjwannabe's Avatar
gl with anything larger than a tvs
Old Sep 27, 2008 | 02:17 PM
  #1868
Custom intake + 2.2L KB = PWN3D TURBO!!!!
I hate turbos, its gonna be like have acid as blood driving me car
Old Sep 27, 2008 | 11:36 PM
  #1869
SSnAZ's Avatar
You should just take the SC off and cut a hole in your hood for ram air. That should help your flow!
Old Sep 27, 2008 | 11:52 PM
  #1870
Raven SS's Avatar
wow, i thought u were gonna make 375whp on a m62?
Old Sep 28, 2008 | 05:30 AM
  #1871
Perhaps, but it wouldn't be making use of the head/cams setup.
17 psi @ 5300 + 14 psi @ 8200 = SRT-4 territory
Old Sep 28, 2008 | 09:15 AM
  #1872
06black's Avatar
WOOOOOOOOOOOOOOO
do i get a prize?
i sure hope so!
none the less, and on a far more serious note.
I'd be more then happy to talk turbo with you, we can get something just rite for ya.
Old Sep 28, 2008 | 10:00 AM
  #1873
listen to this man right here...... he has the knowledge.
and damn you cam after all the **** taking I had to put up with from you, you finally are making the right decision
Old Sep 28, 2008 | 05:09 PM
  #1874
WOOOOOOOOOOOOOOO
do i get a prize?
i sure hope so!
Well ****!!! That means you can get me a turbo that gets full boost at 2500 rpm, holds peak boost to 8200 rpm and makes 400 whp on pump gas (91 shitane)!?!? Count me in!!!
Old Sep 28, 2008 | 05:21 PM
  #1875
find an s.c that'll do that on our cars lol.
once you get to certain power levels there's always tradeoff's to be made my man.
gt3071 full boost @3500 rpm, makes boost at idle (seriously) will pull pretty hard and will make your 400whp on a relatively low boost level (@22-23psi on a stock motor)
Last edited by 06blackg85ss; Sep 28, 2008 at 05:21 PM. Reason: Automerged Doublepost
