I just got dynod by zzp
Old Feb 17, 2009 | 12:35 AM
  #101
lsjwannabe's Avatar
iirc he said 11.9 is what he brough it to
  #102
ShortStack's Avatar
Right, which is why the spark is low...
but he should have made you run richer, which would have eliminated kr to an extent.
Old Feb 17, 2009 | 12:51 AM
  #103
Area47's Avatar
Rent me! per hour
i crammed 23 degree's down a stage2 07 last month on the rollers and the afr was in the mid 11's. double edge sword. screwed either direction you go with it.
just because it will do it on the rollers doesn't mean it will do it on the street.
Old Feb 17, 2009 | 10:52 AM
  #104
ShortStack's Avatar
I think thats your favorite term... double edged sword.. but i cant really think of any other metaphor that can describe it any better.
Area, would you rather cut into the afr, or the spark?
Old Feb 17, 2009 | 11:07 AM
  #105
roadrage06's Avatar
Post #81 (Omega_5) is the best post of this whole thread....lol.
Old Feb 17, 2009 | 11:09 AM
  #106
ShortStack's Avatar
Lol.. i wanna know what the deleted post was.
Old Feb 17, 2009 | 12:31 PM
  #107
Area47's Avatar
Rent me! per hour
i may use it a lot, but it is true.
you have to find the happy medium between the two. most timing you can run on the street, and at a safe afr as well. most street cars i send out are sitting at 11.3 afr, unless other wise wanted by the owner. then waivers come into play to protect myself. you get the idea.
Old Feb 17, 2009 | 12:35 PM
  #108
ShortStack's Avatar
Would that number change if u switched to turbo? considering there is a little less heating going on?
also, you should change your spark first right? It seems that if you do your afrs first, then change spark, your changing how much fuel is being burned so it will throw off your calibration... no?
Old Feb 17, 2009 | 12:37 PM
  #109
Area47's Avatar
Rent me! per hour
when you get rid of the adders on the timing side of it. it drops the timing down a lot. gives you room the play with before you start adding it back in.
Old Feb 17, 2009 | 12:47 PM
  #110
ShortStack's Avatar
It seems that those adders get in the way and just change things when u dont want them changed.
im guessing it makes things more managable to remove some of the PE adders too?
Old Feb 17, 2009 | 01:25 PM
  #111
Area47's Avatar
Rent me! per hour
the iat/ect/afr adders on the timing side of it. leave the high temp ones in there, or increase them. take out some of the lower ones. im a control freak when it comes to certain things
Old Feb 17, 2009 | 01:37 PM
  #112
ShortStack's Avatar
Yea, if you want something setup the way you want it, and the damn computer keeps changing it, id be a freak about it to.
That egt gauge seems helpful in letting you know when your pushing a little bit too far.
Im a bit stuck on how you would try to increase the power... I mean after leveling everything out... Do you add fuel by changing injector offsets, while still keeping it at a leaner AFR... i mean dialing it in to a 11.5 AFR and adjusting the spark accordingly is nice and all, but it just doesnt seem like the path stops there...
Old Feb 17, 2009 | 03:43 PM
  #113
Area47's Avatar
Rent me! per hour
maf scaling
Old Feb 17, 2009 | 03:52 PM
  #114
ShortStack's Avatar
would that be on the same table that you change when you do your fuel trims?
Old Feb 17, 2009 | 04:00 PM
  #115
Darkmanx's Avatar
Maf fqz
Old Feb 17, 2009 | 04:04 PM
  #116
ShortStack's Avatar
Yes.
Jan 12, 2016 12:01 AM
no_ss
Oct 18, 2015 11:58 PM
justinchinn
Oct 2, 2015 12:18 PM
Sep 27, 2015 08:53 PM
