Unused input found on LNF ECM
Old Nov 21, 2009 | 11:35 PM
  #51
Matt M's Avatar
Originally Posted by tomj77
sure u can make boost in neutral, its called antilag. uses the same method gm uses to no lift shift. look em up on youtube and observe
http://www.youtube.com/watch?v=IAlWDLG1how
That's with the big turbo. On the stock turbo, it would hit 20psi as quick as I could get the pedal to the floor.
Originally Posted by VinceTrifecta
The way it would work is like this:
1. Start the car
2. While stationary, hold the engine RPM at what you want the launch RPM to be
3. Press the cruise control SET button, release the accelerator
4. This is now the programmed launch control setting
This sounds like a great way to adjust for track conditions without having to flash a new file to the ECM.
Old Nov 21, 2009 | 11:37 PM
  #52
JPizzle's Avatar
Wow. Good job Vince! Your really an asset to the LNF Community!
Old Nov 22, 2009 | 11:04 AM
  #53
Balento18's Avatar
all the hp all the time may not be the best for getting a tc out of the hole
X2. Just like removing Torque management from 1st gear. Nothing but wheelspin at anything above 50% throttle. Power is great but putting it down is the problem. 50% torque for me in 1st.
Well here is my problem. I go to the drag scene a lot (I only race at the track) and as many know the traction at the track is insane so I have found myself having to launch the car at 4.5k rpm without launch control because of this. So for track use TCS is not your best friend. I understand that for street use TCS is your best pal and I agree that the launch control used outside the track is a win but at the track it just does not work. BTW I did not know that our cars had limited torque in 1st gear!!! does pushing the traction control for 5 secs gets rid of this feature?
Old Nov 22, 2009 | 11:11 AM
  #54
Iam Broke's Avatar
Originally Posted by Balento18
snip...
No, but it is adjustable in the tune. 50% is still a bit much for mine on the street, I may try 45% next time I tweak the tune. 40% was too little.
I set it to 100% for a day just messing around, 1st was totally useless.
Stock is a tapered curve in 1st. Around 58%? I forget.
Old Nov 22, 2009 | 01:03 PM
  #55
mkriebs's Avatar
I set mine in the 70's at the track and seems to work well. I still get a ton of spin if I just flat foot it, but thats why there is a gas pedal instead of a gas switch.
Old Nov 22, 2009 | 01:21 PM
  #56
Iam Broke's Avatar
Yeah, I need a driver mod at times. Gas switch...
Old Dec 7, 2009 | 07:09 PM
  #57
kplaya186's Avatar
Hows this going Vince?
Old Dec 8, 2009 | 12:01 AM
  #58
Sevensix9's Avatar
Dude if we could get the ecu to run as a turbo time that would be slick
Old Dec 8, 2009 | 06:55 PM
  #59
pookie025's Avatar
omg that would be absolutly sick!!!!
Old Dec 8, 2009 | 07:32 PM
  #60
MaxVQ35DE's Avatar
vince, pushing the envelope..... Again..... You rock dude
Old Dec 8, 2009 | 07:44 PM
  #61
mkriebs's Avatar
Vince Rocks!
Can't wait to get my trifecta cable. I will have an order in first thing Thursday!
Old Dec 8, 2009 | 09:54 PM
  #62
austinss's Avatar
The turbo timer idea is brilliant, I'd love to see that.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
Builttss
Oct 4, 2015 10:21 AM
jimbofug007
Oct 2, 2015 12:06 PM
patooyee
Oct 1, 2015 01:07 PM
