V-LEDs V3 Triton Switchbacks pre-ordered!
Old May 30, 2013 | 05:26 PM
  #226
Cobalt08LS's Avatar
got my v3 tritons. holy brightness!
now how does the white wite to 50% dimming when lowbeam is on work. trying to hook it up.
tried spliging to the yellow wire on the driver size harness (the car harness) didnt work.
i have retros btw
Old May 30, 2013 | 07:54 PM
  #227
z062007vette's Avatar
i have retros btw
Depending on how you have your retros setup, I just snipped the wire in with the positive red wire to the HID light. I wrote up an install when the were the "bricks". Here is a pic of how I did mine:
http://sphotos-a.xx.fbcdn.net/hphoto...05753131_n.jpg
And full install instructions. https://www.cobaltss.net/forums/how-...nstall-291137/
I should get that updated for the new version, though I think it's self explanatory over the prior one's
Old May 30, 2013 | 08:40 PM
  #228
Cobalt08LS's Avatar
yeah thats to wire for gen 3 headlights like you have.
and yeah dude the new ones are so easy to hook up.
i just NEEED to get the 50% dimming hooked up there way too bright.
someone says that the yellow wire on the stock harness (connected from the car) on the driver side is low beam. and the tan and white wire on passanger side is lowbeam.
but i do not know.
Old May 31, 2013 | 06:11 AM
  #229
Cobalt08LS's Avatar
bumpp can anyone help me?.
Old Jun 2, 2013 | 02:19 AM
  #230
serega12's Avatar
I'm pretty sure for SS it's orange for high beam.
Old Jun 3, 2013 | 11:18 AM
  #231
victoryredturbalt's Avatar
pink is high beam, orange is low, brown is park lights, black is ground.
Old Jun 4, 2013 | 08:04 AM
  #232
Cobalt08LS's Avatar
my harness has orange purple blue and black
Old Jun 4, 2013 | 12:14 PM
  #233
it is not at the harness you refer to, its where I showed you in the pic u sent....top right corner is the blue connectors for the headlights. Tap orange from there.
Its orange (low beam), Pink is high beam, black is ground. There is only those three off the blue connector.
Tap into orange, if the quick splice are not working then move the plastic cover to the side, solder the connection, use heat shrink and bam its a done deal, take mayb 30mins .
Old Jun 4, 2013 | 05:01 PM
  #234
Cobalt08LS's Avatar
my harness for my retros isnt a oem one its an aftermarket oem spec one. but ill use the orange wire as im sure its the same
Old Jun 4, 2013 | 05:53 PM
  #235
EmperorJJ1's Avatar
why dont you just buy a 1.29 multimeter from harbor fright and test it?
Old Jun 4, 2013 | 06:26 PM
  #236
Cobalt08LS's Avatar
bc my buddy has one i can use fo free
Old Jun 5, 2013 | 02:56 AM
  #237
EmperorJJ1's Avatar
then use that. turn on the high beam or low beam or whatever you are testing for... then with the ground touching a ground on the car see which wires have voltage. if you are looking for high/low you will probably see voltage on parking as well so once u have your 2 wires turn on only the parking light and out of the 2 that had voltage earlier the one without voltage now will be your high/low
testing takes 5 minutes at the most if its raining and you only have 1 leg and 1 arm. Why would you even consider going off what someone says instead of testing and potentially breaking something in your 150.00 LED's???
Old Jun 5, 2013 | 07:04 AM
  #238
Cobalt08LS's Avatar
yeah ill have to go about doing that.
and its the cobalt community tons of people have made how to's on different things few guys instslled these so i figured id simply just ask. i dont think anyone would tell me the wrong wire color causing me to break anything
Old Jun 5, 2013 | 02:19 PM
  #239
EmperorJJ1's Avatar
right but you said you have an aftermarket harness... so high probability your colors arent the same as everyone else
Old Jun 5, 2013 | 02:33 PM
  #240
Its; orange low beam, Pink is high beam, black is ground. There is only those three off the blue connector.
Tap into orange,
Or if your harness looks like below.....then it will be either purple or orange off the BLUE CONNECTOR, I don't have this harness so I can not say which is which however this is where the multimeter comes in handy, switch to 12vdc and ground the ground, then turn on low beam and stick the positive end of the multi meter into the plug for orange or purple, one of them will give u a 12V signal with the low beams on. That's low beam. Start at the blue connector.
Old Jun 6, 2013 | 12:43 PM
  #241
Cobalt08LS's Avatar
2nd one is EXACTLY what my harness looks like.
Old Jun 6, 2013 | 12:54 PM
  #242
Old Jun 6, 2013 | 04:10 PM
  #243
Cobalt08LS's Avatar
alright cool, ill have to get ahold of one and do that
thanks man
Old Jun 9, 2013 | 01:44 AM
  #244
Cobalt08LS's Avatar
anyone have problems with the adapter fitting tight in the turn signal socket? my passanger one is pretty damn loose.
what can i do to make it a tight fit?
Old Jun 9, 2013 | 03:00 AM
  #245
serega12's Avatar
put a bigger rubber washer in there...
Old Jun 9, 2013 | 12:23 PM
  #246
Cobalt08LS's Avatar
rubber washer wouldnt do anything. its the physical sockett.
plug the socket adapter in and its like loose.
wouldnt i have to mess with thr prongs to the socket? jake told me to put some tape around it
Old Jun 9, 2013 | 06:38 PM
  #247
serega12's Avatar
I put tape around most of them regardless. Good practice. Just don't over do it, or you will have a bad time getting it off later.
Old Jun 9, 2013 | 10:28 PM
  #248
Cobalt08LS's Avatar
yea its fine how it is now. hasnt fallen out yet so ill see how long it lasts
Old Feb 16, 2014 | 11:32 PM
  #249
EmperorJJ1's Avatar
just ordered a set with the valentine's day discount. didnt get switchback just the reg amber though... it was tough bc i wasnt sure but **** it the amber should be good
Old Feb 23, 2014 | 12:22 AM
  #250
EmperorJJ1's Avatar
