Lsj + mp90 dynoed!
how are you guys runnning your meth nozzles? Im running a 7gph nozzle and could only get about 22 degress WOT and i have full exhaust vibrant header setup catless downpipe and gmp cat back. I find it interesting that some people claim theyre running 25 degrees (im talking peak timing too)
Just something to consider
its incredibly hydrophilic. 100% gasoline has a shelf life of a few years (2-3) but E10 gasoline is only good for about 90 days. Imagine what E85 or 100% ethanol/methanol do? (its an alcohol thing, so its not specific to meth/eth) Course you can still use it, but its not very good for the car anymore (biggest performance side effect being severely decreased octane as it ages)
Please do me a favor. Now that you have finally listened about the header, please set your rev limiter to 7400rpms. Run the car on the dyno out to a full 7000rpms and I bet you will be pleasantly surprised. I have no idea as to why your running such a big meth jet either, but on windshield washer fluid I was able to put in 25* of timing without an issue way back when I was street tuning.
Where do you get your meth from? I used to get mine from a speed shop when I was running it and they were closed one day so I got some from a different shop and I couldnt get any timing out of the car, so I went back and asked them about it and they told me its slightly diluted and was only 99 octane
Just something to considerAll those who are spinning the tvs out to 7400 rpm are over spinning using a 2.9 or smaller pulley.
A 3" pulley peaks efficiency on a TVS 1320 by 7400 @ a s/c rpm of 16,033.xx
I refill my 5 gal. meth drum w/ 100% methanol and store it off the ground for a longer shelf life. I've never had a batch of methanol ever go bad on me.
im a tech and work with alot of serious race guys. I get the 5 gallon drums of straight M1 methanol VP brand so it isnt the methanol i run a 50/50 mix with distilled water. funny thing is ive run other balts saying they are running 25 degrees timing and i bust their asses
I rapidly sloped timing down after 6400 rpm on purpose.
Gotta make them work a bit! haha
If he sloped the timing down after 6400rpms that would also be why the power is flattening out. When I set up my timing table after the initial ramp up it's the same across the board all the way to my redline. Add the new 4-1 header that will give better top end and the timing up top, I bet he'll make power up until or near 7k.
Indeed true. This is why I think you'll make power out to 7K with timing up top and the 4-1 header. This is my old 1200ax twinscrew dyno with a quick street tune that cleary needed more work. As you can see even with the stock cams and IIRC 21* timing up top, the car made power to 7K. Yes it made 272whp on a low rating Mustang dyno without methanol injection.
Okay. Hold the timing and rev to 7400 then. Deal?
