Shifter won't move side to side in nuetral
Hello,
My cars sitting in a bay currently, waiting for me to do the timing chain .... Life got real busy so didn't have time for it yet.
Went to move it, just by rolling it and felt the shifter .... Shifter is stiff and will only slot up and down between 3rd and 4th .... Won't shift sideways in nuetral .... What happened?? Did someone reef on my transmission and I didn't notice? Or did letting it sit too long, stiffen up the fluid? .... It was fine before, drove fine to other than the timing rattle.
Any help is much appreciated.
Tried finding info on this, but seems it may be a unique problem ....
Don't know that you can, without replacing them. When cars set for long periods these kind of things happen sometimes. You could always disengage the cables from the shifter to see if you can pull them by hand. That would allow you to check the shifter out at the same time.
Ya I'm gonna disconnected the cable to isolate the issue to make sure it's the cables
I've had good luck using Boeshield T-9 to loosen up stuck sheathed cables.
If that's the problem, you might give that a shot if you don't want to spend the cost to replaced them.
Originally Posted by Miltb
Hello,
