Drag Racing Kindle Racing and Dalcorp Racing
OFFICIAL: Difference between SLICKS and Drag Radials
Old Aug 29, 2011 | 02:50 AM
  #101
chrisjaldin's Avatar
so you're wanting an 18" track tire??? i thought you meant you wanted to buy your first set as in you already had 16 or 15 wheels
I wanna buy 16 or 15 rims, along with cheater slicks. I want to know what cheater slicks were recommend on the first because link only goes the summtinracing.com
Old Aug 29, 2011 | 02:53 AM
  #102
are you going road racing or drag racing?
I'm drag racing on Tarmac.
Old Aug 29, 2011 | 03:00 AM
  #103
EXsoccer1921's Avatar
what do you mean tarmac... most people (british) refer to any racing surface as tarmac. either way the only difference in tires you'll see will be between trying to road race with a drag slick, and trying to make a pass down the track on a road slick. every drag strip is going to be sprayed and prepped(even if terribly) so its not gonna be like driving on straight cement or asphault. the tires themselves though do have variations in hard or soft compound, being a fwd i would try and stay on the softer side
Old Aug 30, 2011 | 06:21 PM
  #104
I use tarmac as asphalt. Water is use to prepped the surface for the burnout?
Old Aug 30, 2011 | 07:39 PM
  #105
Leafydialupking's Avatar
Yes, but you should only drive through the water if you have slicks, not radials with tread.
Old Sep 14, 2011 | 08:29 PM
  #106
Ok, I want the cheater slicks 16 from summit racing but link from the 1st post doesn't work, it just takes you to summitracing.com. What are the sizes and brand, including the rims so I look for it?
Old Sep 14, 2011 | 10:13 PM
  #107
que?
Old Sep 14, 2011 | 10:30 PM
  #108
Which is the proper sizing on cheaters slicks and rims?
Old Sep 18, 2011 | 03:02 AM
  #109
D-mac's Avatar
What you really want to do is grind your calipers a bit and run a 15 Inch M&H Racemaster Full Slick
Old Sep 28, 2011 | 12:23 PM
  #110
How much is a "bit"? It wouldn't affect the brake performance? Do you have link to the full slick tire, there are a lot of options out there and what is drag radial instead it is not and slicks are also slicks depending on what compound is made of.
Old Mar 28, 2013 | 11:50 AM
  #111
ok so i'm thinking about getting a cheap set of like hhr 16" rims, i think they are 7" wide. can find them for like 50 bucks on craigslist so idgaf about looks
the important part i guess is size of the slick. anyone have good suggestions? wanna run like an mt sick probly. just need to know a good size, like 24.5" tall but idk how wide
thanks!
Old Mar 28, 2013 | 11:58 AM
  #112
you're not going to find a 24.5" for a 16" wheel.
grind the calipers a hair and run 15"s. then get a real slick.
Old Mar 28, 2013 | 12:14 PM
  #113
i'm not doing that i'm not trying to break records or anything... just wanna run a decent times and hook up for what a 16" rim can do
Old Mar 28, 2013 | 12:45 PM
  #114
well then you can go with the 225/50/16 hoosier drag radial or a 245/50/16 nitto 555r. i wouldn't go with anything else. 16"s and 17"s really only have tires to offer that are too tall for our cars. we don't need anything bigger than a 24.5". and the tall tires make the gearing way too long.
Old Mar 28, 2013 | 01:15 PM
  #115
hoosier it is! thanks a lot man!
Old Mar 28, 2013 | 01:16 PM
  #116
Do you know if base model cobalt/hhr/g5 wheels are 7" wide?
Old Mar 28, 2013 | 01:23 PM
  #117
they're probably 6.5" or 7". but either will work with the hoosier radials. the nittos i wouldn't go below a 7". but i think those wheels are a 7"
Old Mar 28, 2013 | 01:39 PM
  #118
ok awesome. i just found a set of (apparently) new hoosier 225/50/16's on craigslist. kinda local. so **** yeah guy will let them go for 200 done deal!
Old Mar 28, 2013 | 01:48 PM
  #119
hell there ya go.
that'll be $20 for the consulting.
Old Mar 28, 2013 | 01:51 PM
  #120
gimme ur paypal
Old Dec 16, 2013 | 07:46 PM
  #121
Kurisutofa's Avatar
Thanks. Was looking into some of these. Made the search a whole lot easier.
Old Jun 19, 2014 | 07:47 AM
  #122
hucks1987's Avatar
Has anyone thought about motorcycle slicks ? It wont be such a big sidewall, But iam sure they have then in 17in sizes. I hurd of a few SRT4 guys running them
turbochargedss2012
Sep 20, 2023 12:17 PM
biniecki
Oct 25, 2015 02:23 PM
Oct 13, 2015 09:32 PM
importkiller
Sep 30, 2015 07:18 PM
Sep 28, 2015 12:51 PM
