08 SS/TC Custom Intake
Old Sep 9, 2008 | 11:41 PM
  #101
marcusicp's Avatar
Originally Posted by TruStinger
HAHA! But it included a cover so water doesnt get in!!! GENIUS!
Can any of the SS/SC intakes be made to fit on the SS/TC?
I would say no. The intake is on the other side on the SS/SC. However, it you really wanted to "make it work" then I am guessing that you could if you cut and weld it enough!
Old Sep 9, 2008 | 11:44 PM
  #102
TruStinger's Avatar
hmmm.....I got time. lol. Still saving up my DP for the SS. Figured I'll get one next summer. By that time I can almost pay cash for it. :-)
Old Sep 10, 2008 | 12:32 AM
  #103
PimpLay2's Avatar
Originally Posted by 07BlackSS/SC
Nice, but I bet your MAF is going crazy. I know mine was and I had to adjust it. I get my AEM Dryflow Filter tmw
that was my choice... between an &n or aem dryflow....i picked the k&n i will keep it on for a few days and read temps then try the aem and see which 1 has better logs
that ARC cone filter i had was terrible... i can hear the blow off even from 1st to 2nd now... wit that arc i only could hear it from 2nd to 3rd
Old Sep 10, 2008 | 12:46 AM
  #104
08BlackSS/TC's Avatar
I start hearing boost when I'm still in vacuum
I figured I would go with the AEM since it doesn't need to be oiled so I don't set off any codes
Old Sep 10, 2008 | 06:19 AM
  #105
choko's Avatar
through a p0497 code after intake. could be from nitrous but it came on 2 days after i sprayed.. but trying to pint point the code.
Old Sep 10, 2008 | 10:34 AM
  #106
krispy's Avatar
Choko, here is a description of the code and the conditions under which that code is set:
This DTC tests for proper intake manifold vacuum flow to the evaporative emission (EVAP) system
Conditions for Setting the DTC
• The control module detects weak vacuum during a purge condition.
• The fuel tank vacuum is less than -1 inches H2O for 4 seconds continuously or 50 seconds cumulative, within 10 minutes of cold start.
• The 11 second test can run up to 10 times within 10 minutes of cold start and must be completed before this DTC will set.
Old Sep 10, 2008 | 10:43 AM
  #107
SSpdDmon's Avatar
Sounds like a loose gas cap code to me.
Old Sep 10, 2008 | 10:57 AM
  #108
krispy's Avatar
any time I see fuel tank vaccum thats what I usually start thinking too
Old Sep 10, 2008 | 07:42 PM
  #109
supermantxz24's Avatar
Can i use a 4in tube and run it into 3in or is that too much air for the maf sensor ??? i cant find a 3in i only find 4in with little adapter tubes to make it 3in
Old Sep 10, 2008 | 09:47 PM
  #110
SynapseTurbo's Avatar
We made a intake similar to that and ran it all the way down behind the bumper area, but it made no difference on the dyno. We tried a couple different air filters and came up with no real usable gains. On a stock car, the airbox/intake is setup pretty darn good from the factory.
Old Sep 10, 2008 | 10:23 PM
  #111
Pretty much everything will have an effect on the MAF sensor. Nothing a tune wouldn't take care of tho
True. But it's definitely worth it for the sound over stock
I wonder if I can get a custom pipe made that will have 2 outlets from the intercooler, one going to the manifold and one for the intake . Any takers?
Old Sep 10, 2008 | 10:29 PM
  #112
marcusicp's Avatar
I don't understand what you mean by this.
Old Sep 10, 2008 | 10:32 PM
  #113
The pipe that is the one on the passenger side of the intercooler going into the manifold. Have a custom pipe made that will have 2 outlets, one for the manifold and one for the intake.
Old Sep 10, 2008 | 10:41 PM
  #114
marcusicp's Avatar
Why?
Old Sep 10, 2008 | 11:23 PM
  #115
Delta2.2's Avatar
...theres a logical reason for this... i'll let u know when i see u again. its typical. i hear it on my car too.
this makes NO logical sense. THINK REAL HARD
Old Sep 10, 2008 | 11:24 PM
  #116
I just wanted to mention that because PimpLay2 had said that he couldn't hear the turbo with his filter until he got a different filter
Old Sep 10, 2008 | 11:27 PM
  #117
JPizzle's Avatar
Soo basically your intake will be a "SRI", or Short Ram Intake? Pulling in air from the engine bay as opposed to behind the bumper?
Old Sep 10, 2008 | 11:36 PM
  #118
Delta2.2's Avatar
THIS MAKES NO SENSE
Old Sep 10, 2008 | 11:39 PM
  #119
TruStinger's Avatar
Another one of you guys with this "it pulls hot air from the engine bay" mentality. Check back a page or 2, we already covered this issue.
THIS MAKES NO SENSE
Agreed. That would totally mess up the airflow and just in general, doesnt make sense. lol
Last edited by TruStinger; Sep 10, 2008 at 11:41 PM. Reason: Automerged Doublepost
Old Sep 10, 2008 | 11:40 PM
  #120
PimpLay2's Avatar
i love the sound but i just dont like how its pulling air from engine bay.. i do have ss style hood so my engine bay is a little cooler then others.... i exented the pipe and its right by the stock intake hole right beside the fender...
i feel a little safer
Old Sep 10, 2008 | 11:42 PM
  #121
Delta2.2's Avatar
there is reasoning why it does not matter. but o well
Old Sep 10, 2008 | 11:44 PM
  #122
JPizzle's Avatar
1.) I have read every single post in this thread.
2.) I am NOT "another one of those guys with this 'it pulls hot air from the engine bay' mentality", because I have a SRI on my 2.4L Cobalt. I don't think the difference between the SRI & CAI affect performance that much anyways.
3.) I was asking TTR whether THEIR intake will be a SRI, or a CAI.
Old Sep 10, 2008 | 11:57 PM
  #123
Another one of these guys: (not you JPizzle)
Originally Posted by Tazmanian_Dvl
Sorry dude there's no way that air gettin sucked into the motor from right next to a 200 degree motor is 10 degrees colder than the air gettin sucked in from the fender outside the engine bay. I'm sorry there's just no way. The only reason I could come up with is that the big plastic air box trapped in all the heat from the motor. However I feel it's unlikely that you're really seeing that big of a differance. But whatever like I said in the previous post all you turbo guys think you're God's gift to cars and know every damn thing so whatever...
PLEASE STAY OUT OF THIS THREAD IF YOU THINK YOU'RE "GOD'S GIFT"
Old Sep 11, 2008 | 12:01 AM
  #124
FryLoch's Avatar
Looks cheap IMO, I wouldn't do something so cheesy to my car, certainly not a brand new car at that.
My custom intake
Old Sep 11, 2008 | 12:05 AM
  #125
Jn2's Avatar
Jn2
put a little more effor and it wouldnt look so cheap only looks cheap b/c of the air filter use, paint the piping black, use a AEm dry flow and i bet it will look alot nicer
ill be back with a pic of what i mean
