Calgary - random talk thread
i will need this at the very least these lnf's are definatly no push overs..... you see guys the secret is very simple..... never under estimate the compition...... i promise you i have never thought for one second it was going to be easy..... but in the same breath i know its possible..... thats your mistake, you believe it can not be done....
dude i raped a jet car last time i was out on the salt flats.......
i think i happen to know your kryptonite...... lol..... whats funny is they are all lsj's.... you see there will be a lsjt very soon who would absolutely embaress 99% of lnf's, then there is a lsjtvs who can spank ya.... but wait dont tell me that this asshat lsjm62 is gunning for ya too.... boy i must admit that would be kinda embarressing if he pulled it off..... like really a m62, what a clown, dont he know that the ss in ss/sc stands for super slow? lol hey nathaniel settle down i had my fun..... lol just enjoy the techy talk that comes from us upgrading.....
we do work on 4 injectors while the lnfs need a 5th. and i kinda chuckled when psyco mentioned that while m62s can swap pulleys around. the lnfs have turbo options like the "ZFR, EFR, S262, KO4+.... e49 or e85 blends, dual fuel rails.... " lol so the lnf's have to get rid of the factory turbo to be faster than an m62. and the zfr is an efr
lol. don't go with a s262. and the ko4+ is crap. and we have fuel options as well.
and you forgot the most important factor 4.05 > 3.82. AND our power doesn't fall off after 6k.
Game on bishes. lsj>lnf
-new injectors
-smaller pulley
-new serp belt
-larger serp belt tensioner
-new tune for injectors and pulley set up
-then u need a wheel hop kit just to harness the extra power
-step colder plugs
and prob some meth for good measure
I dont know if a done up lsj m62 small pulley will beat a doneup k04 lnf i say its close, a racers race one might say.
ZFR(EFR) spools fast like the k04 but is larger and runs longer would compete with a TVS. The thing is that in order to reach these huge builds both have their own weak areas that need to be conquered. As long as its a balt killin everything it meets im happy (lsj or lnf Boosted is boosted MUCH LOVE)
Lnf comes with esc, traction, launch control, no wheel hop, stiffer chasis, better engine mounts etc etc (the list goes on and on)
Im terribly unfamaliar with the 5th injector set up however i do know there is a cam with an upgraded fuel lobe to strike faster. For what the balt comes with and what a simply tune will unleash is gravy, thats why i love my lnf
Personally my balt is a dd/weekend cruiser. I need fuel econmy mixed with kill when i need it.
Its drivin year round, and thats when i use the esc, traction control and such as its very handy.
this is done with just a tune.......lnf ftw
^true that
Last edited by victoryredturbalt; Feb 10, 2013 at 10:00 PM. Reason: Automerged Doublepost
except after we do all that stuff to the lsj we still haven't even come close to touching the price of even a stock lnf lol
let me go buy an lsj, lay down 440whp. and still be thousands short of what a bone stock lnf costs.
friggin money pit
then the high fuel
but we all love tha BOOOOOOOSSSSSSST
3" intake. long tube header. 2.5" exhaust. 80s. e85 or racegas. 10gph pre blower 90% meth if on pump gas. (optional: stage1-2 cams and a ported head). griffin. single pass. option b. 315+ all day long. especially with the cams and head. cams will also allow you to carry that power out a lot further. pump gas will be tough to hit that number though. past a 2.8 there won't be much gain in hp just a noticeable gain in torque
im sorry but what is a cobalt ss/gt?
Last edited by victoryredturbalt; Feb 10, 2013 at 10:03 PM. Reason: Automerged Doublepost
and look at the drag times thread too. look at what it's taking you guys to run 12s and 13s. i went 13.7 with a pulley, injectors, and tune. no other mods. 12.75 on a 2.85" setup with maybe 260-270whp.. the lsj is not far off at all from the lnf. not enough to say one is better than the other. except for the fact that the lnf is newer and has nicer seats.. haha
Hey guys, here's my random question. I'm sure this question has been asked plenty of times before here it goes. I'm looking into upgrading my transmission because the stock one I have now on my LNF is grinding on me and not going into 2nd. I want a upgrade and possible even upgrade my clutch too... How much will it cost for upgrade with labor? Need a ball park estimate. Any help is appreciated so thank you in advance.
https://www.cobaltss.net/forums/08-1...=gear+grinding
"Heres how to fix it.
Remove the cup holder.
put the car in first gear.
reach down and release the lock on the cable on the right hand side. (don't release the one on the left)
gently push the shifter forward until it measures about 4 3/4 to 4 7/8 between the front of the shifter knob and the dash.
Hold it there with one hand and reach down and relock the cable adjuster. (this moves the shifter forward in the gate)
This moves the shifter forward in its gate and gives more throw when shifting into second before the actual shifter mechanism bottoms out at the back of the shifter gate.
If that does not fix it then yes you probably have a syncro problem but 99 percent of the time its a shifter adjustment issue and not a syncro issue.
I will be passing this on to the appropriate engineers.
I am a GM Engineer and my opinions are my own. "
honest nathaniel i look at the dyno thread and just a trifecta tune, dp, muffler delete you will get 300ish on the avg.... a 2.8 will hit 270 without meth.... 300+ with..... a 2.6 will hit north of 285 without meth and easy 320+ with.... even if you ran meth, i figure they would be on par with 2.6 on meth..... yes your correct we need to spend a lil bit to get there..... but when your in a position im in where i have the support mods, it becomes very cheap to make more power.... the biggest thing you dont have that i do is the power band...... the biggest thing you have i dont is a slight edge in torque..... my money is on the sc power band....... besides that eddie has blessed this car and it will always be the nasty freak you fear.....
btw SS GT = SS GIANT TURBO
also (have not looked at the drag postings as of this posting)
i believe stock lnf is low 14's
a simple tune will take it high 13's
beyond that it starts taking money and parts.......
personally i enjoy a spirited bendy drive as apposed to straight super fast.
for rental cars we can get moving alright hahaha
they do tend to cup a person very nicly!
the other beef would be the passenger seat, after its folde and slid forward, when u put it back it has a 90 degree angle that no one can use to sit, its rediculous haha
i know
i know
Last edited by victoryredturbalt; Feb 10, 2013 at 10:29 PM. Reason: Automerged Doublepost
dude you know me better then that...... i am the biggest joker around..... but i speak alot of truth even when i bullshyt..... the real truth is like mark said, the 2 are not that far apart..... just because you never come across a fast m62 doesnt mean you wont..... seems to me there is one closer then you think.....
