Lil Blacky’s official TVS build thread(long post)
Old Jan 26, 2018 | 02:10 PM
  #226
Johnny Bliss's Avatar
when you run the spacer how does the bottom of the intake manifold bolt onto that bracket??? do they provide a piece to put in there?
Old Jan 26, 2018 | 02:21 PM
  #227
chevygirl2006's Avatar
That big bolt that goes through the manifold and to the ic pump bracket?
Old Jan 26, 2018 | 02:23 PM
  #228
yea, wouldn't that not bolt up because it should be a few inches further out?
Old Jan 26, 2018 | 02:30 PM
  #229
I don’t have that bolt. None of our cars keep that bolt lol
  #230
Henry3959's Avatar
me neither
Old Jan 26, 2018 | 02:31 PM
  #231
hm back in the day when i wasn't getting so old i would've just said f it with that bolt but that whole intake manifold w/ sc is pretty heavy i mean they put it there for a reason
i guess it doesn't make a big diff if you guys havent' had a problem without it
Old Jan 26, 2018 | 02:33 PM
  #232
07blackg5's Avatar
Slobodan Milošević
there are 3 spacers that space the 2 bolts on that bracket and the and the pump bracket to oil pan bolt
Old Jan 26, 2018 | 02:35 PM
  #233
so when you guy it all from zzp they give you those spacers?
Old Jan 26, 2018 | 02:45 PM
  #234
07blackg5's Avatar
Slobodan Milošević
yes
Old Jan 26, 2018 | 02:51 PM
  #235
I don’t remember getting that with mine.
Old Jan 26, 2018 | 02:59 PM
  #236
07blackg5's Avatar
Slobodan Milošević
it comes with the phen spacer, 2 gaskets, longer bolts, and 3 spacers for the lower brackets. basically thick washers
Old Jan 26, 2018 | 03:08 PM
  #237
That’s what those were?! I had no idea lol
Old Jan 26, 2018 | 05:29 PM
  #238
jdbaugh1's Avatar
I don't even have the bottom bracket as ZZP doesn't provide it with their SC kit and they claim you don't need it. Places more stress on the top manifold to head bolts but must not be enough to cause it to leak or anything.
Old Jan 26, 2018 | 09:26 PM
  #239
WHIch bracket?
Old Jan 27, 2018 | 09:30 AM
  #240
jdbaugh1's Avatar
WHIch bracket?
The bottom bracket that bolts to the block and the bottom of the intake manifold. I think it may also be part of the IC pump holder but not sure.
Old Jan 27, 2018 | 10:59 AM
  #241
Oh ya it is. I have that.
Old Jan 27, 2018 | 02:51 PM
  #242
Henry3959's Avatar
I don't see that in the ZZP kit. I found it easier to just get what you need all at once from Jerry and for less $$
Old Jan 27, 2018 | 06:29 PM
  #243
jdbaugh1's Avatar
It's not in the ZZP kit. I also didn't know anything about the LSJ setup when I supercharged my car so I went with ZZP because I wanted to make sure I would get everything in one shot as I didn't know what I would need yet. Still had to source some parts. But it was also back when they had the option of buying a new M62 with the kit. It was convenient and worth it for sure.
Old Jan 27, 2018 | 06:35 PM
  #244
I bought my m62 stuff in a used kit. Stage 3 Stuff. Also my car is ready to be started pretty much now that the single pass manifold is done. Had my boyfriends dad weld it. It’s not the prettiest but it works.
Old Jan 27, 2018 | 06:45 PM
  #245
jdbaugh1's Avatar
I think it looks pretty good. Aluminum is not easy to weld up pretty especially with that number of seams and having to be water tight. Did you put some low pressure on it and test it out?
Old Jan 27, 2018 | 07:13 PM
  #246
Yes. It had one pen hole and we welded it last night so now it’s good to go.
Old Jan 27, 2018 | 10:52 PM
  #247
tomss's Avatar
Why did you go to the single pass setup?
Old Jan 27, 2018 | 11:04 PM
  #248
Henry3959's Avatar
I'm confused... What's on the inlet side?
Old Jan 28, 2018 | 01:03 AM
  #249
Because single pass is far better than dual. Coolant only passes over the manifold one time so it doesn’t heat up as much since it’s not in there very long. And on the side it’s a modified stock endplate. There’s a guy that makes single pass manifolds now and the intake temps are insane.
Old Jan 28, 2018 | 01:05 AM
  #250
And the inlet is now the passenger side that was welded.
