ZZP Builds The Best LNF Mod Ever!
Old Apr 16, 2011 | 12:58 AM
  #501
gone_in_10_sec's Avatar
i can see it now, some sick f - would pull out the LNF and drop a LSJ..
Originally Posted by Sweetsandman
When you get up into that kind of horsepower. It doesn't come down to modability...it comes down to how much coin you can spend.
i remember the shop professor said - for every 100 HP jump = around $1000 - $3000.. LNF?> 900HP = $9000 - $27000
Old Apr 20, 2011 | 11:34 AM
  #502
SOHC24powa's Avatar
any updates yet?
Old Apr 20, 2011 | 11:58 AM
  #503
Sweetsandman's Avatar
Originally Posted by SOHC24powa
any updates yet?
I wouldn't expect anything until mid-late may...they've got an LE5 to blow up J/k
Old Apr 20, 2011 | 09:39 PM
  #504
austinss's Avatar
I'm so damn ready for this!! Just found out I've got the funds too. Good work ZZP!
Old Apr 20, 2011 | 09:41 PM
  #505
whyyoumadson?'s Avatar
whos doing the casting? borg and warner?
Old Apr 20, 2011 | 10:25 PM
  #506
terry11's Avatar
Yeah prob one of those two
Old Apr 20, 2011 | 10:31 PM
  #507
im just curious because if they arent how the warrenty on the turbos going to be applied with an aftermarket casted housing.
Old Apr 20, 2011 | 11:07 PM
  #508
Matt M's Avatar
We have this worked out with the manufacturers.
Old Apr 20, 2011 | 11:13 PM
  #509
just something that i though was a valid point. good to know.
Old Apr 21, 2011 | 01:34 AM
  #510
weezymagic's Avatar
Not if 900hp is your end goal. Then its only a ~600 HP jump. So 6000 -18000
Never the less, its almost not worth it....almost
Old Apr 22, 2011 | 12:10 PM
  #511
Ronn2005's Avatar
Back to the trans issue. If your doing road racing, or roll racing, do you need to worry about braking the trans?
I dont race, but I want to. Im guessing the hardest thing on the trans is Dragracing on Slicks? Basically whats the driving mistake that people ususally make and brake their trans?
Old Apr 22, 2011 | 12:43 PM
  #512
blackbird's Avatar
Slicks can sometimes be easier on a transaxle because the softer sidewall doesn't induce axle hop nearly as much as a street tire, but if you've also upgraded the clutch and are now doing aggressive clutch dumps to take advantage of the slicks that could introduce other different types of failures. You're probably not going to get a clear-cut answer on what torque level you'll have issues as there are too many factors such as the onset and ramp-up of that torque, the tires and traction available, the road or track surface, and a big part in how you drive the car.
Some people could abuse their car and have a trans failure at not much over stock power levels but someone else who is careful might have it last a very long time at mid-400 whp and similar torque levels. You have to pay to play and it is a risk you'll take. My driving style I personally wouldn't feel too uncomfortable into the lower or mid 400 whp range but not everyone will have the same suspension and driving style. Worst case is expect there could be a failure and if it does fail upgrade the next weakest link, turn the power down, or modify your driving style if that happens in order to reduce the chance it will happen again.
Old Apr 22, 2011 | 08:40 PM
  #513
terry11's Avatar
I've broken 3 transmission on the street. If you start making power 3rd gear will not like you. Take a look at my trans thread i just started tho.
Old Apr 22, 2011 | 11:37 PM
  #514
Last month - drove a private 1100HP FWD drag car - it was really fun.. to me worth it..
Old Apr 23, 2011 | 02:27 PM
  #515
PrincessTurbo's Avatar
Really , so these will be more or less private or ZZP warranties.
SO what you are doing is getting them casted for our manifold ?
You aren't just ordering a pallet from BW with your specs?
Last time I checked they would make one with your selected casting but you have to order so many of them ..
SO you just made your own adapter for the one you tested to see what it would do and after the results you are ordering the real deals ?
Still don't understand how you have one EFR thats casted and not any more following it.
Old Apr 23, 2011 | 05:45 PM
  #516
09BlueBaltSS's Avatar
Im taking it that ZZP is doing the prototyping and once the specs are correct BW will do the casting which would make it OE quality
Old Apr 24, 2011 | 10:01 AM
  #517
Kyle4236's Avatar
Im sooooooo readdyyyyyyy
Old Apr 24, 2011 | 08:59 PM
  #518
Supercharged Guy's Avatar
You and 50 others
Old Apr 24, 2011 | 11:17 PM
  #519
Matt M's Avatar
We already handle our turbo warranties. This won't be any different.
Yes, we designed our own exhaust manifold to utilized the EFR center section and mount to the LNF manifold and downpipe. The final version exhaust housing that is in the works will allow us to offer other turbo choices as well. We will have 2 EFR sizes available, plus s252, 256, and 259 extended tip options all as bolt-on turbos.
Old Apr 24, 2011 | 11:32 PM
  #520
The s252, 256, and the 259 as bolt on apps....gotta love that!
I'm liking were this is going soo far....besides the wait ofcourse
Old Apr 24, 2011 | 11:36 PM
  #521
But will require external bov Id assume. Are you going to keep with the internal w/g on those?
Old Apr 25, 2011 | 12:12 AM
  #522
Matt M's Avatar
They will require an external bypass or bov. External wastegate will be optional.
Old Apr 25, 2011 | 12:20 AM
  #523
elecblue06's Avatar
well **** ***** man thats terrible .. if there are all those options for bolt ons **** i might be going a bigger build then i thought
Old Apr 25, 2011 | 12:40 AM
  #524
Actually simplifies things. Unless your looking for 450hp+. By this winter there are going to be quite few 400+whp LNF's(ME)
Old Apr 25, 2011 | 01:00 AM
  #525
Ok I am giggling again , this should be pretty sweet , it will be like the motor is a Universal turbo tester LOL
siiick
