OFFICIAL Blown 4-banger build updates!
Old Sep 23, 2008 | 07:48 PM
  #1801
Area47's Avatar
Rent me! per hour
there is not special with mine really
Old Sep 23, 2008 | 07:50 PM
  #1802
SSdan's Avatar
Tune the bitch already.
Old Sep 23, 2008 | 08:00 PM
  #1803
Blown 4-banger's Avatar
Workin on it foo!
Oh yeah! I have no idea why it was running 24 psi the other night, cause today it wasn't even hitting 17 psi. So yeah, I'm at a loss there.
Last edited by Blown 4-banger; Sep 23, 2008 at 08:00 PM. Reason: Automerged Doublepost
Old Sep 23, 2008 | 08:20 PM
  #1804
SSdan's Avatar
Fucked up gauge. That's odd.
Old Sep 23, 2008 | 11:20 PM
  #1805
No it wasn't the gauge, cause that night it was reading the same vacuum and part throttle boost as it was today. Just at WOT it was different.
Anywho, I didn't have time to get the good camera out so I just used my phone. 8200 rpm in first gear, then it was pulling so hard in second it just smashed the 7200 limiter in 2nd
http://s64.photobucket.com/albums/h1...0923081722.flv
Old Sep 23, 2008 | 11:34 PM
  #1806
SSdan's Avatar
Yuck. You need a new exhaust ASAP!
BTW, why the different rev limiters for the different gears?
Old Sep 23, 2008 | 11:36 PM
  #1807
06blackbalt's Avatar
haha he has an exhuast
Old Sep 23, 2008 | 11:39 PM
  #1808
SSnAZ's Avatar
i thought he has three mufflers lol
Old Sep 24, 2008 | 12:51 AM
  #1809
My exhaust is a Pacesetter header, and 3" catless mandrel bent, with TWO magnaflow resonators, and one large magnaflow muffler. There is literally no more room in the piping to fit more mufflers
Seriously, its a fully build motor, with crazy ported head, and radical cams. It moves a lot of air.
Lots of air = Lots of sound :shrug:
Also, I just wanted to hit 8200 rpm, its still too hot outside to run through 8000 rpm in 2nd gear or higher. Its still over 100 degrees outside, and my IAT1 is already over 110 degrees.
Old Sep 24, 2008 | 12:54 AM
  #1810
camarokiller's Avatar
Have you started tuning yet?
Old Sep 24, 2008 | 12:57 AM
  #1811
Not really. I tuned a friends cobalt today instead of mine.
  #1812
When you get some money chop off that magnaflow and weld one of these on and run a dual cutout setup(one on the DP and one after the second resonator) http://store.summitracing.com/partde...5&autoview=sku
I had the setup that you do now before i switched to the above and it drove me nuts
Old Sep 24, 2008 | 01:02 AM
  #1813
I'll pass. I don't mind the exhaust at all. It sounds pretty good considering its a full race exhaust.
http://videos.streetfire.net/video/C...bys_104050.htm
Thats the same exhaust, only considerably quieter and 1200 rpm less... DAMN!!!! Imagine the blower whine at 8200!?!?!
Old Sep 24, 2008 | 01:06 AM
  #1814
I remember the vid. I made my exhaust the same as yours because i liked how it sounded. It was okay for a month or so, but driving on the long trips that i do it got to be to much. Thats when i put my loud on a switch
Old Sep 24, 2008 | 01:30 PM
  #1815
Alright so last night I took it out for some more scanning. Found out 2 things.
#1 That M62 ******* sucks ass. Even with the 2.6" on there, it makes peak boost of 17 psi at around 5300 rpm, then it starts dropping, and by 8200 rpm its only at 14 psi. What a piece of **** But who didn't know that already. I knew it was shitty, but I didn't know my motor would so heavy over power the blower. Before, it would make peak boost at redline, I figured it would at least hold boost til redline, or at least 7000 rpm!
#2 My clutch is now fucked up. I have no idea what happened, or even WHEN it happened, but my clutch is pretty fucked. When the clutch is slipping (leaving in 1st gear, shifting into second), it sounds like your scraping a rake on the side of the car. This horrible grinding sound, but as soon at the clutch is either fully engaged, or fully disengaged, it makes no noise, and it still works, I shift with no problem, I don't understand it!!!
Old Sep 24, 2008 | 01:37 PM
  #1816
Rangerondubz's Avatar
Well, that blows
Old Sep 24, 2008 | 01:44 PM
  #1817
J.CobaltLT's Avatar
fuxxored sorry
  #1818
Originally Posted by Rangerondubz
Well, that blows
No! The opposite actually! If it blew, then it would hold boost to redline!!!
Old Sep 24, 2008 | 01:49 PM
  #1819
lsjwannabe's Avatar
So is the car going now or are you going to try to keep it?
Old Sep 24, 2008 | 02:17 PM
  #1820
OniMirage's Avatar
so wtf is the car borked again sumabitch that sucks so what say you cam this time next year it will be ready
Old Sep 24, 2008 | 02:30 PM
  #1821
I am just gonna deal with whatever fucked up. The motor is still fine, runs great still, just the damn clutch. **** if I can't figure out whats wrong, I'll just drive it as it, until the clutch lights on fire or something. I'm almost at the weird twitchy smiling point of anger, ya know when people do really stupid stuff...
Old Sep 24, 2008 | 04:28 PM
  #1822
OniMirage's Avatar
just don't **** it up worse by trying to force something to happen or you will be down even longer
Old Sep 24, 2008 | 04:42 PM
  #1823
Herndon_High_SS's Avatar
I think if he breaks it again he will just call it quits.
Old Sep 24, 2008 | 04:44 PM
  #1824
Its most likely the throwout bearing. The clutch still grips just fine, and fully disengages. It just makes a nasty grinding sound when I let the clutch out in first gear. It still shifts fine and everything.
Old Sep 24, 2008 | 09:18 PM
  #1825
BLAZIN07SS's Avatar
I'm too JDM for you
what clutch do you have? btw there was a local car down here with a bad throwout bearing that made a grinding sound.
