Treadstone Intercooler fitment question
Old Dec 29, 2010 | 12:17 AM
  #51
Matt M's Avatar
Originally Posted by ronn
*ANGLE*
Come on now..that baby is hanging about an inch LOWER than stock..are ya tellin' me it's an optical illusion? I went out to my car and took a good hard look from ALL ANGLES before I made that post..just to make sure it wasn't just the angle of the pic.
It doesn't have to be mounted that low. It can be slid up a little when mounted.
Old Dec 30, 2010 | 10:17 AM
  #52
ralliartist's Avatar
my bad, I definitely missunderstood ryan. No big deal, the main goal was to stop the bashing.
Old Dec 30, 2010 | 12:16 PM
  #53
Matt M's Avatar
No biggie. He did ask me what the dimensions were on the Treadstone core that we had while he was on the phone with you, so I can see where the confusion would come from. That core is too big for a Cobalt without modding the front end. I run it on my Grand Prix, however. It makes a nice tool bench.
Old Dec 30, 2010 | 01:17 PM
  #54
LOL, I guess it does make a nice tool bench. haha.
Old Jan 9, 2011 | 11:41 PM
  #55
silver-ss/tc's Avatar
i just intalled a treadstone intercooler the tr12 i dont have any instructions on what vacume line to put to the bov??? i used the one that came off the bypass, and tried the one off the cold pipe but both seem to hold the bov open under throttle idk y does anyone know the correct way can you send me a picture please thanks... i plan on calling treadstone tomorrow but i would like to solve it now
Old Jan 10, 2011 | 12:07 AM
  #56
Matt M's Avatar
You can't use the line from the charge tube because it will never see vacuum which is required to open the valve. You have to use the port on the intake or the port on the solenoid used to control the factory bypass.
Old Jan 10, 2011 | 12:42 AM
  #57
NME's Avatar
NME
Matt did u start a thread on clubgp about your new build for the gp? If so post a link.
Old Jan 10, 2011 | 09:56 AM
  #58
Matt M's Avatar
Its in the TTGT Updates thread.
Old Jan 10, 2011 | 11:18 AM
  #59
i tried the one that controlled the factory bypass but when i run on that on i can only boost at the most 10psi cause the bov stays open and leaks boost under throttle... what does the line that goes direct in the intake go to i was thinking of blocking that off and running the bov straight to that or putting a tee in there?
Old Jan 10, 2011 | 11:25 AM
  #60
Matt M's Avatar
The line from the intake runs to a vacuum tank on the front of the motor. It is used as the vacuum source for the factory bypass so that it can still open the bypass while you are in boost if the ECM wants to intervene. On our turbo upgrade kits, we remove the vacuum tank and use the fitting on the intake for the BOV.
Old Jan 10, 2011 | 12:15 PM
  #61
RyRidesMotox's Avatar
Here is a link to when I installed my kit. ITs a TR8 but the charge pipes are set up the same. The vacuum line needs to be teed off. Then the line that ran to the lower CP needs to be "T"ed into the intake mani so it is hooked up to a boost source. As my sig says this setup for me is good for up to 24psi. I am running a BPV block off plate from treadstone as well. If you have anymore questions pm me.
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
