Automatics - B&M Shiftplus!
Old Jul 24, 2007 | 11:00 AM
  #226
Jimmys2007CobaltSS/C's Avatar
how do u install it...i have a shiftboot over my autotrany...any1 know ..hack??
Old Jul 24, 2007 | 11:05 AM
  #227
OrngBalt's Avatar
https://www.cobaltss.net/forums/show...ight=shiftplus
piece of cake... should only take you 30 minutes to an hour
Old Jul 24, 2007 | 02:47 PM
  #228
sick06cobalt's Avatar
okay so everyone who has this- should i get it.. i can get it for 37.00 and i want to know if it was worth it... I have been making a descion about it and the install doesnt look terribly hard.. and the shifting is good i hear, so was this a worth while investment?
Old Jul 24, 2007 | 02:50 PM
  #229
OrngBalt's Avatar
YES X10000!
Old Jul 24, 2007 | 05:26 PM
  #230
xCobalt05x's Avatar
yes x10000 x1000
Old Aug 1, 2007 | 02:52 AM
  #231
06jjmLT's Avatar
What's up everyone, kinda new to the site and I've been reading through this thread and i'm thinkin this is somethin that I'll definitely consider gettin but i was thinkin about the effects of using a torque damper along with it when I save up some money. Would this somewhat ease the kick since its reducin the movement of the engine?
Old Aug 1, 2007 | 03:08 AM
  #232
HunterKiller89's Avatar
why would you want to reduce the kick? thats exactly what the B&M is trying to do...shift so fast it kicks! keep in mind, you can always just turn off the B&M witha flick of a switch if you get tired of the aggressive shift...i love it though, and drive daily with it on 2
Old Aug 1, 2007 | 10:36 AM
  #233
06jjmLT's Avatar
I'm not tryin to reduce, what i meant to say had to do with some ppl had concerns about it wearin the trans out quicker or somethin i meant to say would the damper be a good investment to help out with that?
reduce the kick*
Old Aug 2, 2007 | 07:12 AM
  #234
this will most likely extend the life of your transmission. the weakest parts in a 4t45e are the clutch packs...this will speed up the shift, causing more of the force to be exerted on the actual axles opposed to the clutch packs and friction plates...also, because there is less movement on the clutch packs, there is less heat generated through friction, and heat is the #1 killer of an automatic transmission
ideally, if your trying to make your transmission last longer, get a transmission cooler and change to synthetic tranny fluid
Old Aug 2, 2007 | 07:28 AM
  #235
Blood Lucky Picnic's Avatar
this sounds pretty sweet. I'm gonna have to look into it.
Old Aug 2, 2007 | 08:33 AM
  #236
OrngBalt's Avatar
^^^Don't look... just buy... trust me you will NOT regret
Old Aug 3, 2007 | 11:36 AM
  #237
The_Blur's Avatar
I was just on the B&M site and the ShiftPlus (part # 70380) is only for RWD GM vehicles. Somebody please correct me if I'm wrong. I was going to buy one today, but then I saw that.
Old Aug 3, 2007 | 05:22 PM
  #238
Sodex
Guest
Posts: n/a
I bought mine, trust me it will work, if you ahve been reading up on parts here youll see. Also I am sure Hack wouldn't advertise a part that wouldn't work for us? Lame mine comes on Monday, I was all excited to. I wanted to test it out tonight at the races, oh well.
Old Aug 3, 2007 | 05:53 PM
  #239
automatics chirping gearshifts ftw!
Old Aug 3, 2007 | 08:33 PM
  #240
The_Blur's Avatar
I thought it was fine. I was just wondering if there was a different part number. Since there isn't, it's time to go buy mine.
Old Aug 3, 2007 | 08:43 PM
  #241
j27's Avatar
j27
what does ftw mean?
Old Aug 3, 2007 | 08:46 PM
  #242
HackAbuse's Avatar
for the win
Old Aug 11, 2007 | 01:10 PM
  #243
Evil C's Avatar
Cool
Originally Posted by joeworkstoohard
depends on your idea of fast, i have never equated acceleration and speed. truth is, 90% of the cars on the market today will easily exceed 100mph on a public street if so instructed, that's pretty damn fast.
the other side of it is, most of the cars that people tradtionally think of as fast, are not by todays standards. look at muscle cars, you'd be hard pressed to find too many that will run better than a 14.5 or 15 second 1/4 mile, nor would you be likely to find many that would do better than 110 flat out. ****, that's a 2.4SS on a good day.
the simple fact is, it's not that most cars are "too slow", it's that some are "too fast"
Yes but you can do an intake and exhaust and some wider tires and turn some muscle cars from 16 second cars to 14 seconds or lower just because the Tech was poor back in the day. I took a 350 outa a crappy 80's camero and had it pushing over 300 hp by removing the AC condensor giving it an electric fan, tossing in a Wieind stealth intake manifold, putting roller tip rocker arms, full lenght headders and a full exhaust w/ hi flow cats and a decent carb. that cost me total like 1200 bucks for another 120 poneys. well and another 900 to get that to hook up with a set of soft 8's paired to some Eagle ones. so like 2100 dollars to knock off like 2 seconds and some change is not bad @ all. That and Good lookin Muscle cars Do it in Style. Though tuneing a carb all the time depending on the season was never fun.
Old Oct 3, 2007 | 01:29 PM
  #244
DecoyGSX's Avatar
Exclamation
*bump*
Keep the interest alive, I just ordered mine from Cobaltpreformanceparts.com
Old Oct 3, 2007 | 01:49 PM
  #245
monkeiboy's Avatar
For those that didn't read the whole thread, You CAN change the settings while the engine is turned on and in Park, To make harder shifts. You still have to turn the engine off and switch the Shiftplus back to normal to reduce the line pressure back to norm. But it's a pretty cool little feature that I can change how my car shifts while sitting at a stoplight.
Old Oct 4, 2007 | 03:16 AM
  #246
DecoyGSX's Avatar
They are on back order again...
Old Oct 4, 2007 | 02:49 PM
  #247
TurboTechRacing's Avatar
We now have these in stock @ www.TurboTechRacing.com
The package says RWD GM Cars. HOWEVER B&M designed this product YEARS before the Cobalt was even a thought. Many have tested and found it has been a great mod
Old Oct 4, 2007 | 02:51 PM
  #248
i have one for sale.. so everyone knows... its in the box still never opened... pm me if intrested...
Old Oct 11, 2007 | 07:21 PM
  #249
CobaltFan06's Avatar
I read they don't come with an install guide? so how are you supposed to know where to hook it up?
Old Oct 11, 2007 | 07:57 PM
  #250
HackAbuse's Avatar
I made a how-to
