Official Dyno Thread.
Old Nov 26, 2007 | 01:42 PM
  #151
06black's Avatar
Originally Posted by 06blackg85ss
If I can find someone willing to trailor me down, I just might. I think Atco is open this weekend but #1 I hate that track for FWD and #2 it's too damn cold lol.
hey paul i'm not sure if theres a direct way to talk to you, like of the forum but i have some tips for you when you order your 30R.......
i've kinda got some experience with it....ohhh and the 35R on my scoobie
I <3 GARRETT
Old Nov 26, 2007 | 04:47 PM
  #152
skymynx's Avatar
Originally Posted by Darksun
I say unverified numbers should be left of the list. Whats the point of putting them up?
i put them up there to give people a broad idea. trying not to leave people out even if they have no proof. luckily noones really claiming something high without proof
Old Nov 26, 2007 | 04:49 PM
  #153
Area47's Avatar
Rent me! per hour
the odd torque numbers from the 2.7-2.6 cars bother me though
Old Nov 26, 2007 | 05:49 PM
  #154
06black's Avatar
on a dynojet at a undisclosed location
SAE certified and corrected.
21psi and my last dyno run for a while
the new found power is more due to the bent exhasut valve i replaced, found it when i did a leak down on the motor.
reworked the dyno set up tune and get this.
it was fairly consistent across 5 pulls....heat has finally become a non-issue.....but it is snowing and like 30out as well...
387/360
Old Nov 26, 2007 | 05:59 PM
  #155
Area47's Avatar
Rent me! per hour
hate to say it man, but it looks like a fisherprice's "my first dyno" im not doubting the numbers, just seems a bit wierd
what was your egt temps on that run?
Old Nov 26, 2007 | 06:10 PM
  #156
06black's Avatar
the pen marks are my notes and the odd lines are from me tracing over the original ones with a sharpie(sp?) it was in color but i guess our "all in one" scanner, printer thing wont scan color.
the lines look like a little kids because thats the extent of my tracing skills
in original form every things vary light in contrast so i wanted to darken it up.
as for egts i have no clue, however i did find a sweet way to get the EGT's up before a pull and thats what helped my torque number the most.
i need a spot to mount said EGT gauge before i can use one to my benefit.
i'm still battling some KR up top, if not for that i think the curves would be more consistent up top
Old Nov 26, 2007 | 06:14 PM
  #157
Area47's Avatar
Rent me! per hour
brake boosting does wonders doesn't it
i was just givin ya **** about it. it's ok. you're still faster than me. by oohhhhhh 107 hp
you suck
::takes ball and goes home::
Old Nov 26, 2007 | 06:18 PM
  #158
06black's Avatar
you suck
not brake boosting, not this time at least...
wanna know what it is?
its stupid easy, i figure paul might give it a shot
Old Nov 26, 2007 | 06:19 PM
  #159
06blackg85ss's Avatar
387/360
Very nice man... what correction was used if any on that pull
anyway I will definitely be looking to you on the gt30r when I finally get to ordering that. As of right now cash is tight and with said planned fuel upgrades, I'll probably just be getting the same size turbo I have now, just a better quality one, probably a turbonetics for now.
I've been keeping my TQ numbers down since I"m still on the stock clutch and I need it to hold out til I do my motor swap since I don't really feel like taking everything apart more than once.
Old Nov 26, 2007 | 06:30 PM
  #160
06black's Avatar
According to the guy at the dyno the correction factor was a "1" or what he called a "stright pull" that combined with the KR all lead to the erratic numbers/curve from mid-rpm range on up.
let me know when you get to the point of ordering a turbo, i'm way into all the new stuff rite now.
as for torque on the dyno its easy....its all in the EGT's
go into HPT (the scanner) start to log the car and then click on the "on / off / 100%" button next to the DTC check button.
then click on the "special" tab and look at the idle control window.
type 2000 into the window and click the "RPM" button thus haveing the car hold its self at 2000rpm BUT it use's idle control spark numbers (9-10deg) that low of a timing number combined with the extra fuel needed for that rpm and BAM, she'll start to glow if you hold her there for a sec, makes AWESOME torque improvements across the mid-range.
Old Nov 26, 2007 | 06:33 PM
  #161
Area47's Avatar
Rent me! per hour
ahhhhhh cheap antilag
hehehe
Old Nov 26, 2007 | 06:38 PM
  #162
not bad man, I might try that, but not with this clutch
Old Nov 26, 2007 | 06:40 PM
  #163
06black's Avatar
vary true sir, if only it worked in a more convenient way.
but such is life i guess, to many people put wayyyyyy to much stress and emphasis on dyno numbers....the good ole butt dyno has never let me down before!
to me the car with my DD tune pulls harder through the gear but that could be because of multiple variables so i guess it could "just be me"
but she moves pretty good, lots of fun on the highway. and the best part is shes still a beast from our famed 40 roll
give it a shot bro!
if you clutch is that bad you could vary well be loosing some power across it....just a thought
Old Nov 26, 2007 | 06:42 PM
  #164
I couldn't agree with you more man.
I'm a big track number guy, so that's why I"m dying to get out there in the spring. But the car pulls damn hard... I just don't street race so I really can't compare it to other's until I hit the track.
Ask phil (darksun) I took him for a few pulls...... no homo
give it a shot bro!
no it's not bad at all... it holds perfectly, still will chirp 3rd if I WOT.. but it's the original stocker with 27,000 miles on it, and I would like it to last a bit longer. Once I get the exedy in, then I'll start messing with TQ. But my car has been modded for power since it was 1 month old, so I just don't want to push my luck with the clutch any harder then I already am
Last edited by 06blackg85ss; Nov 26, 2007 at 06:42 PM. Reason: Automerged Doublepost
Old Nov 26, 2007 | 06:46 PM
  #165
06black's Avatar
buwhahha.....good thing you put the "no homo" in there cuz i was about to start asking questions!!!
i like track numbers as well but i for one am huge on the street racing side of things...thats how i judge if my car is "good enough" or if she needs more work
i'm with ya paul, i put about 30k on my stocker and she wouldn't spin the tire or stall the car when i was done with it.
so far i absolutely LOVE my spec 3+
Old Nov 26, 2007 | 06:48 PM
  #166
Area47's Avatar
Rent me! per hour
go from a 30 punch. it's fun when roast the tires past the car you're racing.
they look at you funny when you do.
i think we "officially" screwed this thread up.
Old Nov 26, 2007 | 06:50 PM
  #167
yeah we kinda took over this thread lol.
but yeah I got arrested for street racing back in 01 and got nailed really bad (no homo) 165 in a 40 and felony evasion and about 15 other violations, no license for 3 yr's and $22,000 in tickets really sucked.
Old Nov 26, 2007 | 06:56 PM
  #168
widebody_balt_ss's Avatar
holly ****. Im never street racing again. pluss if something happenend to somone I would not be able to live with it.
Old Nov 26, 2007 | 07:10 PM
  #169
06black's Avatar
LOL AHAHA, vary true sir.
however when the car sounds like a jet on takeoff, that also gets some looks
and yea, we jacked it up!
BACK ON TRACK!
**** me man, i've been busted for some **** before but DAM.
glad to see you have a car again!
on a serious note....paul, and Area47(it would be helpful to know your name) maybe we could eaither hit up AIM or go PM crazy and exchange some notes, tunes, ideas, ect....
i grow tired of talking with idiots on here, so when i find a few people who are on the same page as i am i try to stay in contact with them...get what i'm sayin.
your thoughts?
Old Nov 26, 2007 | 07:11 PM
  #170
agree.... aim thing is in my links under my name
Old Nov 26, 2007 | 07:15 PM
  #171
06black's Avatar
word up, gonna snag a video and then i'll be on.
Old Nov 27, 2007 | 09:57 AM
  #172
RedBaseBolt's Avatar
Bumpage
Old Nov 27, 2007 | 11:38 AM
  #173
Area47's Avatar
Rent me! per hour
06, i have aim, but rarely on it. avoidance of a stalker ex. go figure.
BTW the exedy single is good for 358 ftlbs {i have inside info}
Old Nov 27, 2007 | 12:09 PM
  #174
hmm that;s not gonna be enough... guess 4 puck bully it is
Old Nov 27, 2007 | 12:28 PM
  #175
06black's Avatar
i WILL have excedys twin disk if i can ever get my hands on it.
i love my carbon-carbon twin disk in my scoobie.
