New here and need some help
Old Mar 13, 2018 | 10:17 AM
pearljamfan's Avatar
I recently purchased a HHR SS. I am in the process of replacing the head gasket. Almost done but I have a ground wire that lost the tag I marked it with and I don't know where it should hook up to. It is in the area of the high pressure fuel pump. It could connect under the intake manifold as well.
The end of the wire connects to other ground wires in the front driver's side of the engine compartment.
BTW - tons of great information on this forum - I have gained knowledge from many posts.
I attached 3 photos showing the connections
1. showing a closeup of the connection I need to find a home for.
2. showing where the wire connects
3. the general location of the wire
Old Mar 13, 2018 | 10:31 AM
Kolt's Avatar
what year and ill get a ground location diagram, vin works best if you can get that
Old Mar 13, 2018 | 10:39 AM
It is a 2009 HHR
3GNCA63X59S500898
I do have a repair manual with wiring diagrams, I can certainly look through and see if I can find the connection. *slapping my head for not thinking of that*
Old Mar 13, 2018 | 10:48 AM
Kolt's Avatar
there is four grounds, looking to see if there is anymore, one under the alternator and another under the oil cooler on the trans. the two top right is by the fuse block
Old Mar 13, 2018 | 10:49 AM
Kolt's Avatar
heres one on the backside attached to the corner of the cyl head
Old Mar 13, 2018 | 10:51 AM
Kolt's Avatar
there is another view of the one under the cooler(#2) and alternator(#4).
Old Mar 13, 2018 | 10:53 AM
Kolt's Avatar
last one I can find that goes behind the left headlamp on the upper radiator support bar
Hope those help
Old Mar 13, 2018 | 11:41 AM
This image is perfect
My lost connection is #3
Many thanks
UnholyPsycho
Oct 30, 2014 04:43 PM
NWAE Cobalt
Feb 6, 2009 05:19 PM
65bus
24
Aug 6, 2008 04:44 PM
black05ss
Tuning
Aug 3, 2008 04:34 PM
SS RN
Dec 2, 2006 08:09 AM
