V-LEDs V3 Triton Switchbacks pre-ordered!
got my v3 tritons. holy brightness!
now how does the white wite to 50% dimming when lowbeam is on work. trying to hook it up.
tried spliging to the yellow wire on the driver size harness (the car harness) didnt work.
i have retros btw
i have retros btw
http://sphotos-a.xx.fbcdn.net/hphoto...05753131_n.jpg
And full install instructions. https://www.cobaltss.net/forums/how-...nstall-291137/
I should get that updated for the new version, though I think it's self explanatory over the prior one's
yeah thats to wire for gen 3 headlights like you have.
and yeah dude the new ones are so easy to hook up.
i just NEEED to get the 50% dimming hooked up there way too bright.
someone says that the yellow wire on the stock harness (connected from the car) on the driver side is low beam. and the tan and white wire on passanger side is lowbeam.
but i do not know.
but i do not know.
it is not at the harness you refer to, its where I showed you in the pic u sent....top right corner is the blue connectors for the headlights. Tap orange from there.
Its orange (low beam), Pink is high beam, black is ground. There is only those three off the blue connector.
Tap into orange, if the quick splice are not working then move the plastic cover to the side, solder the connection, use heat shrink and bam its a done deal, take mayb 30mins .
then use that. turn on the high beam or low beam or whatever you are testing for... then with the ground touching a ground on the car see which wires have voltage. if you are looking for high/low you will probably see voltage on parking as well so once u have your 2 wires turn on only the parking light and out of the 2 that had voltage earlier the one without voltage now will be your high/low
testing takes 5 minutes at the most if its raining and you only have 1 leg and 1 arm. Why would you even consider going off what someone says instead of testing and potentially breaking something in your 150.00 LED's???
yeah ill have to go about doing that.
and its the cobalt community tons of people have made how to's on different things few guys instslled these so i figured id simply just ask. i dont think anyone would tell me the wrong wire color causing me to break anything
Its; orange low beam, Pink is high beam, black is ground. There is only those three off the blue connector.
Tap into orange,
Or if your harness looks like below.....then it will be either purple or orange off the BLUE CONNECTOR, I don't have this harness so I can not say which is which however this is where the multimeter comes in handy, switch to 12vdc and ground the ground, then turn on low beam and stick the positive end of the multi meter into the plug for orange or purple, one of them will give u a 12V signal with the low beams on. That's low beam. Start at the blue connector.
Tap into orange,
rubber washer wouldnt do anything. its the physical sockett.
plug the socket adapter in and its like loose.
wouldnt i have to mess with thr prongs to the socket? jake told me to put some tape around it
