Le Riceburners OFFICIAL Build Thread
You will be impressed with the power from the ported head and cams. It's worth it!
i'm just saying for this current 'build'. i have nearly 15k into mods before that. its nuts
and i did get a lot of good deals for doing this stuff no joke.
Prob not even 10k.
Edit: Just did a quick calc.... I spent roughly 7k total on all the mods currently on my car.
That includes all suspension mods, brakes, wheels and tires.
I actually did make and keep updating a list since i got the car
i was off, i'm around 16k at this moment now
Car mods list: (12/19/13)
Exterior:
Front TC Grill: $71
TC Radiator Grille: $70
Rear k2motors taillights: $150
Extra set of k2motors taillights: $110
Getting the two combined: $150
Resistors: $20
Debadge/Rebadge: $20
Led turn signals: $8
New Morimoto Harness & Ballasts: $130
Another set: $130
Anzo black housing headlights: $120
Windshield Tint: $35
20/35 Window Tints: $150
Evo Mod
Tint side markers/3rd brake light
G2 Red Caliper Paint: $40
Stickers: $20
C/F Bowtie: $25
New C/F Bowtie: $25
C/F License Plate frame: $20
Shorty Antenna: $20
Hide-a-plate: $50
C/F Wingblade & endcaps: $225
and set of anzo headlights - 120
misc retrofit parts - 150
Total: 2622
Interior
Rebought turbo seats: $450
Armrest: $75
Redline Goods Armrest cover and shift boot: $150
Front and Rear huskyliners floormats: $85
Trunk huskyliner mat: $75
Map leds: $8
Black Cat Custom gauge faces: $120
Red Led Button Swap: $100
Supercharged Logo: $13
Single pod steering wheel bezel: $100
Wideband Gauge: $120
WOT BOX (LC + NLS) : $120
GMPP Pedalset: $110
MRZ Performance Supercharged Door Sill Plates: $60
TWM Short Shifter with base bushings & cable clamp: $380
Flat black painted dash trim: $45
Factory Dome Light w/ LED’s : $40
Rockford Fosgate Speakers (front & back): $300 installed
Alpine Sub Amp: $60
Polk Audio MM1040 Sub: $100
Sub Amp Wiring Kit: $40
Sub Box to modify: $60 (then sold other one so $-60
Dual Gauge Pod: $50
Aeroforce Multigauge: $150
Total: 2791
Drivetrain:
GMPP Clutch kit: $270
Stock Flywheel - $120
LNF Shift Bracket: $45
ZZP Axles : $150
Replacement ZZP Axle: $100
Napa axle: 80
Install: $500
Powell Trans Mounts - $110
LSD trans with 15k miles: $450
Total: 1825
Suspension:
SSC Lowering Springs: $220
Moog Front Sway Bar Endlinks: $60
KYB Front Struts: $140
Kyb Strut Mounts: $50
Moog Front Tie Rod Ends: $45 - sold
Moog Control Arm Bushings: $40
Koni Rear Adjustable Shocks: $150
ZZP Front Strut Tower Brace: $80
Unknown Brand Rear Swaybar: $40 used
Powdercoating strut brace black: $20
Total: 845
Wheels/Tires:
Extra set of ss/sc rims: $100
Powdercoating them: $240
Powderciating other set: $200
16” Wheels with Hoosier Drag Radials: $200
2 Nitto NT555’s: $300 Installed
1” 5x110-5x110 hub adapters: $130
Total: 1070
Brakes:
Brakes – r1 concepts slotted rotors and hawk hps pads: $400
Engine
Ottp stage 2 - #60’s, 2.8”, spark plugs +multiple pulley: $350
Different pcm: $140
Ottp stg1 heat exchanger: $235
ZZP Longtube Header/Catted DP: $400
ZZP 2.5” Resonated Catback: $420
ZZP Option B: $130
Dual Pass Endplate: $75
Phelonic Intake Manifold Spacer: $100
Progressive Meth Kit: $280
(installed jan 1st of 2013, ~1 $10 gallon of meth a week until August 1st)
(since aug 1st, $5 a gallon)
ZZP 3” Intake: $210
James Rakes Tune: $300
Powdercoating new valve cover: $20
ZZP Stage 2 cams – 500
80# performance autowerks valvesprings – 125
Ecotec viton valve seals – 20
ZZP Stealth heat exchanger – 265
ZZP Machined front cover – 99
ZZP Magnetic Drain plug – 7
ATI Super Damper – 399
ARP Tensioner Bolts – 55
LSJION ported head – 200 so far
New devilsown progressive stg2 meth kit – 200
80# injectors: $150
ZZP Neutral Balance Shafts: $150
New valves - 150
front and rear seal - 40
new rod and main bearings and bolts - 210
Arp headstud kit – 150
2.7” pulley – 60
New timing set – 250
Retainers, studs, nuts, keys – 220
Total: 5950
Upkeep
Repaint window switch/sub cover : $8
225/40/18 Continental ExtremeGrip DWS: $700
Reverse Switch : $16
Drivers Side seatbelt guide: $20
Timing Chain Tensioner: $40
K&N Filter repl.: $35
Replacement IC pump – 100
Exhaust gaskets – coppertech and remflex - $60
Total: 979
Free/extra
Add auxiliary port
Move rear seat fold cord
Came with injen intake
CURRENT COST TOTAL :
GAS?
SOLD/TAKEN OFF PARTS HISTORY
Carbon fiber wing blade and endcaps: $150 SOLD!
Black Headlight Housings: $100 UNUSED!
Other stickers/overlays: $20 TAKEN OFF!
Carbon dash panels: $45 SOLD
Ingalls stiffy torque dampener: $100 - SOLD
ZZP 2.5” Catted downpipe w/ extra bunghole: $225 - SOLD
Corsa Catback 2.5” touring exhaust: $450 - SOLD
8000K BiXenon Heads & Fogs: $100
Black grey mesh turbo seats swap: $350
Straight trade for black/black turbo seats
Traded for recaros: $-100
Sold Recaros: $-150 (plus stock head)
Ottp stage 1 rotated trans mounts: $120 – SOLD!
Bad Mab header: $180 – SOLD!
Kdubs 1st set of headlights: sold w/ kit for 400
Kdubs 2nd set of headlights: 350
Injen Intake – SOLD!
TTR Engine Mount – 150 - sold
Moog tie rod ends – sold for 45
Exterior:
Front TC Grill: $71
Resistors: $20
Another set: $130
Evo Mod
Stickers: $20
C/F Bowtie: $25
New C/F Bowtie: $25
Shorty Antenna: $20
Hide-a-plate: $50
Total: 2622
Interior
Armrest: $75
Map leds: $8
GMPP Pedalset: $110
Alpine Sub Amp: $60
Dual Gauge Pod: $50
Total: 2791
Drivetrain:
ZZP Axles : $150
Napa axle: 80
Install: $500
Total: 1825
Suspension:
Total: 845
Wheels/Tires:
Total: 1070
Brakes:
Engine
Different pcm: $140
ZZP Option B: $130
ZZP 3” Intake: $210
80# injectors: $150
New valves - 150
2.7” pulley – 60
Total: 5950
Upkeep
Total: 979
Free/extra
Add auxiliary port
GAS?
Im fairly confident im somewhere between 3 and 4k for this head swap thus far, and i havent gotten my 500 dollar dyno tune yet either. Ill go through and make an official list later since im interested now lol
Engine
Different pcm: $140
ZZP Option B: $130
ZZP 3” Intake: $210
80# injectors: $150
New valves - 150
2.7” pulley – 60
Total: 5950
Engine
Different pcm: $140
ZZP Option B: $130
ZZP 3” Intake: $210
80# injectors: $150
New valves - 150
2.7” pulley – 60
Total: 5950
engine is what I am referring to the drive train I can see also the rest is stuff(that's probably inflated numbers) that dos not make the car perform better dose not matter to me I know to others it dose I consider it more of a waste
and if you get 4g into a head swap something is wrong
$900 GMR Head
$500 (bolts, gaskets, timing components, etc.)
$550 COMP/ZZP cams (Black Friday deal)
$350 Supertech valve springs
$150 (cam tool/valve spring tool)
Total = $2450 give or take a few dollars
Oh yeah engine stuff less than 6k
The numbers are rough but not inflated. I tried to include shipping into some as i went along since shipping really adds up
Exterior:
Front TC Grill: $71
Resistors: $20
Another set: $130
Evo Mod
Stickers: $20
C/F Bowtie: $25
New C/F Bowtie: $25
Shorty Antenna: $20
Hide-a-plate: $50
Total: 2622
all of that is a tvs kit from ottp
Interior
Armrest: $75
Map leds: $8
GMPP Pedalset: $110
Alpine Sub Amp: $60
Dual Gauge Pod: $50
Total: 2791
this is a built shortblock
Drivetrain:
ZZP Axles : $150
Napa axle: 80
Install: $500
Total: 1825
Suspension:
Total: 845
head work and springs
Wheels/Tires:
Total: 1070
cams and misc parts neede to finish
Brakes:
Engine
Different pcm: $140
ZZP Option B: $130
ZZP 3” Intake: $210
80# injectors: $150
New valves - 150
2.7” pulley – 60
Total: 5950
some would not need spent due to built sb
Upkeep
Total: 979
you cant count normal up keep as mods or money spent **** wears out needs replaced
Free/extra
Add auxiliary port
GAS?
Exterior:
Front TC Grill: $71
Resistors: $20
Another set: $130
Evo Mod
Stickers: $20
C/F Bowtie: $25
New C/F Bowtie: $25
Shorty Antenna: $20
Hide-a-plate: $50
Total: 2622
Interior
Armrest: $75
Map leds: $8
GMPP Pedalset: $110
Alpine Sub Amp: $60
Dual Gauge Pod: $50
Total: 2791
Drivetrain:
ZZP Axles : $150
Napa axle: 80
Install: $500
Total: 1825
Suspension:
Total: 845
Wheels/Tires:
Total: 1070
Brakes:
Engine
Different pcm: $140
ZZP Option B: $130
ZZP 3” Intake: $210
80# injectors: $150
New valves - 150
2.7” pulley – 60
Total: 5950
Upkeep
Total: 979
Free/extra
Add auxiliary port
GAS?
technicaly the parts you had before the gmr head don't count they were already in and being used all you did was repourpose them lol
