Need your help
Old Oct 11, 2019 | 02:17 PM
jdbaugh1's Avatar
I'd guess timing chain or valve-train. Might be worth popping the valve cover off and having a look
Old Oct 11, 2019 | 02:25 PM
Yeah might have to do that, I'll need to get a gasket first
Old Oct 11, 2019 | 02:27 PM
jdbaugh1's Avatar
As long as it doesn't rip and is still springy I reuse the valve cover gaskets all the time.
Old Oct 11, 2019 | 02:30 PM
I would rather have it just in case. Not sure if I could find one locally
Old Oct 11, 2019 | 02:43 PM
jdbaugh1's Avatar
Don't blame you there. Should be able to order one from your local parts store.
Old Oct 11, 2019 | 03:03 PM
Yup found one in advance auto so that should work. Thinking of getting the chain tensioner and if I needed then replace it then if I dont need it then I'll return it
Old Jul 18, 2020 | 06:46 PM
I guess I never updated this post and my vibration issue. It ended up being the balance shaft guide had broken. The noise was coming from the chain having slack and also the chain was rubbing against the tensioner
williamsunltd
Aug 22, 2010 10:33 AM
Unforgiv3n
Nov 28, 2009 05:14 PM
skidizzle105
Oct 12, 2008 01:02 AM
paulstookey
Mar 13, 2007 01:17 AM
jonnymerk
Aug 28, 2006 03:43 AM
