Current Problems You Are Rolling With
Old Nov 15, 2013 | 12:14 AM
  #126
Pinky Demon's Avatar
I've driven quite a few Cobalts, and I don't think I've ever driven one that didn't make some sort of nasty noise over bumps. I dunno.
Old Nov 15, 2013 | 12:18 AM
  #127
Gixxercobaltdriver's Avatar
The colder it gets, the nastier the noise lol. 35 degrees and below sounds like the tires are gonna fall off.
Old Nov 15, 2013 | 12:34 AM
  #128
the interior only gets rattlier at colder temps too haha.
well this is a 'new' clunking, im pretty sure of it. hard to tell with how many crazy noises ive heard over the years
ball joint? idk
Old Nov 15, 2013 | 12:43 AM
  #129
thedude411's Avatar
**** tune... and a stock pulley on my TVS :S
Old Nov 15, 2013 | 07:03 AM
  #130
owlwyn's Avatar
Quote:
If something isn't clunking in the front end, you aren't driving a Cobalt.
^this
Posted from Cobaltss.net App for Android
Old Nov 15, 2013 | 07:06 AM
  #131
owlwyn's Avatar
Originally Posted by Gixxercobaltdriver
and this.
as of right now since its been 25ish degrees out when I'm going to work, it sounds like my front end is going to fall off. and it was fine 2 weeks ago when it it was 45+ out
Old Nov 15, 2013 | 07:59 AM
  #132
Rick Bragstad's Avatar
There's a loose nut behind my steering wheel.
Old Nov 15, 2013 | 08:04 AM
  #133
blueLNFftw's Avatar
For once in my owning this car ive got 99 problem but my car isnt one.
Old Nov 15, 2013 | 08:17 AM
  #134
nobody2u's Avatar
Oh well if we're talking about cold weather, my front right strut squeaks quite loudly over bumps sometimes. Gets worse as it gets colder.
I've always just let it be though.
Old Nov 15, 2013 | 09:02 PM
  #135
Sometimes I get clunking in the front when I'm stopped and turn the wheel sharp. Started after I installed the coilovers.
Old Nov 17, 2013 | 08:58 PM
  #136
Jacob4ta's Avatar
Were clacking sound from front driver side.
Some belt squeaking.
My blower is making some weird grinding noises too. Time to rebuild that sob.
Old Nov 17, 2013 | 10:17 PM
  #137
dieGone's Avatar
- Passenger side window rolls slow too (need to replace regulator/motor)
- Driver's side window has super ugly scratch marks, needs polishing.
- Rotors are shot, steering wheel vibrates like crazy when braking.
- There's a noise like in the steering wheel like somethings a little loose, it sounds when I brake and when I go over light potholes. Still have to find out what it is.
- Car's rpm are very unstable when the car first turns on cold, to the point it almost stalls when I rev up the needle falls all the way to 400-500, 5-10 minutes into driving NO issues at all. Bothers me, but don't know what to even look for.
Anyone knows about this last issue? Car threw a code back in the day (PO300) Cylinder Missfire but the code would be on and off, replaced spark plugs and the code went away forever. The issue with the revs was there before I replaced the spark plugs. Any ideas?
Old Nov 18, 2013 | 10:47 PM
  #138
My pass side regulator is shot too. Rotors are a simple fix. Clunking over potholes I bet has something up with the column.
Which motor do you have?
Old Nov 18, 2013 | 11:02 PM
  #139
dieGone's Avatar
My pass side regulator is shot too. Rotors are a simple fix. Clunking over potholes I bet has something up with the column. Which motor do you have?
2.2 LS 100% stock don't know what to do I wish I could fix it but I can't diagnose what's going on and don't wanna go to a mechanic bc he'll say 2,000$ for cleaning the throttle... (Which is what I'm gonna do based on some research I've done it could be my problem) lol
Old Nov 18, 2013 | 11:04 PM
  #140
Tsbbzm's Avatar
Jedi Master
paint needs attention
Old Nov 18, 2013 | 11:33 PM
  #141
Make sure everything is tuned up first. This includes:
Spark Plugs
Fuel Filter
Air Filter
Then, clean your MAF sensor with some MAF cleaner available from most auto parts stores. Then hit your throttle body with some TBC again, from the parts stores. Pull your battery cables off, touch them together to reset the ECM, then drive and see if that corrects the issue.
Old Nov 18, 2013 | 11:44 PM
  #142
EmperorJJ1's Avatar
car is mia
Old Nov 19, 2013 | 12:04 AM
  #143
dieGone's Avatar
Make sure everything is tuned up first. This includes: Spark Plugs Fuel Filter Air Filter Then, clean your MAF sensor with some MAF cleaner available from most auto parts stores. Then hit your throttle body with some TBC again, from the parts stores. Pull your battery cables off, touch them together to reset the ECM, then drive and see if that corrects the issue.
Wow this is great advice!!
Spark plugs - Check!
Air filter - Check!
Fuel filter? (I replaced my fuel pump if that counts had a recall on it)
MAF sensor is a good idea - Pending.
Throttle was my first guess - Pending.
And the battery I thought resetted just by unplugging it and plugging it back on. But I have to touch the positive and negative together to reset ECM? Lol I'd assume this would blow up some fuses but guess I'm wrong haha
Thanks a lot man I appreciate it will try all of this Wednesday on my day off!
Old Nov 19, 2013 | 12:32 AM
  #144
Disposable-Hero's Avatar
I've been pididdling for months. Hopefully get that fixed this week finally.
Old Nov 19, 2013 | 12:45 AM
  #145
Infamous SC/SS's Avatar
My goal by the end of this week is to finally fix the damn sunroof. Hopefully drilling the tabs will fix the problem because I had to take the tracks out cause they were broken. Also I plan on buying a rain shield for my Injen Intake, cleaning my maf sensor, cleaning the fuel system, cleaning my backseat out, remounting the headliner and finally checking the spark plug gap. Busy Busy Busy....!
Old Nov 19, 2013 | 08:42 AM
  #146
Tsbbzm's Avatar
Jedi Master
Need to get aligned
Old Nov 19, 2013 | 04:12 PM
  #147
car is mia
You have the biggest problem out of everybody.
Old Nov 19, 2013 | 04:38 PM
  #148
TCBalt09's Avatar
Ive got two TPMS sensors that like to tell me FU** off mid drive.
Will eventually need clutch and both brakes are coming up.
Old Nov 19, 2013 | 10:08 PM
  #149
Air filter - Check!
Fuel filter is separate from fuel pump. It's an inline filter under the rear of the vehicle. Search for a replacement guide online. You may or may not need special tools, I can't remember at the moment.
When you clean the MAF, do not actually touch the MAF grid. You'll have to take it out of the intake tract. Just spray both sides down with the cleaner and let it sit and dry. The TB you will want a large screwdriver to help prop open. The car may run rough directly after with some smoke so don't worry.
As for the battery, no it won't pop any fuses because you are essentially completing the main circuit on the car with no power applied.
Old Nov 19, 2013 | 10:35 PM
  #150
nobody2u's Avatar
Feels with the tpms sensors here too, I've got two that are causing slow leaks in my tires.
