ZZP Builds The Best LNF Mod Ever!
LOL why don't you make the Injectors for us ..
They don't exist, the current ones will flow more with more rail pressure ..
Someones working on a bored out LNF pump rebuild kit right now but the problem is with boring the strength of the bored out hole it will crack after getting hot ...
They worked around this by in a sense sleeving the new bore ad using a thicker case and using a Teflon type material ring around the new plunger to prevent friction.
Don't really have any more info for you right now.
The shop that is doing it has done similar applications and are just waiting on a few small pieces they think will make it even easier..
10 KSI what ever that means should be the minimum to expect .. He said it's around 10000 PSI ..
Should be enough for what we are doing..
Unfortunately I don't think these rails can withstand that.
They have a shop thats won the Global Machinist Award for 6 straight consecutive years out of Denver who claims they have pumps for other application that have been reworked to do double the flow rate ..
by increasing the "feed" tubes and adding a larger piston it should flow quit nicely.
Yes they have
or possibly a second stock injection pump feeding the rail (its a common rail system right?)
Well the way I see it we have one of 2 options.
Just run the ZZP rail..
Or rig the plungers in the stock and run larger lines
holy **** it took me like 2 hours to read this whole damn thread, and for about the first 18 pages i was trying to figure out what EFR turbo its based on, till I guessed ( and noticed others) are saying it is based of the 6758...
is this correct?
Edit: lots of that reading time was wasted on the "I want" or "When is this coming out" - bout 50% of the thread hah.
is this correct?
Two pumps feeding the rail would solve the flow issue, but might be difficult to regulate. I'm sure it could be done, though.
is this correct?
is this correct?
Sounds like they got a great product then.
Yes, I would recommend the 6258 for road course cars and the 6758 for street/strip.
The 6258 will still get you over 400whp and will be very smooth with no lag and it won't run out of steam on the top end. The 6758 doesn't have much lag its spooling good at 2500rpm but you still need to be at 3500 to 4000rpm to get it cranking good. I don't road course race but i think the 6758 would be too much turbo and would have to lower boost or be light on the throttle cause you will be smoking the **** out of the tires
But your RWD so you would probably be ok with it
just my opinion..
Guess we will find out BYT is starting my install in a few weeks with the 6758. Its gonna be interesting when its done for sure.
If you like the stock turbo feel, you can only like the 6758 even more. You won't notice much of a spool change if any, but it can support 150 more HP than the k04.
