ZZP Builds The Best LNF Mod Ever!
Old Mar 17, 2011 | 10:39 PM
  #226
Omnigear's Avatar
Originally Posted by Matt M
I do not expect these to be ready by May. It's a big project.
Building the motor is not required for 450whp on this turbo.
how about the bolt on's?
Old Mar 18, 2011 | 12:27 AM
  #227
Matt M's Avatar
450 should be easy with intake, charge tube, intercooler, downpipe, and exhaust. Of course you will need a good tune.
Old Mar 18, 2011 | 12:36 AM
  #228
ronn's Avatar
What about drive train requirements...Axels..clutch..tranny?
Old Mar 18, 2011 | 12:37 AM
  #229
Omnigear's Avatar
a bare minimum list would be nice to go with said turbo ^_^
Old Mar 18, 2011 | 01:10 AM
  #230
09whteSSpssssh's Avatar
Originally Posted by cubaniche
Yeah, maxing out the stock turbo is real fun. Im sure stock internals LOVE that. Especially the piston rings. And how long do you think the stock turbo can handle that kind of abuse? Plus those numbers are with meth or E. We can achieve the same numbers safely and preserving the life of the turbo with the BNR offerings, without meth injection. To ppl like me, thats important man. Im not trying to stir trouble. Was just pointing out that BNR and ZZPs EFR shouldnt be compared, and you shouldnt belittle someone elses work.
@Matt: You or Zoomer posted in the BNR thread or some other thread that you guys tried the big wheel upgrade, back when BTF was doing this, and that it wasnt worth it because when you ported it to make the larger wheels fit the walls could become too thin and crack allowing coolant to leak into the turbo. I took that comment to mean that you guys tried it and considered it to be not worth it.
Aaaanyways, keep an eye on the BNR thread, you will see one of the 2871 guys post numbers along those lines.
Like I said, good work ZZP. I hope this turbo is out soon for all the people that are anxiously awaiting it now that you made it public.
Lets see ive been at 360 whp for 40k miles driven hard and tracked all of it, turbo and motor still running like a top!
Old Mar 18, 2011 | 01:17 AM
  #231
PrincessTurbo's Avatar
32k Beaten to **** , not going to exaggerate , sure I drive sensible but most on ramps see full boost etc LOL been tuned full bolt ons for 25k
I've got the feeling she would take 450 WHP all day long with a good tune and the right setup..
Biggest worries are probably the trans for me personally. I heard rumors of Sheppard working on something for us ...
Old Mar 18, 2011 | 01:40 AM
  #232
terry11's Avatar
Who is this sheppard? haha
Old Mar 18, 2011 | 01:41 AM
  #233
I agree, my transmissions on the other hand..................3rd one hasnt exploded yet!......yet
Old Mar 18, 2011 | 01:50 AM
  #234
Ok so I spelled it wrong is that what you are getting at dude ?
Sheptrans.com: Specializing in Performance Nissan GTR Transmissions, DSM Transmissions and EVO Transmissions
Old Mar 18, 2011 | 01:59 AM
  #235
AndrewSS/TC's Avatar
Mine broke and it's stock
Old Mar 18, 2011 | 02:27 AM
  #236
Driving habits have a lot to do with it not saying you are john forcing it but still..
This car can't be driven like a ford ranger ... I know thats what comes to mind while first getting used to it but you just can't
I've ridden with someone that has the same car as me and I was like Just different I guess..
Old Mar 18, 2011 | 08:44 AM
  #237
RooTBeeR's Avatar
lol put that turbo on bone stock car all the plastic charge pipes and intercooler wouldnt like it and obviously stock clutch has to go...it slips with just over 300whp(sadly)
Old Mar 18, 2011 | 09:08 AM
  #238
Matt M's Avatar
Yes, I should have added clutch. Obviously not to make power, but so it can actually get used.
Stock axles are fine.
The stock trans can live, but as said above, it's an aquired driving style.
Old Mar 18, 2011 | 09:16 AM
  #239
Ill admit the first trans was just a plain brain fart at the track.
Old Mar 18, 2011 | 09:34 AM
  #240
swazzees's Avatar
Originally Posted by Supercharged Guy
Pretty much
Although I would buy all the supporting mods
It wouldn't be a bad thing to build the motor....better to be safe then sorry
thanks for qwik reply.
my thoughts a little more in depth.............................
by the turbo
add it to the car, don't buy anything else unless it s a clutch and we can all understand that.
don't add anything else......
go see an amazing tuner
run a lower boost.........lets say 18 to 21 psi.
Im thinking there has to be a perfect effeciency range for this turbo and I would guess not @ 27 psi.......lol
but the lower boost would be easier on the stock parts like charge tubes for example......
does this sound normal??? like make 400 hp out of it without stress on the car because of the lower boost settings?
Old Mar 18, 2011 | 10:51 AM
  #241
gone_in_10_sec's Avatar
Matt - what about the stock valve springs - they should be replaced to ZZP 78#, to support this TC upgrade along with the rest of the ZZP supporting mods (Clutch, 3'' Exhaust, DP, Charge pipes, CAI & IC)?
Old Mar 18, 2011 | 11:11 AM
  #242
terry11's Avatar
No, I just wanted more info. I just ordered that trans with the quaife lsd and I would like to build it, but I can't find the tools anywhere, and nobody makes parts right now. At least get it all apart cryo everything and change the ring gear to the 4.45
Old Mar 18, 2011 | 11:21 AM
  #243
bogalusahondakiller's Avatar
wonder what us treadstone guys gotta do. hopefully not spend a arm and a leg on new parts to run this
  #244
Matt M's Avatar
We did a little over 400 at the wheels a couple years ago with the stock airbox, charge tubes, and intercooler. That was also when we had less ECM access and stock fuel pressure. 400 should be pretty easy with this turbo and minimal mods.
Valvesprings are not required to hit 400. This turbo spools soon enough to keep the shift points lower if you need to. Of course swapping the valvesprings allow you to turn up the boost and/or rev it out further.
Old Mar 18, 2011 | 12:37 PM
  #245
cmiller8006's Avatar
I have to see that to believe it. Its not a foreign manufacturer.
Old Mar 18, 2011 | 01:01 PM
  #246
cubaniche's Avatar
You must be confusing us with someone else. We didn't post that. There is no coolant in the exhaust housing or compressor cover, so that wouldn't even make sense.
Sorry man I meant the center housing. And thats cool, I may have gotten confused as you said.
Just dissregard all my previous comments lol
If this turbo was out now I most probably would have gotten your EFR rather than the BNR I just got, even though it would put me at more HP than I was aiming for
Shoot, I may get bored with this one, sell it, then get the EFR once its out lol
Old Mar 18, 2011 | 01:08 PM
  #247
elecblue06's Avatar
you got the 2871? maybe i'll take it off your hands for a discount lol
Old Mar 18, 2011 | 01:40 PM
  #248
cubaniche's Avatar
LOL Noooooo I got the 2860....I wanted to run a little more power and have better top end but I really didnt want to mess with the MAF relocate and having to get a BOV. In retrospect, I would have been better off with the 2871. Should have just sucked it up and done it
Old Mar 18, 2011 | 01:43 PM
  #249
elecblue06's Avatar
LOL Noooooo I got the 2860....I wanted to run a little more power and have better top end but I really didnt want to mess with the MAF relocate and having to get a BOV. In retrospect, I would have been better of with the 2871. Should have just sucked it up and done it
psh yea.. i have no urge to to do a slight upgrade.. i'm going for either this or 2871 depending on price
unless you're looking to lower that price considerably then maybe i'll take it off your hands lol
Old Mar 18, 2011 | 01:53 PM
  #250
cubaniche's Avatar
lol I dont think like most ppl when it comes to HP. I had a goal in mind and the 2860 fit in with that perfectly. But this EFR would have been perfect for me too since its got everything built in like the K04 does. I had been waiting for the BNR to be avail for some time and when my tax money came in I bought it with a quickness lol
Too bad we didnt know about what ZZP had planned or I would have waited quite honestly.
