New camaro killed
#76
fair enough. Oh and I had an 04 Notice the chromes the 03's came with the alluminum. I would have ran a 12.5 or so if I didn't miss 3rd on that one run with I got the 1.9 60ft. I just looked up a bunch of 5.0's in the 11's and they all got a 1.8 60ft or better. 114mph-117 or so. I guess I see where your coming from. warm those mickeys a little better next time Or did you say ET streets? Either way I miss RWD
imagine having the motor sing a 5k while you pop the clutch and it bogs. the car didn't spin an inch at all. it just needs 26" tires or 3.73s. Even so it will only go 11.5-11.6 with my car
#77
I think 3.73s will be your ticket. My cobra came stock with 3.55s and I would have gone 3.73s myself but I just couldn't justify the cost and only going up a little bit of gear. And 3.90s or 4.10s would have been too much IMHO for a FI v8 car.
#80
My 12 has
M6 with 3.31 gears
Boss manifold, 85mm tb, steeda boss air intake
lt's, orx, jpc over axle pipes, and gt500 mufflers
Evolution/Lund tune
aluminum driveshaft
best et on regular radials was 12.20 at 120.5. went 11.79 at 120.0 while bogging on 295/55 MT drag radials. The car picked up ALOT of power on the dyno about 6500rpm with the boss manifold setup and picked up close to 3mph at the track. I need to switch to 3.73s if i plan to keep on running the 295/55 drag radial.
M6 with 3.31 gears
Evolution/Lund tune
aluminum driveshaft
Tip for other 5.0 owners on my 13 my fog light and grill block 90% of the outside airflow to my intake snorkel. Removing my fog lights and grill seems to help my IATs stay a lot cooler when sitting and seems to keep the overall IATs much cooler than before and I venture to say that it will really help those with high flow intakes like you slowstang.
#81
Cooler weather is beautiful, dynod this past weekend, first pull was around 3pm at about 75-80 degrees out put down 430/397, did another pull at like 630 at about 60-65 degrees out and put down 434/407, I plan on gettin a different grill that moves/removes that fog light and allows more air flow, every little bit helps
#82
#88
I still need to trim the front bumper support bracket some as it obstructs the air being rammed strait into the duct but I have seen some small improvements in gas mileage at cruise (0.5-1.0 MPG average seen). Once I cut the inner bracket and all I expect some more improvement. Hopefully I get my SCT software soon. First performance mod will be an extremely aggressive E-85 tune!!!!.
#92
Yeah I cannot wait. E-85 is worth 30+ whp and 35+ wrtq throughout the whole curve over an agressive 93 octane tune (55 whp and 65 wrtq over stock). Going to hate the 25% fuel mileage decrease though being my DD but going to try to fight it by tuning VCT, Lean cruise (if I have the tables) and adding global spark.
E-85 vs 93 octane same spark advance, same PE lambda, same car, and the same dyno. This is a 2011 with LTs and CAI otherwise stock.
#96
Term - Love the green. I'm a red candy/sport red/strawberry fan as thats what my mustangs and cobalt are. I got a great deal on my 12 as the 13s were coming out. If I waited for the 13 it would be Gotta Have it Green for sure.
#97
Sick 5.0 term you and Derek should run-it and do a shoot.
#99
Thanks. I would have taken a 12 if they had one left over but I got a good deal on the 13. 32K sticker (base GT M6 with the $600 paint option) I got it for 27K plus tax, tag, etc. They had every color for me to choose from and I was torn between the green and the deep impact blue.
