Official Turbo LSJ thread!!!
Old Jul 31, 2012 | 04:06 PM
  #2551
SuperChargedMA's Avatar
Originally Posted by CCrunner84
Skip to around 1:30 - I had thought it was the BOV but that's not the case
Ion Redline - Compressor Surge? - YouTube
I've talked a bit to Matt about it, it seems to happen more often when rolling into the throttle, but even when just stomping on it you get a little bit.
I actually may be experiencing something similar if you're talking about the noise I think you are
Old Jul 31, 2012 | 04:10 PM
  #2552
CCrunner84's Avatar
The chachachacha noise, it's not BOV flutter when you let off.
Old Jul 31, 2012 | 04:14 PM
  #2553
Like the noise at 0:12 and 1:30. When you're getting on it and it starts to sound like its stuttering? I get that same noise and its driving me insane.
Old Jul 31, 2012 | 04:16 PM
  #2554
CCrunner84's Avatar
That's it, it's not good either. What turbo are you running?
Old Jul 31, 2012 | 04:21 PM
  #2555
I know, it only happens when I'm in second. Third gear goes solid. But I've been babying the car til I can figure it out. I'm running the S252et with the ZZP Swap.
Old Jul 31, 2012 | 04:30 PM
  #2556
jhaddock21's Avatar
Yea that definitely sounds like compressor surge. What a/r do you have and how much boost?
Old Jul 31, 2012 | 04:32 PM
  #2557
cobaltsskid1200's Avatar
so i have 78xxx miles. probably 80xxx by the time i would go turbo. would it be safe to go turbo at this point? and if so what options on zzp kit would be best? what size turbo my STOCK internals can handle?
lots of questions i know.
thanks
Old Jul 31, 2012 | 04:36 PM
  #2558
Gelladuga69's Avatar
thanks
Do a compression test to figure out general engine health.
Options on the kit depends on how deep your pockets are.
Stock internals are good to like 400hp or something.
Old Jul 31, 2012 | 04:42 PM
  #2559
Also, which BOV are you using?
Old Jul 31, 2012 | 04:46 PM
  #2560
CCrunner84's Avatar
Apparenly it's the .55a/r - 24PSI. Using the Tial Q 50mm.
Old Jul 31, 2012 | 04:48 PM
  #2561
Damn, well we have different set-ups and we're experiencing the same thing... I want to know how to fix this...
Old Jul 31, 2012 | 04:58 PM
  #2562
BLAZIN07SS's Avatar
I'm too JDM for you
apparently it's not 25.5psi on the .55ar
Old Jul 31, 2012 | 05:41 PM
  #2563
CCrunner84's Avatar
Not sure what you mean...
From ZZP, standard 256 with .55 housing, maybe the a/r doesn't apply, not very familiar with turbo's.
Old Jul 31, 2012 | 11:48 PM
  #2564
c130aviator's Avatar
Well my day sucked. I didnt have any nuts to bolt up the Super 20g so I made 3 trips to the hardware store to find out they were 3/8 24 tpi. In the process of bolting up the manifold I got a nut twisted using a deep well socket and it destroyed the threads. I spent 4 hours today destroying my turbo manifold studs. Pulled the manifold and decided I will take it to a machine shop to remove the busted up stud. Then I am going to get the manifold and the turbo ceramic coated silver. Should look awesome. This is taking forever but its my own fault for breaking my thermostat housing and destroying the thread on my manifold. I am so freaking fed up but since every thing is pulled I am going to get them ceramic powder coated.
Old Aug 1, 2012 | 12:17 AM
  #2565
Facepalm_IRL's Avatar
Need help solving issues on my setup. Running LNF manifold with k04 with intention of swapping to ZZP EFR in the spring. LNF oil lines custom I/C piping on a Redline. On start up, had an exhaust leak. Been trying for 2 weeks to hunt it down. PD and myself performed the install and made sure everything was correct to the best of our abilities.
The exhaust leak is still present and has gotten worse. I searched for it again today and couldnt find it still. Every possible nut and bolt has been checked and re-checked. I have come to the conclusion that the manifold gasket may have gotten folded somehow and causing the leak or (even worse) the compressor housing itself has a leak.
I cannot build above 9psi for some reason. I have checked every coupling and have found nothing.
The car wont respond to any changes in the tune. The car runs rich and afr flatlines on 10.0 until it forces the pcm into open loop.
On start up and beginning driving, the car is very jerky and sometimes sluggish, possibly due to being so rich. The jerks are very uncomfortable and is a nuisance.
If I have to get a new turbo due to compressor housing leaking, I will be getting one with the power potential I want, within price range.
At this point I am frustrated, disappointed, and tired of the problems. I am being patient because i kno these are part of the process.
Old Aug 1, 2012 | 12:30 AM
  #2566
CCrunner84's Avatar
Could all be related to the exhaust leak. After seeing someone seafoam their car for the first time this past weekend I'd consider that to try and find an exhaust leak, you'll have plenty of smoke to find out where it's leaking lol.
I can compare your tune vs mine if your interested (04 IRL).
Old Aug 1, 2012 | 12:33 AM
  #2567
PD (blkwdoss) is doing my tuning. He has my tune file so I will have him send the file to you later tonight when he gets online
Old Aug 1, 2012 | 04:12 AM
  #2568
BlkWdoSS's Avatar
SCMA & CCrunner - what spring are you guys running in your BOVs? its possible that you are seeing a boost spike and getting either surge or flutter.
csskid & gelladega - I made 438whp w/ 180k miles on the car. If you are worried, do compression and leak down test.
CCrunner, send me a pm with your email, I will send a .hpt and log over for you to see if you would like. what injectors/fuel system do you have? FP IRL uses stock fuel system w/60s
Old Aug 1, 2012 | 03:51 PM
  #2569
I'm honestly not sure what spring I'm running in it, whatever came in the ZZP Kit. I've never fiddled with a BOV before, but I do feel like the problem may be that it's not opening enough. How do I go about adjusting the spring, or lessening the pressure so that it opens and closes easier?
Old Aug 1, 2012 | 04:02 PM
  #2570
BLAZIN07SS's Avatar
I'm too JDM for you
yeah, i misunderstood what you were saying sorry
Old Aug 1, 2012 | 04:39 PM
  #2571
CCrunner84's Avatar
The BOV shouldn't really open under WOT. I'm running a plain spring if I remember correctly, it was sized according to the tial chart and the amount of vacuum I'm pulling at idle (stays closed at idle).
Old Aug 1, 2012 | 06:25 PM
  #2572
before the ceramic powdercoat the sample tube is what color I am going with on the turbo and the manifold
Old Aug 1, 2012 | 07:24 PM
  #2573
rivaladore's Avatar
My bov stays open at idle. Tial q
Old Aug 1, 2012 | 08:00 PM
  #2574
BLAZIN07SS's Avatar
I'm too JDM for you
My tial q stays closed at idle. I believe I have the unpainted spring in it
Old Aug 1, 2012 | 08:27 PM
  #2575
CCrunner84's Avatar
Same here, plain / unpainted spring - Tial Q.
