Official Dyno Thread.
Old Apr 25, 2008 | 11:23 AM
  #526
lsjwannabe's Avatar
Originally Posted by Area47
it's true!
i have never used a dyno for making big numbers. i know what my car makes. what i post is usually lower. not that i care enough anyways.
use the dyno to work out issues with a car. back to back 80-124 mph passes on the street lead to issues.
i know of these issues so do the popo and the judge, we have become all to fimilar.
Old Apr 25, 2008 | 11:25 AM
  #527
Darkmanx's Avatar
people who use dyno's for making big numbers to inflate their already weak self esteem need to be shot.
STOP talking sh*t behind my back.
Old Apr 25, 2008 | 11:27 AM
  #528
Area47's Avatar
Rent me! per hour
STOP GIVING PEOPLE THE RAKE
im all to familiar with excessive speed issues.
Old Apr 25, 2008 | 11:30 AM
  #529
Darkmanx's Avatar
BiTE me again.
Old Apr 25, 2008 | 07:23 PM
  #530
lsjwannabe's Avatar
Question to you higher hp guys what correction factor do you use sae or std?
Old Apr 25, 2008 | 07:51 PM
  #531
Area47's Avatar
Rent me! per hour
depends if i catch it or not. 99% of the time is sae
Old Apr 25, 2008 | 07:53 PM
  #532
lsjwannabe's Avatar
i noticed m dub's was std and i was just wondering...
Old Apr 25, 2008 | 07:59 PM
  #533
INFE's Avatar
i guess you can add me to the list. mods and dyno jet numbers are below.
Old Apr 25, 2008 | 08:20 PM
  #534
lsjwannabe's Avatar
alot of guys running uncorrected numbers to. maybe i should throw mine up just to make it look like a dyno queen.
Old Apr 25, 2008 | 09:01 PM
  #535
Area47's Avatar
Rent me! per hour
my 274 stage 2 pulley dyno was in sae. maybe i should have gotten the std numbers and broke 280
lol!
i got nothin
Old Apr 25, 2008 | 09:04 PM
  #536
lsjwannabe's Avatar
yeah probably, lawl at the 2.9 guys that are doing 26X on a stage 2 tune
Old Apr 25, 2008 | 09:07 PM
  #537
Area47's Avatar
Rent me! per hour
hehehehhe. this is why i post my street numbers. not the "on kill" dyno numbers
ain't i a stinker
Old Apr 25, 2008 | 10:08 PM
  #538
lsjwannabe's Avatar
ha you and me both...
Old May 4, 2008 | 09:15 PM
  #539
Dunkinuts's Avatar
add me 2.4L stock
https://www.cobaltss.net/forums/2-4l-le5-performance-tech-46/dyno-numbers-110333/
159hp 156tq
http://farm4.static.flickr.com/3202/...299a860e_b.jpg
^^click for larger image^^
Old May 4, 2008 | 11:04 PM
  #540
NWAE Cobalt's Avatar
I want to be changed from the 2.4 to the 2.2 section!!!! switch me to the propper section!!!
Old May 5, 2008 | 11:20 AM
  #541
Dunkinuts's Avatar
why isn't this a sticky yet?
Old May 7, 2008 | 05:41 PM
  #542
o3nisoaso3's Avatar
i cant wait to get my new numbers on this motor b4 my built motor is finished and put it
im hoping for 150+whp and 160+wtq
Old May 11, 2008 | 06:10 PM
  #543
Dunkinuts's Avatar
updates?!?!?!?!
Old May 13, 2008 | 02:54 AM
  #544
InfinityzeN's Avatar
Man, I seriously need to get a retune and dyno again. My listed dyno is only through 6.4k rpm and with a hell'a bad exhaust leak. I did have a very flat torque curve though, 221 @ peak and 206 @ 6.4k.
I, H, DP, E, T (need a new one), DU, 55s (not installed due to lack of tOoN), 2.9", HE
Should be better the next time thanks to ^^^ the changes above. I'll actually be able to run up to ~7k without my AFR going all wonky like it does with the Stage 2 42# injectors.
I'm also not running the maximum timing I can without knock, since while doing the last tOoN we hit a point where I actually started dropping in power.
I posted my SAE corrected numbers. I was only 236whp on the Stage 2 tune and 251whp after the custom tOoN. Didn't gain any wheel torque, but my peak moved from ~4.45k on the Stage 2 to ~4.3k on the custom tOoN and was a lot flater overall. Was over 12ft/lbs higher at 6.4k (highest that the stage 2 injectors wanna stay stable till, went all wonky higher).
Last edited by InfinityzeN; May 13, 2008 at 02:59 AM. Reason: Automerged Doublepost
Old May 13, 2008 | 11:25 AM
  #545
lsjwannabe's Avatar
yeah your numbers are fine i was talking more the high 260's on a stage 2 tune only
Old May 17, 2008 | 11:35 AM
  #546
n8g's Avatar
n8g
237/222
Mods in sig
Old May 17, 2008 | 08:41 PM
  #547
Dunkinuts's Avatar
why hasn't this been updated in forever!?!?!?!
Old May 27, 2008 | 06:28 AM
  #548
Dayta's Avatar
ill have some new numbers tonight,
the meth and 2.7 went on
Old May 28, 2008 | 07:58 PM
  #549
Dayta's Avatar
253hp
238 ftlbs
bump me up!
Old May 28, 2008 | 08:21 PM
  #550
Dunkinuts's Avatar
yeah why hasn't anyone updated this?!?!?!
