Dyno Results Dyno pictures, videos and dyno results.
The Official Dyno Thread
Old Feb 23, 2010 | 03:20 PM
  #126
elecblue06's Avatar
Originally Posted by boosted4dr
You imply the car stock vs stock program with modifcations will make same power....that is not the case. Learn down is simple air load values you can not pass (that is in gms1 still)....stock the car with mods made 10whp more then completely stock cars, with higher airload values it is now 11whp higher then the only other gms1 I've seen with dp...the ecm has never tried to maintain a certain whp number
he's right it will.. like you said it's air load values.. it limits those even when you have mods to let it flow better..
look at how when the dyno hits 260 trq it just keeps bouncing off of that.. the same way it wouldve stockat like 240-260 ( depending on dyno) the desired airload value doesn't move up at all so there would be no way to continue to show gains from mods without a tune.. vendors have shown this
Old Feb 24, 2010 | 03:20 AM
  #127
ralliartist's Avatar
List is up to date.
Old Feb 24, 2010 | 09:09 AM
  #128
PerformanceClutches's Avatar
Originally Posted by ralliartist
List is up to date.
where is my time?
Old Feb 24, 2010 | 09:41 AM
  #129
send it to me again, sorry bud.
Old Feb 24, 2010 | 11:07 AM
  #130
Tennpenn83's Avatar
i never have posted mine. here you go brad
M62, 2.8, am, h, dp, 42s, DU, T
249whp, 225wtq
TVS, 3.1, i, tb, 79s, h, dp, e, du, he, T, PI, cometic headgasket, arp headstuds
285whp, 250wtq
Old Feb 24, 2010 | 03:35 PM
  #131
sput's Avatar
^^ weak
Old Feb 24, 2010 | 05:58 PM
  #132
EXsoccer1921's Avatar
hes on a 3.1 and only took it to 6500, not that weak...
Old Feb 24, 2010 | 06:13 PM
  #133
SS/SC Crazer's Avatar
put me on that list!!! dyno vid is in my signature and the graph is in this thread!
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/adams-tvs-build-343-whp-300-tq-190849/
Old Feb 24, 2010 | 07:40 PM
  #134
Tennpenn83's Avatar
Originally Posted by sput
^^ weak
what was your first dyno with the TVS? no meth and 91 pump gas?
thank you. you can see it's only at 6500, and it's rising sharply right when he let off. that was on a base TVS tune. since then i have dialed in the maf, and cleaned up a lot of the drivability portions of the tune. i am anxious to get back to the dyno...
Old Feb 25, 2010 | 12:12 AM
  #135
https://www.cobaltss.net/forums/showthread.php?t=190849
I need to know your full mod list.
Old Feb 25, 2010 | 07:59 PM
  #136
oh boy... where to start?
TVS with 2.7" pulley, ported intake manafold, dual pass with opt B, ZZP H/E, OTTP 3" intake, CTI header,3" CTI catless DP, and 3" CTI catback, 80lb injectors, OTTP return fuel system with modded walbro fuel pump, E-85, 1 step coolder NGK sparkplugs, sparkplug spring inserts, MRZ light weight crank pulley, SPEC stage 3+ clutch with lightweight flywheel, custom tune by OTTP, STOCK ENGINE!!! NO HEAD OR BOTTOM END WORK!!! Mods comming this spring - OTTP fuel rewire kit, possible LS4 TB, poss built engine!
I think that about covers it, lol
note that that dyno graph was with an off the street tune, and i was running a full point lean at the top end, i was told with a little tuning which i have had done and some better airflow (driving vs boxfan) i should easily be past 350whp. havn't had it redynoed since i got tuned!
Last edited by SS/SC Crazer; Feb 25, 2010 at 07:59 PM. Reason: Automerged Doublepost
Old Feb 25, 2010 | 11:59 PM
  #137
TVS/2.7"/IM/DU/CM/HE/I/H/CD/DP/E/80's/FS/E-85/P/T
that's all I needed right there. lol
Old Feb 26, 2010 | 12:24 AM
  #138
troyss's Avatar
How you liking Germany Brad?
Old Feb 26, 2010 | 01:04 AM
  #139
I love it, but mainly because the base and shop here is SOOOOOOOOOO much better than offutt.
Old Feb 26, 2010 | 01:25 AM
  #140
i just can't wait for your ass to get your cobalt up and running and go twin charge and run some bad ass times and rip apart a lot of cars on the street. you'll surprise the hell out of some guys
Old Feb 26, 2010 | 07:06 PM
  #141
it was easier for me to type it out insted of going back to page one and finding the abbreviations for everything!
Old Feb 27, 2010 | 01:13 AM
  #142
yea, but it makes it harder on me. Those abbreviations are for everyone, not just me.
Old Feb 27, 2010 | 09:53 AM
  #143
my bad, sorry!
Old Feb 27, 2010 | 11:00 AM
  #144
lsjwannabe's Avatar
You were a point rich
Old Feb 27, 2010 | 01:18 PM
  #145
my bad, sorry!
no worries, lol
Old Feb 27, 2010 | 05:27 PM
  #146
oh, i though u said lean, ok well it deff shows that i don't know what im talking about when it comes to tuning, lol
Old Mar 2, 2010 | 08:16 PM
  #147
Darkmanx's Avatar
hes the only decent dyno i can find atm.
tvs ,2.9,heat exchange,dual pass, obt b, 79lb injectors, full 3inch exhaust and intake.
Old Mar 3, 2010 | 08:14 AM
  #148
Tennpenn83's Avatar
damn that is a flat torque curve
Old Mar 3, 2010 | 10:05 AM
  #149
is that with e85 darkmanx?
Old Mar 3, 2010 | 10:54 AM
  #150
Darkmanx's Avatar
you like it flat or peaky?
yeah thats with e85
