For discussion of all things Powell!!
Old Aug 29, 2013 | 08:55 AM
  #676
Powell Race Parts's Avatar
I never remove the bumper to install the tow hook. If you purchase tow hooks from me, request an emailed how to ; its complete.
Old Aug 29, 2013 | 09:22 AM
  #677
CobaltSS 16's Avatar
ok great sounds good.
yea i bought them a while back brand new directly from you.. just havent had the time to put them in. Ill email gloria then. Thanks.
Old Aug 29, 2013 | 10:43 AM
  #678
Nfamous60's Avatar
how much are the pcv systems again? trying to decide between this upgrade or more suspension. i have the hahn intake with pte5857 turbo.
Old Aug 29, 2013 | 11:49 AM
  #679
Refer to page 1, idk how much the check valves are for the oil return.
Old Aug 29, 2013 | 08:06 PM
  #680
its going to be hard to do them for less than 18 dollars plus two fittings. fits in the drain back line. The Kappa will be a little more costly than the Delta's it takes a different fitting set up.
Old Aug 29, 2013 | 08:59 PM
  #681
That's pretty cheap. Should I have a check valve running the ko4+?
Old Aug 29, 2013 | 09:12 PM
  #682
i think so. its hard to find a check valve that blows off at very low .5 psi pressure. I am hoping that the crank case blow by pressure if its not in vacuum is not high pressure. Because if it is, the motor is dead.
It looks like the GM goal of vacuum under all conditions is only true if you dont cane it at the race track though. Road race. I dont think 1/4 mile is long enough to cause issue, but what do I know? The non K04 for sure ; I think those installations have pretty much dumped the vacuum idea in boost in the crapper.
Old Aug 29, 2013 | 09:20 PM
  #683
I know of some check valves that open/close at low pressure but they are much more expensive than what you've found. I'll have to email you about getting a check valve to add.
Old Aug 29, 2013 | 09:32 PM
  #684
we looked for months to get where we are at. Very difficult. In the end we found the correct part for the application. Most check valves blow off at higher pressure. have a higher cracking pressure. One quote for this part ran 56 dollars each. So we had to work really hard to find sources. For a stock LNF even with GMS1 in good shape it should not be needed. But if you track it etc its essential. For me having it is peace of mind. But I dont want to be upselling people that dont need it; we are responding to track issues though, for sure 100% the K04 does not stay in vacuum on the race track all the time.
Old Aug 29, 2013 | 09:39 PM
  #685
I'm planning on tracking my car next summer, so it will be a needed upgrade
Old Aug 29, 2013 | 10:09 PM
  #686
JapEatr's Avatar
South Central *********
The official term is cracking pressure
Old Aug 29, 2013 | 11:00 PM
  #687
colodude18's Avatar
^^this. When I was doing daily log runs for my ZFR tune, oil was dripping from the car after I parked it in the garage. And that was maybe 3 or 4 ~1 minute acceleration runs. Once you start doing (10) 2-minute laps around HPR I have to assume it only gets worse.
Now that I only do an occasional pull and mostly daily driving, I have no issues.
So John, do I understand correctly that this solution is final and for sale? If so, shut up and take my money! But seriously, let me know how much and I'll shoot Gloria an email!
Old Aug 30, 2013 | 09:14 AM
  #688
yes contact gloria she is a NASCAR official on weekends and this long weekend is the big deal NASCAR Camping truck world truck race at Mosport and she is gonzo. But I will prep the check valve for you plug and play for your PCV upgrade and I can ship it out today as well she will deal with the money.
thanks
Old Aug 30, 2013 | 10:15 AM
  #689
colodude18's Avatar
thanks
Awesome thanks! I'll contact Gloria today and shall start calling her Gonzo ;-
Old Aug 30, 2013 | 03:13 PM
  #690
Your check
Valve is gonzo to u lol
Old Aug 31, 2013 | 01:43 AM
  #691
night_throne's Avatar
any update on the rotated auto tranny mounts id love to have some considering my coilovers will be here next week
Old Aug 31, 2013 | 09:57 AM
  #692
the reason there are rotated mounts for manual transmission cobalts, is that the transmission output axle shaft position is not the same as the auto trans, The auto trans is made correctly and in alignment, the manual is not.
so no rotated mounts for autos. I spent a lot of time trying to raise the motor on auto trans cars to enable extreme drops so the axle didnt bind. It is not feasible
Drop front spindles are. They would cost about 1600 the pair. Next.
Old Aug 31, 2013 | 10:58 AM
  #693
kdub1492's Avatar
So I already have the PCV setup, the check valve will just be plug in right? If so I know you talked about me having it, so I will take one haha
Old Aug 31, 2013 | 11:07 AM
  #694
2.2balt's Avatar
^If I was able to install mine with my stock 2.2 front bumper on, you sure as hell have enough room on yours...lol
Old Sep 20, 2013 | 11:09 PM
  #695
BLKLS's Avatar
I know it's been covered and I'm sure it has been covered here (I'm not reading threw 28 pages) what's the point of changing the front lower control arm bushings? I'm not trying to be a smart ass I'm serious... I just want to learn.
Old Sep 20, 2013 | 11:23 PM
  #696
andrewcarr1993's Avatar
The stock ones are most likely bad and causing problems such as steering wheel shake as I'm having.
Old Sep 21, 2013 | 10:02 AM
  #697
BLKLS's Avatar
No I know if they are f'd up they need to be replaced. Perhaps I didn't word that correctly. I need to replace my trailing control arm bushings again and plan on getting the spherical set but I was wondering what the advantage is to swap out the leading stock ones for Powell ones.
Old Sep 21, 2013 | 10:09 AM
  #698
06cobalt racer's Avatar
more solid feel. better control of your camber when turning and driving aggressive.
Old Sep 21, 2013 | 02:06 PM
  #699
^^^this. Troof
Old Sep 26, 2013 | 12:15 AM
  #700
06RYSS's Avatar
I haven't really paid attention too closely until recently so forgive me if this info is already out there, but you guys should do a big group buy/ black Friday sale this year if you weren't planning on doing so already! i'd definitely be in!
