ZZP Builds The Best LNF Mod Ever!
Old Mar 28, 2011 | 12:22 PM
  #426
soundjunky's Avatar
Originally Posted by FF_ace
i know i remember when people were saying we will be lucky to break 300whp on stock turbo
that's pretty lame...
I never doubted this - now 300(ish) whp is a "tune only" option for those willing to chance it...
I always figured that if the N-SRT4's were pushing 500hp, that we would be up there in no time flat - assuming we had some aftermarket support.
Old Mar 28, 2011 | 12:28 PM
  #427
FF_ace's Avatar
this was in july of 07 when i bought my LNF this talk was going on, since then weve had a lot more support
Old Mar 28, 2011 | 01:20 PM
  #428
blk06ss/sc's Avatar
im sure this was answered allready i just don't feel like looking, any aftermarket DP will bolt to this correct ?
Old Mar 28, 2011 | 01:26 PM
  #429
cmiller8006's Avatar
It uses the factory O2 housing so yes any lnf dp will fit. But from What I have seen ZZP's fits the best anyway so why use a different company.
Old Mar 28, 2011 | 01:28 PM
  #430
Matt M's Avatar
Yes, this turbo still uses the factory o2 housing.
Old Mar 28, 2011 | 01:34 PM
  #431
rallycobalt06's Avatar
price?
Old Mar 28, 2011 | 01:46 PM
  #432
blk06ss/sc's Avatar
if i had a zzp DP i'd use that but i have CIA so im gonna use that thats all
Old Mar 28, 2011 | 01:51 PM
  #433
It will work fine.
Old Mar 28, 2011 | 01:53 PM
  #434
blk06ss/sc's Avatar
gracias
Old Mar 28, 2011 | 02:22 PM
  #435
Stamina's Avatar
Stumbled across this:
EFR 6758 diagram
Also, looks like word on this is getting around on other forums too..
http://www.honda-tech.com/showpost.php?p=44944586
Something I was wondering was: (In theory) If I already have a 6758, then how much would the exhaust housing that bolts up to our manifold go for?
Old Mar 28, 2011 | 03:40 PM
  #436
ronn's Avatar
Originally Posted by hunter19707
Not bulletproof, some LNF owners have blown their tranny's.
This
The tranny is rated at 260 Ft lbs (Flywheel)...yes..there's a safety margin, but like the tibit I quoted from the article above, you don't wanna go over 50% of the rated torque, which would be 390 Ft lbs FLYWHEEL..or roughly 360 to the wheels. Maybe that guy with the Focus drove it like a little ol lady?
Old Mar 28, 2011 | 03:42 PM
  #437
ronn's Avatar
Originally Posted by Stamina
Actually, I remember GM "magically" re-rating the tranny when GMS1 came out, so it may not be rated at 260 ft-lbs anymore.
Not saying it'd make much of a difference, but it may raise the rated+safety margin number, considering GMS1 makes like 340 ft-lbs at the crank on paper I think it was.
GM1 makes 320 Ft lbs at the FLYWHEEL...that's roughly 300 to the wheels.
Old Mar 28, 2011 | 04:25 PM
  #438
soundjunky's Avatar
Originally Posted by ronn
This
The tranny is rated at 260 Ft lbs (Flywheel)...yes..there's a safety margin, ...
actually 260ft/lbs was the torque rating before GM released the stage1;
if you missed it, GM quietly upped the torque rating of the transmission the same time they released the kit to 320ft/lbs... now, how much of a saftey rating they have above the 320ft/lbs... who really knows.
We all know there is a saftey margin that manufactureers always have;
I have read of several cars running the older Getrag-282 in a GM car with a V8 ~ which undoubtedly has far exceeded the 282's torque rating (which iirc was 200ft/lbs)...
Old Mar 28, 2011 | 06:12 PM
  #439
ronn's Avatar
"GM quietly upped the torque rating of the transmission the same time they released the kit to 320ft/lbs"
Sure..to accomodate the tranny under warranty and that falls well within the *plus 50%
limitation* originally at 360 Ft lbs to the wheels. Doesn't change that upper limtation at least in my mind. You KNOW 400 ft lbs is testing the very upper limits...this isn't rocket science here. I guess it boils down to what ZZP said...some (*enthusiasts*) don't care and will test the limits .."that's what they do" .
Old Mar 28, 2011 | 06:15 PM
  #440
soundjunky's Avatar
so you really think there's only a 50% margin?
I would have guessed about double that...
Old Mar 28, 2011 | 06:17 PM
  #441
BLAZIN07SS's Avatar
I'm too JDM for you
why are you wasting so much energy on this? if you want to stay stock to save your transmission, go ahead
Old Mar 28, 2011 | 06:23 PM
  #442
Fastgti69's Avatar
Honda-Tech - View Single Post - Borg Warner EFR turbos
Yes It's good info for all who are enthusiasts. I have started a thread in the BMW community as well. A little taste of SS potential
That's why I would like to get some verified 60-130mph vbox runs to put up on this list.. It has awesome potential and will impress all! BimmerBoost
Old Mar 28, 2011 | 06:24 PM
  #443
ctn2mb's Avatar
Also has alot to do with driving habits... if you have say... 440 ft tq... and you NLS and launch hard and goto the track everyday, yeah something will happen. But for the daily once maybe twice street run. It should be fine depending on how you drive I suppose, I've had mine tuned for over 50k miles and have yet to have a issue being fully bolted and 23 psi, but then again my clutch starting slipping around 50k~
Old Mar 28, 2011 | 06:30 PM
  #444
soundjunky's Avatar
and what pray-tell, is wrong with this line of discussion?
Old Mar 28, 2011 | 06:33 PM
  #445
BLAZIN07SS's Avatar
I'm too JDM for you
because this thread is about zzp's testing of efr based turbo's and not the transmission strength?
Old Mar 28, 2011 | 06:47 PM
  #446
soundjunky's Avatar
ok, fair enough, I thought you were nitpicking at the reason behind talking, not the fact that we had gone off topic.... which is why I originally came here anyway.
I too am curious to see what pricing will look like.
Old Mar 28, 2011 | 06:52 PM
  #447
MTE's Avatar
MTE
Is cause people keep trying to power shift or break boost this tranny, makes no sense on a car with 0 Turbo lag.
I'd rather say it's not "driver-proof"
This.
Old Mar 28, 2011 | 06:56 PM
  #448
MTE's Avatar
MTE
Back to topic. I'm exited to hear about this and more anxious to install it and keep it at 17 psi till the car its paid for.
Old Mar 28, 2011 | 07:23 PM
  #449
donkeyballs's Avatar
X2... I'm sick of reading that ****! he needs to go make his own thread on it. I know i want more power and if i have to get a tranny i will "YOU HAVE TO PAY TO PLAY"
Old Mar 28, 2011 | 07:36 PM
  #450
ronn's Avatar
That's what I said!
..Ok...why get pissed off? Ya think I'm raining on ya'alls parade?
OK..no more posts on this tranny thing. I'm done.
