GM Racing Exhaust Ported Cylinder Head
Old Nov 26, 2013 | 11:15 PM
  #226
Tjolley's Avatar
Air lift is wat i use.
Works perfict every time never have to add coolant after it dose its job.
Works on the IC system. One time bleeding.
Can't have air pockets if there isn't any air in the first place.
Old Nov 26, 2013 | 11:19 PM
  #227
05RLS2's Avatar
lol. the easiest way to fill an Ecotec cooling system is to do it by the GM book.
how is that? easy. Remove the top hose at the cylinder head andpour in coolant and fill the radiator. Then fill the reservoir. You can do it reservoir first then top hose if you want. This way the waterpump doesnt have to deal with trying to work without fluid. It cant pump if it doesnt have anything to circulate, and all the folks that cant fill an ecotec without massive air locks either dont have a workshop manual or cant read.
That's the way I have always done it, and never had any problems trying to remove air pockets afterwards
Old Nov 26, 2013 | 11:42 PM
  #228
Powell Race Parts's Avatar
AIRLIFT doesnt always work well with an ecotec. We use that very useful tool here a lot. But ecotec has an issue and its where the waterpump is located, and the capacity of the air lift tool. if there is not enough capacity in the air lift tool then its an issue as attempting to renew the vacuum with coolant in the system doesnt work.
The ic system stock on a cobalt does not have an air bleed like a conventional cooling system, unless its upgraded to option B. So for the stock lsj system there is no such thing as one time bleeding, the air entrainment from the pump in the system keeps it happening.
whatever
Old Nov 27, 2013 | 12:52 AM
  #229
Tjolley's Avatar
I use it on every Ecotec i work on and never had a problem. My ic system is always full. After using the air lift I've never had to coolant in the 2 years since i built the engine.
Old Nov 27, 2013 | 07:09 AM
  #230
Staged07SS's Avatar
Administrator
Administrator
Getting out of work early today for the Holiday.
I will be using that free time to swap the cams and springs from my stock head to the GMR, and hopefully have her bolted on by today.
Old Nov 27, 2013 | 07:29 AM
  #231
Yay!
Old Nov 27, 2013 | 10:30 AM
  #232
InfraRedline's Avatar
Just make sure that when you think the block and head surfaces are clean, clean them one more time lol.
When filling coolant I pretty much follow the same procedure Powell posted, but I like to take the bendy funnel and fill the port in the head where the upper radiator hose goes in as well. Makes it even that much quicker.
Old Nov 27, 2013 | 10:36 AM
  #233
Staged07SS's Avatar
Administrator
Administrator
I cleaned the hell out of the block. Went over it 5 times (scotch brite pads ftw). The head is brand new & spotless.
Just checked it again yesterday, and will prob check one more time before the head goes on, lol.
Thanks for the tips about filling the coolant.
Old Nov 27, 2013 | 10:49 AM
  #234
After the scotch bright did you use something to clean the surface of the block to get rid of all the dust left behind from the pads? I wiped mine off a few times, then when I thought it was clean I took some brake clean and sprayed it into a clean rag and went over the surface. The rag was pretty dark after a few passes over the block surface. Also, make sure before you fill the oil to pull the drain plug again to let all the coolant out that probably seeped down into the pan when you pulled the head. Could use a quart or so of oil (or old still clean oil) to flush through the system to get any remaining coolant out.
Old Nov 27, 2013 | 10:55 AM
  #235
Staged07SS's Avatar
Administrator
Administrator
Yup, wiped it down with throttle body cleaner (multiple times). I'm very ****.
I'm going to check the oil level (will drain some out like you mention), add to it, and once I get her timed start her to make sure all is ok.
Then I'll completely drain the oil and add new oil and a filter.
Old Nov 27, 2013 | 02:26 PM
  #236
mrbelvedere's Avatar
**** the level just drain it and be done
Old Nov 27, 2013 | 05:25 PM
  #237
DRAIN ALL THE OIL ALL OF IT. ALL. OF. IT.
ITS GOT COOLANT IN IT.
got it?
ya.
good
Old Nov 27, 2013 | 05:40 PM
  #238
watch out the master of all things has spoken lol
Old Nov 27, 2013 | 05:47 PM
  #239
TStone's Avatar
lmfao
Old Nov 29, 2013 | 03:49 PM
  #240
advise's Avatar
Updates staged?
Old Nov 29, 2013 | 03:56 PM
  #241
hes too busy looking at the final product and fapping. Hell I would...
Old Nov 29, 2013 | 04:25 PM
  #242
advise's Avatar
If he faps too much he'll go blind and won't be able to finish the head swap
Old Nov 29, 2013 | 04:37 PM
  #243
Or his hairy palms will prevent him from tightening the bolts to spec and possibly damaging the head. Damn we need to call in the local pd for a wellness check!
Old Dec 2, 2013 | 10:08 AM
  #244
Staged07SS's Avatar
Administrator
Administrator
Head is on, bolted to spec. Cams, valve springs, and followers all installed. Fuel rail is bolted on, timing her today.
got it?
ya.
good
Calm yourself
Old Dec 2, 2013 | 10:27 AM
  #245
yeeeeeeeeeeeeeeeeeeeeeeeee
Old Dec 2, 2013 | 12:45 PM
  #246
Dyn0mitemat's Avatar
I expect that you can at least get us some idle videos of it this time around?
Old Dec 2, 2013 | 01:25 PM
  #247
Staged07SS's Avatar
Administrator
Administrator
We shall see. I have videos of it, but they are only on FB.
Old Dec 2, 2013 | 05:31 PM
  #248
Create youtube account, or photobucket
Old Dec 2, 2013 | 09:51 PM
  #249
Staged07SS's Avatar
Administrator
Administrator
I have a youtube account, but haven't been on it in years. I'll have to see if I can remember the password.
On a good note.... The car is all timed up. All that's left to do is change the oil, install the exhaust manifold & blower, and add coolant.
Old Dec 2, 2013 | 09:54 PM
  #250
JapEatr's Avatar
South Central *********
So.... You done yet?
