Official Dyno Thread.
Old Mar 3, 2008 | 07:30 AM
  #401
skymynx's Avatar
Originally Posted by freakta
got new numbers. 255hp and 232tq will post up the dyno sheet soon
well post your sheet and then your numbers will get posted
Old Mar 3, 2008 | 08:00 AM
  #402
BRN169's Avatar
Hmm, These numbers are posted in a hierarchy but Mustang and DynoJet numbers are commingled... There should be a numerical adjustment to even the field when comparing the numbers from both types of dynos to get a true picture of the hierarchy...
Old Mar 3, 2008 | 09:52 AM
  #403
freakta's Avatar
blue is my old run
red is my new run
3.0 pulley
cold air intake crushed (it was crushed in an accident)
zzp header downpipe
snow performance progressive meth kit
42 lb injectors
Old Mar 3, 2008 | 11:59 AM
  #404
elecblue06's Avatar
he said he's not doing this because there's no science to it .. not all dynos are alike.. one DJ can read 15% different from a mustang while another can read exactly the same...
Old Mar 8, 2008 | 09:38 AM
  #405
RollOver360's Avatar
230/ 190 on a Mustang Dyno, which is about 261/ 216 on a DynoJet. The mods I had at that time were Custom CAI, Custom dual side exit catback exhaust, and a great tune by Matt @ TuneTimePerformance. Ill post up a dyno sheet later.
Old Mar 8, 2008 | 11:36 AM
  #406
skymynx's Avatar
thank for reiterating this fact. i understand people want an even playing field but without an exact forumula im not gonna change it.
post up you dyno sheet and ill be glad to add you to the list
Old Mar 8, 2008 | 11:51 AM
  #407
elecblue06's Avatar
np just getting annoyed wiht people asking for it when there's no sure fire way to get it right
Old Mar 8, 2008 | 01:40 PM
  #408
later
Old Mar 11, 2008 | 09:31 AM
  #409
firemanfrank's Avatar
230/ 190 on a Mustang Dyno, which is about 261/216 on a DynoJet.
According to an article I read that did back-to-back testing on a Dynojet and Mustang Dyno using an '00 six-speed Z28 Camaro:
"The Dynojet measured 5.1 percent higher horsepower in Fourth gear, 7 percent higher horsepower in Third gear ..."
So using the above adjustment numbers, your Dynojet figures are more like 241-246whp and 199-203wtq.
Considering your hp related mods of a CAI and an exhaust with stock resonator and Y-pipe w/glass packs, that seems reasonable.
And dubs 258/230 is actually closer to 271-276whp, 241-246wtq. on a Dynojet.
Old Mar 11, 2008 | 09:46 AM
  #410
BRN169's Avatar
So on a DynoJet I would be about 280/239... Sweet... Gotta go find me a DynoJet!
Old Mar 11, 2008 | 10:03 AM
  #411
elecblue06's Avatar
only with those two specific dyno jets...
it all depends on calibration too he's not going to convert it.. so people stop pressing the issue
Old Mar 11, 2008 | 10:16 AM
  #412
First off, you need to chill out man.
I'm not "pressing" anything. Just reporting on a test.
Secondly, your reply indicates you missed the point.
The test was back-to-back testing of a Dynojet vs. Mustang dyno.
No arguing there.
If you don't like the results, then give me another article where back-to-back dyno testing was done with the same car with those two dynos.
Then stop laughing and do it already!
LOL
Last edited by firemanfrank; Mar 11, 2008 at 10:16 AM. Reason: Automerged Doublepost
Old Mar 11, 2008 | 10:30 AM
  #413
Misery5567's Avatar
Ahh well.
I guess my setup is weak then.
Carolina Auto Master's tune on a 2.8 pulley & 60#ers only netted me 242whp/227tq on a Dynojet. But my AFR stays under 12 past 2500 rpms Nice safe strong tune and a 23% IDC.
Old Mar 11, 2008 | 10:41 AM
  #414
Area47's Avatar
Rent me! per hour
some of you are dreaming in an empty wishing well again.
possible new numbers comming this weekend
Old Mar 11, 2008 | 02:17 PM
  #415
Edubs's Avatar
Frank, use your head. I don't just make empty claims. The Mustang dyno at TTP is 13.5% lower than standard dynojet #'s. Typical mustangs are 12% lower. That all changes from dyno to dyno. I could care less if he converts the #'s and what they would be. I should have never mentioned anything in the first place about what my numbers could be, cause it doesn't freakin' matter anyways. Bottom line is, my car made 258whp on a dyno and I guarantee my car will smoke any other car w/ similar #'s. Take it however you want.
I'm fine w/ that...
Old Mar 11, 2008 | 05:51 PM
  #416
I have 697whp and 893wtq..... to the steering wheel... lol....
U know eDubs I can smoke u... in my winter beater.. lol...
later
Old Mar 11, 2008 | 06:02 PM
  #417
Dayta's Avatar
later
burn
are you gonna take that?
Old Mar 11, 2008 | 08:56 PM
  #418
Originally Posted by Edubs
Frank, use your head. I don't just make empty claims. ...
Dubs, I was using that article to simply project #'s from what you had reported.
That was all. It was not meant as a personal atttack against yourself/your car's performance.
I would really appreciate it if you stopped using such demeaning remarks as "use your head".
It's rude, and doesn't befit the otherwise friendly presence you relate to people when speaking to them in person (as have we).
The Mustang dyno at TTP is 13.5% lower than standard dynojet #'s. Typical mustangs are 12% lower. That all changes from dyno to dyno. I could care less if he converts the #'s and what they would be. ...
I was just extrapolating #'s for people's thoughts/input.
What in the heck is up with everybody around here?
I should have never mentioned anything in the first place about what my numbers could be, cause it doesn't freakin' matter anyways. ...
There's absolutely nothing wrong with you posting your dyno #'s on a forum with people who share similar vehicles/interests. Doing so should make it informative for the rest of us which should then lead to worthwhile discussion (supposed to anyway).
Bottom line is, my car made 258whp on a dyno and I guarantee my car will smoke any other car w/ similar #'s. Take it however you want....
I'm fine w/ that...
Wow.
later
Last edited by firemanfrank; Mar 11, 2008 at 08:56 PM. Reason: Automerged Doublepost
Old Mar 12, 2008 | 08:39 AM
  #419
Edubs's Avatar
You made your point. I made mine.
I have no issues w/ pointing out the obvious, regardless if the communication being in person or online. I would have said the same thing in person. USE YOUR HEAD FRANK!!!
I don't care if you think it's rude. You should know from dealing w/ me in person that I would have a smile on my face while yelling at you. I'm a ball buster. Cup check?!?
You made your point. I was just countering with the fact that your numbers are uncommon. You seem to like to learn. I was simply supplying knowledge.
We don't take things written online personally; however, we also don't turn down an opportunity to debate the facts.
Glad you cleared that up, I was about to buy a vaccuum cleaner...
Wow.
Wee.
Nick likes to challenge me. I shall bitch-slap accordingly...
later
*SCHLAPP*
Right across yo' face son. Bring ur beater, I'll bring my jebus sandals. We'll settle this once and for all...
Old Mar 12, 2008 | 09:35 AM
  #420
USE YOU HEAD FRANK!!!
As of late, I've noticed that you haven't been taking sufficient time to review the content of your statements before posting them (whether they be automotive or personal).
^And now we finally get to the heart of the problem.
I go to great lengths in my life in trying to avoid people who have confessed exactly what you just did.
Life is too short man. I don't have the time, energy, or desire to interact with such people.
So please avoid replying to my posts, as I will now stop responding to yours.
The ball was in your court man, and you blew it ...
Old Mar 12, 2008 | 02:26 PM
  #421
Edubs's Avatar
Please make sure I actually made a mistake before trying to point them out. You must have deleted the "R" when you were preparing your response. I have not made any false statements as of late. Once again, check your facts.
That's your agenda. You missed the fact that I was just giving you **** the second time around. If you can't handle it, that's perfectly fine. We'll avoid eachother from this point on. Have a nice life and be safe on the job...
Old Mar 12, 2008 | 02:29 PM
  #422
06black's Avatar
wow, friend fight via the interwebs on a dyno thread......
this has to be a first.
Old Mar 12, 2008 | 03:25 PM
  #423
Edubs's Avatar
Anything can happen on the shortbus...
Old Mar 12, 2008 | 03:33 PM
  #424
06black's Avatar
TUFTH!!!!
Old Mar 12, 2008 | 07:23 PM
  #425
Wee.
*SCHLAPP*
lol... No reason to be jelous just because I am better then you. lol.
I'm suprised that he even has time to respond- seeing as how he has a wife, I mean finance, and a life.
Back to topic now...
