LDK build thread, version 2.0
Old Jun 21, 2017 | 06:18 PM
  #126
I wish you luck
Old Jun 24, 2017 | 01:01 AM
  #127
08VRSS's Avatar
Buttoning up the new clutch install tomorrow I'm tired. New clutch is in though and bled. Pedal is much stiffer, might be tough to slip. But feels like it doesn't engage at the top like all the old stage 3 did.
something went wrong with the 4+, it was not really making much contact on the one side of the disk, causing slipping and hot spots. I'd say pressure plate issue, otherwise it may have held just fine.
Old Jun 24, 2017 | 07:12 AM
  #128
That pressure plate looks bad. It also looks like the clutch disk was only making contact in the center. I'm glad you got it out of there, and hope the new one works well.
Old Jun 24, 2017 | 01:51 PM
  #129
Omiotek's Avatar
Seems to be on goimg quality issues with ky......
Old Jun 24, 2017 | 06:08 PM
  #130
08VRSS's Avatar
New frankencluth is done, easier than I thought to drive. Engages near the bottom of the pedal like stock so they fixed that weird pedal engagement that the stage 3 had. Time to break it in now and hope for the best.
Old Jun 24, 2017 | 06:13 PM
  #131
Good luck man!
Old Jun 24, 2017 | 07:48 PM
  #132
08VRSS's Avatar
Oh and I switched to a hallman rx evolution 😁. Cockpit adjustment ftw.
Old Jun 24, 2017 | 10:04 PM
  #133
No doubt I hear more bad about them than any other clutch. Hope the frankenclutch works great for you .
Old Jun 30, 2017 | 05:30 PM
  #134
08VRSS's Avatar
SO far so good. With 150ish miles on it. It drives just like a stage 3 does, engagement is perfect and low, feels like factory except much heavier pedal. It takes some getting used to with the heavy pedal but I've had worse in my T56 camaro way back when.
Engine is still running perfectly, put a turbo blanket on the hotside to minimize my wiring looms melting back near the firewall lol.
Old Jun 30, 2017 | 05:32 PM
  #135
Good idea. I will probably do the blanket at some point
Old Jun 30, 2017 | 05:33 PM
  #136
08VRSS's Avatar
Its a HUGE PITA to install, gotta do it from under the car. But I HIGHLY RECOMMEND getting one, it really cut down underhood temps.
Old Jul 17, 2017 | 11:45 AM
  #137
08VRSS's Avatar
About 700 miles on the new clutch, holds fine on high boost on 93. I'll switch over the e47 and see what happens next. It drives fine too very easy to daily drive.
Old Jul 17, 2017 | 12:13 PM
  #138
T-Man's Avatar
Happy to hear this is holding well for you. I finished the install of my replacement over the weekend and definitely agree, it's much easier to drive and I enjoy the heavier pedal.
Old Jul 17, 2017 | 01:37 PM
  #139
08VRSS's Avatar
It may get harsh on engagement in the first like 200 miles, after that it smooths right back out. I'm a happy camper. Did they set you up same setup as me?
Old Jul 17, 2017 | 05:57 PM
  #140
T-Man's Avatar
I haven't noticed the engagement getting more harsh but the pedal is definitely heavier.
Yeah, stage 5 PP and the 6 puck kevlar ceramic disc
Old Jul 17, 2017 | 08:59 PM
  #141
08VRSS's Avatar
Cool I think we have a winner. I beat the crap out of it today and no issues.
Old Jul 23, 2017 | 09:41 PM
  #142
08VRSS's Avatar
Still going strong. Hallman evo pro rx is also doing well, spool is very manageable, and part throttle full boost is non existent with a turbo this size. Very happy with everything. 93 tune is dialed in. Gotta switch over to e47.
Old Aug 7, 2017 | 10:48 AM
  #143
08VRSS's Avatar
Filled up last week on E47, the quality of the fuel at my station down the street from where i live is the best I've ever seen, E90 or above lol.
So far the tune is on 23* timing, and .87 lambda on a base boost of 25psi to start with the injection start angle tuned a bit earlier. Im making sure the fuel trims are settled in and the fueling is 100% before turning it up little by little to pay close attention to fuel pressure and injector DC and injector timing. I have the stage 2 cams and opels, I'm not sure how far that will take me on E47, hopefully up to 28-29psi, maybe, we'll see. The 5th injector is just there if i need it, but not active as of now.
Old Aug 7, 2017 | 06:32 PM
  #144
cw383's Avatar
I found a gas station that tested 90%, I was tickled. Then I tested some flex fuel from my local chain, which should test 51-83% and is labeled as such, but it also tested at 88%. It seems all I've been testing is up over prior years.
Old Aug 7, 2017 | 06:39 PM
  #145
I need to buy a tester
Old Aug 8, 2017 | 09:44 AM
  #146
umrdyldo's Avatar
We are also talking about summer gas which should be very high ethanol content. Winter is the bigger issue when it drops to the 50-75% range.
Old Aug 8, 2017 | 12:09 PM
  #147
cw383's Avatar
Yes, I checked my local station in Feb or March when they first started carrying the "Flex Fuel", note, it doesn't say E85, it tested at an even 70%. Even so being the mix is higher in summer, the 88% was a welcome surprise. I have an on board E tester also using a flex fuel sensor which is nice for keeping tabs on the status of the mix in my tank.
Old Aug 9, 2017 | 11:23 AM
  #148
08VRSS's Avatar
This car is nuts on E47. Targeting .88-.89 lambda on 17MPa fuel pressure (yes its holding so far thanks to cam fuel lobe) had to really work on injector timing table to get injector pulse width down for more headroom (6.5ms peak now) as well as bump fuel pressure a bit, but theres headroom now on 26psi, and theres still some wiggle room left in the tables for a bit more adjustment. Turning it up today a bit.
I want to see how far i can go without the 5th injector to basically see the limitations of the stage 2 cams with opels and AEM fuel pump.
Old Aug 9, 2017 | 05:32 PM
  #149
08VRSS's Avatar
Well since ZZP won't sell me just a fuel controller instead of the entire kit...........fine....
So for future bc I know I'm going to need the 5th injector eventually. Testing with my old style AEM meth controller, it actuates the deka 630cc injector just fine. It may not be an ideal pulse width but it works and I'm gonna try it out.
Going to tap into the MAF signal wire via ZZP's MAF extension harness and run it to the AEM controller in the cabin. 4000hz to 14000hz is plenty of adjustement, have it come in around 8500hz (15psi on my logs) and full around ~12000hz (max i've seen so far in my logs). This should make tuning it quite easy rather than relative pressure controllers (boost pressure).
So i bought this, gotta wait for Amazon now:
Old Aug 9, 2017 | 09:05 PM
  #150
Nice!
