For discussion of all things Powell!!
Old Sep 30, 2013 | 05:39 PM
  #726
Sox-Fan's Avatar
Got Brakes?
oil pan received and paid for.
who wants to buy it?
Oh, John, is there a check valve in that box? I wasn't going to open it if there wasn't a reason to.
Old Sep 30, 2013 | 06:01 PM
  #727
nobody2u's Avatar
Originally Posted by padlock
seeing as this is the powell discussion thread figured I'd mention this here.. Just upgraded from the Hardcore bar to the XXX bar. Took a couple trials to get tire pressures adjusted to where I like them with the new found stiffness, but overall its a great piece of equipment. I'm really getting to like how the car handles when setup for track days, although I have found that on "daily driving pressures" ~30-34 F/R psi the car gets pretty snappy in the steering response over the hardcore bar and it will actually oversteer slightly... so knowing that I just be a bit more careful with it on the street (not to say you cant just throttle out anyways, but you get the point).. but like I said, fantastic part to use when I have tire pressures dialed in a bit lower in the rear on track days
I'm on YYZ V1's and 235/40/18 BFG KDWs as well for what its worth to you all...
This is good information, the XXX sounds like it's more than I need.
Old Sep 30, 2013 | 06:45 PM
  #728
Nukesforbreakfast's Avatar
It's a misconception that the XXX (or any other) bar will make your car drift and oversteer. It (greatly) reduces the understeer characteristics of the Cobalt, giving it a more neutral behavior in aggressive turns. It also firms up the rear end of the car in terms of flex. I use the XXX bar for road racing; for auto-x I would definitely get the triple-x.
Makes sense and I was pretty sure that's what it would help do. I just was a little worried because as of right now I'm running some Direzza Z1 star specs I had lying around for the rest of the year and to get the car to rotate more in the corner I have pumped up the tires in the rear a good 8-10 PSI higher than the front and it works. Sometimes too well(but driver mod is probably a large factor). I guess the idea would be with the sway bar it would give you that same effect with a lower pressure and more range to adjust the pressures, correct?
Old Sep 30, 2013 | 07:13 PM
  #729
Powell Race Parts's Avatar
the rear bar keeps the front wheels working. think rear bar/ front effect( keeps both front wheels well placed and helps turn in) front bar /rear effect( keeps rear tires well placed and helps rear grip which hurts turn in)
the rear bar the way it is designed not only increases rear roll stiffness it changes the rear roll center ( google) that is something that increasing rear tire pressure of course does not do.
all you get from increasing rear tire pressure is an increase in sidewall stiffness and the risk that the car will "skip"at the rear, which in itself can be scary, Keep your foot in it, and the rear can dance all it wants you will be okay. Up to a point.
But with real good progressive rate springs ( ya, I mean YYZ) and the rear bar, the whole car comes alive.
It is hard to oversell the significant handling improvement of the hardcore rear bar. Hard also to oversell YYZ and a triple X or hardcore on the race track. Just listen to guys like Wangspeed ( thanks tohis griping about Pedders collapsing that I went and got Hyperco to make YYZ) and to Speedbuggy who has shattered all his personal best lap times at various tracks in the Chicago area. YYZ/Hardcore or xXx. For serious drivers ...
as a matter of fact I had a customer drop in today on his way down east for a holiday. He auto x 's in Ontario. I put the hardcore on his car. He drove it down the road a bit and then stopped and said "They said it would be good and I thought "ok" But this is amazing!"
Troof/
Old Oct 1, 2013 | 01:11 PM
  #730
padlock's Avatar
did some drag racing this weekend.. YYZ V1's dont seem to squat too much in the rear on this launch given I was pre-loading
Old Oct 2, 2013 | 07:26 AM
  #731
Staged07SS's Avatar
Administrator
Administrator
How'd u do against that rustang?
Old Oct 2, 2013 | 07:59 AM
  #732
09TcSedan's Avatar
So I broufht my car into the dealership last week, I thought I had a wheel bearing goin out. Turns out my CABs are toast which took out my alignment and then cupped the hell out of my tires.
I ordered new CABs from john and plan on replacing the in 2 weeks. Is I put the new powell CABs in and don't get my car aligned for a couple of weeks, would that screw anything else up?
Still haven't figueed out which tire I want to go with yet.
Old Oct 2, 2013 | 08:10 AM
  #733
if you have not changed the alignment from new its a good bet it will be fine. its easy to check toe in is the only parameter to check. tape measure side to side to the same spot front of tire and rear of tire . 1/8 toe in total is stock. so 1/8 longer back side of side to side tire measurement compared to front
Old Oct 2, 2013 | 08:25 AM
  #734
Whitnith's Avatar
Troof/
But when I wanted to move up from my Street, I was told I can't handle it.
I see how it is.
Old Oct 2, 2013 | 09:29 AM
  #735
Sox-Fan's Avatar
Got Brakes?
^ uh oh. Someone's in trouble now....
Old Oct 2, 2013 | 09:55 AM
  #736
padlock's Avatar
I beat him
he was a good friend of mine. running 13.6-ish most of the day on his street tires trapping 104-106 most of the time. I was around 13.5-13.65 most of the day trapping 107-109. Close races are always fun races
Old Oct 2, 2013 | 01:01 PM
  #737
I see how it is.
I certainly did not tell you that
Old Oct 2, 2013 | 02:57 PM
  #738
Gmoney06's Avatar
Lots of awesome info in here!! Just read all 30 pages, and it was well worth it. Looks like some Powell parts will be my first mods to the car. Probably gonna start with the rotated mounts with and lnf rear mount. Starting to save up now. Can't wait to actually order.
I'll have some more questions here in a few when I'm not at work and can actually make a full post.
Old Oct 4, 2013 | 11:15 PM
  #739
GreenySC2's Avatar
what ever happened to the R&D on the replacement Brembo rear brakes you were working on?
Old Oct 5, 2013 | 02:09 AM
  #740
JapEatr's Avatar
South Central *********
Got sidelined with helping jap build a fuel system...
Old Oct 5, 2013 | 02:33 AM
  #741
andrewcarr1993's Avatar
As far as I'm aware (since I'm interested) he's got a set or two complete and is in testing to try and make sure there aren't issues.
Old Oct 5, 2013 | 05:00 AM
  #742
GreenySC2's Avatar
fuel systems cant be that hard hah from tank to injectors! done and done!
kidding i hope it works out great for ya! but i'm pretty sure i'm going to be on board for the brembo rears when they are done..
price point considering(and if he can powder coat them)
Old Oct 5, 2013 | 07:43 PM
  #743
I am waiting on the parts to come in. I got the plan, the parts figured out I have to put it together and with respect I did say it was going to be a late October project. pc is always possible.
Old Oct 5, 2013 | 08:08 PM
  #744
EmperorJJ1's Avatar
sorry to bug john but did u ever get my e-mail with the pics regarding the UCR hardware?
Old Oct 5, 2013 | 08:23 PM
  #745
An early estimate was $1750 but that is by no means an exact or final price.
Old Oct 5, 2013 | 09:52 PM
  #746
JapEatr's Avatar
Got the big box of powell today John, ill go thru the contents tomorrow
Old Oct 5, 2013 | 11:51 PM
  #747
yes fell down on that, email me again I ran some extra bolt plates for you last week.
Old Oct 6, 2013 | 12:08 AM
  #748
EmperorJJ1's Avatar
cool ya no prob ive been spending money lately like water so it worked out
Old Oct 6, 2013 | 12:28 AM
  #749
kdub1492's Avatar
Hey John,
I have emailed Gloria 3 separate times about the check valve for my PCV system and have not heard anything back. I'd like to get it while everything is out of the car. Hope you can get back to me soon so I can get it in the car.
Btw the valves looked great after 5k miles with the PCV system, little to no buildup
Old Oct 6, 2013 | 12:38 AM
  #750
GreenySC2's Avatar
very true, like i said if the price with pc is good i'm so so so in.... my parking brake not working is a slight issue more of an irritating thing though....
