ZZP Builds The Best LNF Mod Ever!
Old Mar 14, 2011 | 11:45 PM
  #176
PrincessTurbo's Avatar
Originally Posted by Matt M
The idea would be to have the turbo available by itself. This makes the upgrade path much more appealing. I'm running our off-the-shelf charge tubes, IC, downpipe, and catback as well as our silicone intake coupler with a modification.
425 on stock internals is completely fine.
Well have you checked your PM's lately
I'll bet you got more than one...
Old Mar 15, 2011 | 12:16 AM
  #177
Matt M's Avatar
Yes, I am very far behind right now.
Old Mar 15, 2011 | 12:22 AM
  #178
cmiller8006's Avatar
Matt are you using any of Vinces new fuel stuff or is this still the old stuff. I know you have the port fueler on there. Just trying to gauge where my car may be.
Old Mar 15, 2011 | 12:31 AM
  #179
Matt M's Avatar
I'm still on one of the older base files from over a year ago. I'm sure we could get some gains or at least tune easier with some of his new offerings.
Old Mar 15, 2011 | 12:34 AM
  #180
bobbyhill31286's Avatar
daaaaaaammmmnn! i want this
Old Mar 15, 2011 | 01:13 AM
  #181
ronn's Avatar
Spotted a mock up...
Old Mar 15, 2011 | 01:14 AM
  #182
DARIN616's Avatar
Old Mar 15, 2011 | 02:20 AM
  #183
ricky3000gt's Avatar
haha I 'm too lazy to read the other pages right now but as far as I understand, you're having trouble with high duty cycles and poor fuel delivery? When you bolted on the EFR on the LNF did you guys have stock injectors and fuel pump or did I skip too much. lol
Old Mar 15, 2011 | 03:37 AM
  #184
They are running a secondary fuel rail on it with stock fuel injectors from an LSJ or equivalent , then they swapped them out to try and get a little more from the Rail and a little less from the direct injectors.
From my understanding.
You can't go past 450 Wheel or so without the secondary fuel rail.
With the new fueling and e85 etc I wouldn't be surprised if they end up eliminating the need for another fuel rail and controller.
That would be optimal but that just means more time before release..
I wouldn't mind the secondary fuel rail if thats what it takes but ideally we would like to run just one..
Nothing like a ball of flames and fuel spraying all over ..... Unlikely but more with that kind of set up.
I wouldn't run a secondary fuel rail on my DD thats just me.
Old Mar 15, 2011 | 09:58 AM
  #185
on gas Matt made almost 500whp with the s252 without the second rail. It's just this e85 takes so much more fuel.
Old Mar 15, 2011 | 10:53 AM
  #186
gone_in_10_sec's Avatar
question is there any smaller injectors to the ones we have now, that would fit in the FI port?
2 smaller inj (2nd fuel rail) = 1 stock injector
or
1 small+1 medium size (2nd fuel rail) = 1 stock injector
Old Mar 15, 2011 | 11:11 AM
  #187
Matt M's Avatar
With a meth kit or a rigged up extra injector sprayer I could see the risk you are referring to. In the case of our second fuel rail, it is an oem rail with oem connection and oem injectors. There is no reason to have any increased risk of that sort of thing going wrong.
Old Mar 15, 2011 | 11:14 AM
  #188
rallycobalt06's Avatar
Matt M............................. any idea on price?
Old Mar 15, 2011 | 11:16 AM
  #189
09cobaltSS's Avatar
I think this should be the map for the turbo they are using or very close. EFR-6758
Old Mar 15, 2011 | 11:21 AM
  #190
BYT*SS*TURBO's Avatar
Curious if that's a new exhaust housing or a cut/weld job with a stock turbo?
  #191
Matt M's Avatar
I'm not sure what you are asking. We didn't really have trouble with anything. The project surpassed our expectations with ease. the only issue I ran into was only having about 10 minutes to tune in the 60s and make a couple dyno pulls before I had to leave.
On the DI only, we can get close to 500whp on gas at 2900psi.(leaned out on race gas) or around 460 on pump gas running a little richer. With Trifecta's new injector timing tables, that number should be increased even higher. That is more than enough for most people. The problem comes in when people want to switch to E85. The amount of fuel required increases substantially which decreases the max HP potential to around 350. While this is a reasonable power level for the stock turbo, it leads us to another issue. The stock turbo operates in a lower RPM band than turbo swap setups. Because of this, the mechanical fuel pump is not always operating at a high enough speed to keep up with fuel delivery demands. Our secondary fueler solves the low RPM fuel starvation issue as well as the DI injector limitation issue at the same time. We just need to set it up specifically for the injectors that are being used.
Old Mar 15, 2011 | 11:45 AM
  #192
DiabeticKripple's Avatar
I don't know if anyone saw the first post, but he did another dyno on it and got 540 whp...... HOLY ****!!!!
Old Mar 15, 2011 | 01:11 PM
  #193
M-Dub's Avatar
I was able to get to 455 with pump 93 and meth... But I didn't feel safe that way so I backed it down before I sold that kit...
My new setup is good to well over 500 but I need to fueling guess it's time to hit up Trifecta and get that part....
Old Mar 15, 2011 | 01:41 PM
  #194
newt's Avatar
Originally Posted by D-mac
Id love to post some findings if ZZP would sell me one
Dude we talked about this...lol
ZZP: You guys have a compressor map for this turbo? I would like to see the efficiency range (it looks kinda small to be pushing near 600whp).
Old Mar 15, 2011 | 05:39 PM
  #195
blk06ss/sc's Avatar
so for us who have supporting mods allready piping intake exhaust etc etc, it really just comes down to what couplers are being used on our current parts for the turbo to simply bolt on?
and also, if your running a BOV with MAF relocate, and block off plate, could you block off the BPV on this new turbo and continue to run it with the BOV?
Old Mar 15, 2011 | 05:47 PM
  #196
09BlueBaltSS's Avatar
See post #189
Old Mar 15, 2011 | 06:07 PM
  #197
Matt M's Avatar
Yes. I am using our silicone couplers that we sell. I am also running the block off tube in the bypass because I already have the TiAL BOV.
Old Mar 15, 2011 | 06:12 PM
  #198
Matt M's Avatar
Remember that a lot of the power comes from direct injection and E85 as well as being a very efficient turbo.
Old Mar 15, 2011 | 06:15 PM
  #199
chris88z24's Avatar
**** GM for initially using a blower on a 4cyl car.
Old Mar 15, 2011 | 06:22 PM
  #200
blk06ss/sc's Avatar
so i would imagine just some new tuning and bolting that thing up there is all thats needed
sign me up ... really
