Shifter won't move side to side in nuetral
Old Apr 14, 2019 | 11:27 PM
Miltb's Avatar
Hello,
My cars sitting in a bay currently, waiting for me to do the timing chain .... Life got real busy so didn't have time for it yet.
Went to move it, just by rolling it and felt the shifter .... Shifter is stiff and will only slot up and down between 3rd and 4th .... Won't shift sideways in nuetral .... What happened?? Did someone reef on my transmission and I didn't notice? Or did letting it sit too long, stiffen up the fluid? .... It was fine before, drove fine to other than the timing rattle.
Any help is much appreciated.
Tried finding info on this, but seems it may be a unique problem ....
Old Apr 15, 2019 | 05:58 AM
63 Nova SS's Avatar
Sounds like your cables seized up.
Old Apr 15, 2019 | 02:40 PM
Miltb's Avatar
Crap,
Dunno how that happened .... It's never been below zero, where I'm storing it .... Its in a bay.
How do I un-seize it?
Old Apr 15, 2019 | 04:43 PM
63 Nova SS's Avatar
Don't know that you can, without replacing them. When cars set for long periods these kind of things happen sometimes. You could always disengage the cables from the shifter to see if you can pull them by hand. That would allow you to check the shifter out at the same time.
Old Apr 16, 2019 | 02:14 PM
Miltb's Avatar
I see .... Could have just rusted or something ....
Ya I'm gonna disconnected the cable to isolate the issue to make sure it's the cables
Old Apr 16, 2019 | 03:37 PM
hrspwrjunkie's Avatar
I've had good luck using Boeshield T-9 to loosen up stuck sheathed cables.
If that's the problem, you might give that a shot if you don't want to spend the cost to replaced them.
Old May 2, 2019 | 08:30 PM
cobaltssdude420's Avatar
Originally Posted by Miltb
Hello,
Happened to me and it was one of the cables. Just seized to ****. Even when I took it out, i tried spraying it and getting it to move but it was shot. Dirt and **** gets trapped inside of it
Dart_SI
Jul 28, 2017 02:57 AM
saltdawg
Mar 8, 2010 03:24 PM
anthonyS88
Aug 29, 2008 10:45 PM
STG2BALT
Apr 3, 2007 12:46 PM
djblass
Feb 2, 2007 01:15 PM
