574's TVS mini build
Old Apr 21, 2013 | 01:22 PM
  #1126
Tjolley's Avatar
Looks like the piston froze in the bore and the rod said **** u..lol
Old Apr 21, 2013 | 02:55 PM
  #1127
574's Avatar
574
Cloyes 9-4201S Multi-Piece Timing Kit : Amazon.com : Automotive Cloyes 9-4201S Multi-Piece Timing Kit : Amazon.com : Automotive
Thoughts on this? I'm thinking of getting this and just go to the hardware store and get new guide bolts like c130 did
Old Apr 21, 2013 | 03:19 PM
  #1128
mrbelvedere's Avatar
get the **** from c.e.d. it will save you in the long run
Old Apr 21, 2013 | 04:22 PM
  #1129
Powell Race Parts's Avatar
Yup The Cloyes stuff is okay but there are little parts that may not be in the kit, which the GM one has. Also the one Cloyes kit has the old style tensioner, so thats a non starter.
Old Apr 21, 2013 | 05:09 PM
  #1130
c130aviator's Avatar
Originally Posted by 574
Engine is out MF'ers! pulled it by myself...
SO, thats only the first step pansy. I pulled it, rebuilt completely by myself, reinstalled tranny and motor with no help whatsoever, twice cause I forgot the trannsmission spacer between the block and the tranny.
Just playin' you are bout to embark on one of the most fun and worrisome experiences of your life. Yours may not be as stressful if you arent married with kids, my family life suffered because of the many hours in the garage. I am lucky to have a supportive wife but still felt guilty because of all the time it was taking.
Anyway go with Genuine AC delco/GM stuff and do the timing components fresh, with a break like that your timing components stand the chance of bending, stretching, etc. I got away with just bolts and a tensioner in the timing area because my popped motor was just a sleeve. With something that catastrophic do everything new. Man I am excited for you.
Old Apr 21, 2013 | 07:26 PM
  #1131
IonNinja's Avatar
I have the Cloyes timing chain guides and chain, quality is OEM-like
Old Apr 21, 2013 | 07:33 PM
  #1132
574's Avatar
574
lol thanks, I know you gotta pay to play but I can't help to be a little upset still
Old Apr 21, 2013 | 08:02 PM
  #1133
the ones ive seen have the new style
Old Apr 23, 2013 | 12:57 PM
  #1134
574's Avatar
574
Build list so far:
zzp gen 1 block
zzp rods
Possibly a set of diamonds from someone, not saying beacuse I don't want anyone stealing them
Complete timing set
Bearings
Do I need front/rear main gaskets?
Old Apr 23, 2013 | 02:04 PM
  #1135
advise's Avatar
Build list so far:
zzp gen 1 block
zzp rods
Complete timing set
Bearings
I'd change the front and rear main especially the rear main, also get your head deck checked
Old Apr 23, 2013 | 03:09 PM
  #1136
you need to have the bores checked before you get pistons if the bore is shot you will be pissing your money in the wind
Old Apr 23, 2013 | 03:10 PM
  #1137
you only have 1 main seal and its the rear main seal the front is a timing cover seal
Old Apr 23, 2013 | 06:43 PM
  #1138
Get seals for both sides of the crank, CED shipped me the wrong part but overnighted my main seal because they are awesome. Also take note of how the seal is in the block, if you put it in backwards, under boost the car will pee oil between the engine and transmission. Ask me how I know this.
OK, onto your PM. ASK AND YOU SHALL RECEIVE. I used 3 inch bolts and the threads I am not sure about, I just took a tranny bolt to lowes and bought the bolts and nuts for that size. Notice below that you will need two nuts for the other holes on the block that are not threaded. They were (2)3 and (2)4 inch bolts of the same thread size. But only buy two nuts.
Heres the pics you asked for.
Old Apr 23, 2013 | 07:27 PM
  #1139
574's Avatar
574
Your the man! First of many questions to come, thanks for all the pictures
Old Apr 23, 2013 | 07:41 PM
  #1140
ThexGovenor's Avatar
why the gen 1 block over the gen 3? price?
Old Apr 23, 2013 | 07:44 PM
  #1141
Tjolley's Avatar
The gen1 will be plenty strong..
Old Apr 23, 2013 | 07:48 PM
  #1142
hey i just took a look at the bolts I bought for the stand, two are 3", and two are 4", they are all the same threads but the longer bolts you see in the 6th picture down (exposed crank pic) is the 4" bolt with the nuts on there. Also pick up 4 washers for the engine stand so teh bolts sit level in the stand mounts. Some engine stands are different so make sure you measure the engine stand hole depth for the mounts so you have plenty of bolt to work with. But I think you will be fine with 2-3", and 2-4" bolts.
Old Apr 23, 2013 | 07:50 PM
  #1143
i would put my gen 1 open deck block with the cromoly sleeves (pm mrbelvedere if anyone wants a set) against any stock gen 3 block. Hondas have a similar open deck design and they are making power to 600 on them all day. Look at the top of my sleeves in the pics, its a couple thousand thicker than a stock bore due to the loose fitting size of diamond pistons. My sleeves were bored to the piston, not the piston sized to the bore. Getting the pistons with rings installed into the cylinders was freaking TIGHT. So my tolerances and high compression test show that they are a perfect match.
Old Apr 23, 2013 | 08:08 PM
  #1144
574's Avatar
574
Found a deal I could not pass on
Old Apr 23, 2013 | 08:35 PM
  #1145
574's Avatar
574
C130, is that engine stand from harbor freight? Haha looks just like the one I picked up!
Old Apr 23, 2013 | 09:18 PM
  #1146
i think so, i borrowed it from my local cable internet provider installer. Long story.
Old Apr 23, 2013 | 09:27 PM
  #1147
574's Avatar
574
Haha nice of Larry to loan you that
Old Apr 23, 2013 | 10:20 PM
  #1148
^lol
Old May 2, 2013 | 11:38 AM
  #1149
574's Avatar
574
I'll have better pictures when I get home...
There are four rods the other one wasn't found at the time of these pictures. Does the middle one looked fucked up to anyone?
Old May 2, 2013 | 12:09 PM
  #1150
advise's Avatar
Looks over heated
