Upgrade from GM coming soon!
I put down 13k. Makes your payments much nicer. You can never put down too much as long as you have it to put down. Itll just lessen the amount of interest youre gonna pay.
This is definitely good news, Im subscribed and keeping my fingers crossed that it comes out soon and the price is decent!!
Im still pretty new to turbos....but it seems like these cars have virtually no turbo-lag stock. Maybe its just me, but it seems like whenever I increase the throttle even slightly the boost is right there with me.
Cobalt............ No lag..........
yeah there isn't much lag, BUT its still much quick brake boosting
the lag is nothing terrible though, in a lot of cars without brake boosting, from a roll.....they are just absolutely terrible and it doesn't matter what rpm you are at, it takes forever for the turbo to spool
the cobalt will still put up a decent fight even without a brake boost
pretty much just holding up the e-brake and letting it down when you launch giving it a lil gas and letting out the clutch just enough to kind of "stage" the car if you will... some people do it differently but that's the way I do it
no, brake boosting is while rolling, slightly pressing the brake, while giving it throttle, thus maintaining your speed(say a 30 roll) and building boost, so that when you go WOT, you already have your turbo spooled
its essential in racing cars from a roll that will actually put up a fight
the thing is in our cars its not night and day of a difference, its noticeable(and much quicker building boost) but in cars like say an Evo or a WRX, if you DON'T brake boost, you are going to be getting walked by cars like a 3.5L Nissan Maxima(from a roll), lol
for example:
http://www.youtube.com/watch?v=iR8Oj4KykJQ
http://www.youtube.com/watch?v=nH_5n...eature=related
the second video is more informal
for example:
for example:
for example:
another way to do it... nice post man!!
When you brake boost a turbocharged automatic trans car you're not just spinning up a free revving engine in neutral but instead are trying to overpower the brakes on the drive wheels. Brakes are almost always stronger than the engine power so the engine ends up burning a lot of air and fuel as the engine is now under a heavy load trying to overpower them. That allows higher exhaust gas volume to drive the turbo and allow it to build boost without the car moving.
Downside to doing that is something has to "give" and in an automatic trans that would be the torque converter. All the engine's power instead of going to move the car is being transferred and placed on the torque converter if you're trying to do it from a stop and it's not much better if you do it while the car is moving. The torque converter (which is a fluid coupling device) has to slip excessively which creates a ton of heat in the trans fluid and heat is the number one killer of automatic transmissions. An occasional quick jab of the gas while on the brake might not be too bad but a heavily modified car putting down big torque numbers and extended boost braking will kill a trans very fast, even many that have internal upgrades and cooling modifications.
On a manual transmission car like our Cobalts you don't have a torque converter and instead have a clutch. In order to place a load on the engine you'd have to keep the car from moving while stopped. If you tried to use the parking brake it may hold the car from moving forward but if you let out the clutch while on the gas the front tires are going to light up and as soon as that happens there isn't that much load and therefore not much boost. You could also hold the brake down with the heal or left side of your right foot while giving the car some gas with that same foot while using your left foot to operate the clutch. Just like the torque converter, when you're restricting the drive wheel from moving (with the brakes), something has to give and that will be the clutch.
In the SS Turbo that's probably not a great idea. Do it wrong or even if you do it right it will build up a ton of heat which can cause the organic clutch lining material to glaze over and slip, permanently ruining the holding force of the clutch. It appears the stock clutch can take quite a bit of hard launches and the stock torque capacity of the engine but slip it too much and overheat it and that all goes out the window.
Now while you're on the move and the clutch is fully engaged and locking the flywheel to the input shaft on the trans you could slightly get on the brake pedal while continuing to give the car some gas. That will place more load on the engine as it will try to overpower the brakes and therefore produce a higher volume of exhaust flow to drive the turbo. This is still pretty hard on the driveline and if you have a weak clutch or do it too hard it may slip and effectively ruin any clamping force the clutch had left to offer.
In moderation while on the move and the clutch fully engaged it might be okay if you're careful but I personally wouldn't do it to my car. That and when you're already on the move the transient boost response of the stock turbo is great as-is on the SS Turbo. On another car with a giant aftermarket turbo it could definitely help get it spooled quicker but we really don't have that problem stock while on the move.
I would not believe him just because he works at a dlr. Just like Bush saying there are WMOD in IRAQ, when in fact there never was. Do research before believing everthing someone says, this why Bush got re-elected, because DUMB Americans believed everything that rolled off his lying tongue.
Do your homework first, especially today in this F**K'ed up country of ours .
I have relatives that have been in GM Engineering for 20 years and they say no such perfrormace package upgrades will be offered in the immediate future (next 3 years) till GM is back on terra'firma from a financial perspective.
Can you then explain why GM hardware and calibration numbers have been leeked?
you can't "brake boost" a manual car off the line without using the hand brake, and in a fwd car, unless you are running full blown slicks, you are wasting your time, as you will be turning 2.4 second or worse 60's...
I was highly skeptical too, but there is good evidence this is planned to become a reality.
I said that it would make sense if they were going to announce it there...pure speculation though...I have no idea when this will be officially announced...
