Treadstone Intercooler fitment question
It doesn't have to be mounted that low. It can be slid up a little when mounted.
i just intalled a treadstone intercooler the tr12 i dont have any instructions on what vacume line to put to the bov??? i used the one that came off the bypass, and tried the one off the cold pipe but both seem to hold the bov open under throttle idk y does anyone know the correct way can you send me a picture please thanks... i plan on calling treadstone tomorrow but i would like to solve it now
You can't use the line from the charge tube because it will never see vacuum which is required to open the valve. You have to use the port on the intake or the port on the solenoid used to control the factory bypass.
Matt did u start a thread on clubgp about your new build for the gp? If so post a link.
i tried the one that controlled the factory bypass but when i run on that on i can only boost at the most 10psi cause the bov stays open and leaks boost under throttle... what does the line that goes direct in the intake go to i was thinking of blocking that off and running the bov straight to that or putting a tee in there?
