Dyno Results Dyno pictures, videos and dyno results.
Lsj + mp90 dynoed!
Old Jan 10, 2011 | 10:20 PM
  #401
HunterKiller89's Avatar
Originally Posted by ebristol
Even though people may run their TVS or M62 past its "efficiency" range, those blowers outside of their efficiency ranges, are still more efficient then the MP90 in the heart of its efficiency range. The MP90 on your car is a Gen 4 design which is less efficient and takes more power to spin then the M62 and much less efficient then the TVS.
you are aware that there are gen5 MP90's right?
pretty sure steve isnt using the old gen4 roots
Old Jan 10, 2011 | 10:49 PM
  #402
100% METH's Avatar
How much?
Okay. Hold the timing and rev to 7400 then. Deal?
deal
Old Jan 10, 2011 | 11:11 PM
  #403
InfraRedline's Avatar
Originally Posted by 100% METH
deal
Hey I wanted that same deal a few weeks back!
Old Jan 10, 2011 | 11:48 PM
  #404
100% METH's Avatar
lol... i havnt done any tuning since the last dyno.
replacing the front two wheel bearing hub assemblies.. then save a little money for 100 oct to tune maf off meth... then save for the dyno...
need some time...
Old Jan 10, 2011 | 11:49 PM
  #405
ebristol's Avatar
Not from where Steve got his from.
Manufacturer of Supercharger kits, remanufactured superchargers and supplier of supercharger oil.
Unless you know something I don't?
deal
I am not knocking you either. You know that right?
Old Jan 10, 2011 | 11:57 PM
  #406
100% METH's Avatar
your absolutely correct it's a gen4
no i know your not senor
  #407
2K5SS/SC?'s Avatar
How much what? Power? I'd have to look at his timing map to see. Ideally I like to tune for about an 11.6-11.8 AFR and run a safe 21* of timing on the street with meth. I have experimented and 25* is attainable as well, but I would reserve that for the track or special occassions. I'd be willing to bet on the same dyno he makes ~300whp doing what I've said.
  #408
OneCOLDBIZL272's Avatar
Eric there are 5th gen mp90's. Alot of the 3800 guys upgrade to it. The flow is improved and I believe the mp90 5th gen came of the newer bonivills but, not 100% certain on that. There are 5th gen mp90's I think a staright swap on a 3800 gtp from a gen4 to gen5 is like 5-15hp gain. thats a estamate.
Old Jan 11, 2011 | 12:07 AM
  #409
if you go to zzperformance. and look at their 3800 section, they actually have a used mp90 5th gen that they are trying to sell as used.
Old Jan 11, 2011 | 12:31 AM
  #410
100% METH's Avatar
That's a M90
Magnuson is phasing out the 90 series, resulting in the mp90 gen 4 being the final product.
Old Jan 11, 2011 | 12:43 AM
  #411
euthanasia's Avatar
Eaton M90 5th gen
Not sure if Magnuson will have there own MP90 version or go with the MP1650 TVS?
Old Jan 20, 2011 | 06:28 AM
  #412
100% METH's Avatar
picked up 10 gallons worth of methanol today
had about 1 1/4 gallons left of 50/50 mix left in the tank... filled the rest of the tank up w/ pure methanol...
no bog... engagement is 8 and 14 psi
noticeable difference in pull vs the 50.50 mix
still using 19gph
12.2-12.4 afr
92,190 miles on the car... oil separator is still showing no signs of getting dirty after a full nights worth of wot driving thru the cyns.
Old Jan 20, 2011 | 10:08 AM
  #413
ralliartist's Avatar
did you ever get a new dyno?
Old Jan 20, 2011 | 01:12 PM
  #414
euthanasia's Avatar
Not yet but soon. He just got his wheel bearing fixed.
Old Jan 20, 2011 | 02:37 PM
  #415
Originally Posted by euthanasia
Eaton M90 5th gen
take out these rotors and stuff em in the mp90 case? and maybe you can do a little port work on the openings to the case JR?
Old Jan 20, 2011 | 04:56 PM
  #416
100% METH's Avatar
^^^^ that wouldnt be a bad idea!
ralli -
i havnt... i did a lot of maintenance in the last 2-3 weeks. Just did my tax return last night... should be back on the rollers soon as the direct deposit hits.
Old Jan 20, 2011 | 05:18 PM
  #417
awesome. Don't mind me today, I'm drunk. lol
Old Jan 20, 2011 | 10:16 PM
  #418
RooTBeeR's Avatar
lucky! >_>
Old Jan 20, 2011 | 10:40 PM
  #419
ebristol's Avatar
That is an interesting idea. That should be good for around 20whp on the low side.
Old Jan 20, 2011 | 10:51 PM
  #420
100% METH's Avatar
if the rotors were 100 bucks... id make the swap
those rotors even at jr's price are no less than 600 dollars
Old Jan 28, 2011 | 07:01 PM
  #421
100% METH's Avatar
Those of u familiar with gcyl in hptuners. Gcyl is holding 1.12-1.20 until 4600 rpm now vs the 3800 rpm on the jbp header. Maf hasn't been touched... only things I changed are the meth mix to 100% and to a short v2 hdr.
Now hopefully the 3in dp and 3in. CAtback extend it out past 5k rpm.
Old Jan 29, 2011 | 01:59 AM
  #422
Yes I feel like we just had this discussion lol
Old Jan 29, 2011 | 01:34 PM
  #423
hungryhip-ccp's Avatar
What size is your maf housing?
Old Jan 29, 2011 | 01:36 PM
  #424
RooTBeeR's Avatar
Originally Posted by hungryhip-ccp
what size is your mar housing?
5"
Old Jan 29, 2011 | 01:38 PM
  #425
Bs..
diameter not length
Last edited by hungryhip-ccp; Jan 29, 2011 at 01:38 PM. Reason: Automerged Doublepost
