Official Turbo LSJ thread!!!
Old Feb 11, 2013 | 03:11 PM
  #4001
jonnymerk's Avatar
Originally Posted by slvr 04 rl
Thanks
No it says CMS it's a local shop down here that did my piping.
lol don't I own something in one of your pics now
Old Feb 11, 2013 | 08:51 PM
  #4002
slvr 04 rl's Avatar
Haha no, not exactly.. I'm running the 6262 now
Old Feb 11, 2013 | 10:05 PM
  #4003
brentp's Avatar
Well I'm a college kid building on a budget so 4k is expensive to me I'm not a novice I already did my supercharger build and clutch and rebuilt a ford ranger engine hoping that the turbo kit won't mess up my engine I plan on getting head studs is that prob a good idea? Zzp says you can run the turbo kit on a stock internal engine (which I have) but it has 81k should I just do cams pistons valves? Might be cheaper and safer?
Old Feb 11, 2013 | 10:14 PM
  #4004
c130aviator's Avatar
follow this guide and you cant go wrong, just remember to log log log, dial in dial in dial in with zzp. it may take days or weeks. Get that tune right and you will be fine.
BIG power LSJ! | ZZP News
Old Feb 11, 2013 | 10:19 PM
  #4005
brentp's Avatar
Don't even have a tuner guess I should look into that I'm guessing you will say hp tuners is the way to go?
Old Feb 12, 2013 | 12:48 AM
  #4006
jonnymerk's Avatar
so ya my phone rings at 12:30 am and it's my tuner/mechanic.....and he doesn't sound so happy. Tells me my car made at most 250hp on the dyno then on the 7th pull just loses power...
So now I'm like well what happened. I hope its something simple and not the motor or turbo poping... Still the power numbers being that low from the get go wtf gives.. Hope I'll get better news tomorrow.
Old Feb 12, 2013 | 01:17 AM
  #4007
EXsoccer1921's Avatar
sounds like rings were going out. or something else was wrong. and then buh bye.
i only put down 346 on 21psi with a 3076 on a hurt motor. that's a 430whp setup all day long. few months later number 4 said i quit life.
Old Feb 12, 2013 | 02:19 AM
  #4008
Dr.Balt407's Avatar
question! i have 98k on a stock block and i have a s20g at 22psi im looking to go a little higher but i want to kno how do the lsj's take abuse at such high mileage? should i keep it as is or as long as the motor is maintained i "should" be fine. also i run 5w30 oil if that makes any difference.
Old Feb 12, 2013 | 03:35 AM
  #4009
jonnymerk's Avatar
Ill be pissed my motor had maybe round 58,000 miles on it. It ran fine before it went in for the swap.
he thought also maybe a spun rod bearing? Either way I'm screwed cus I barely had enough for the turbo change and stuff as is...
Old Feb 12, 2013 | 12:49 PM
  #4010
Cmyler34's Avatar
Question guys. The alternator that I got for y kit is bad, can I just use my old LSj alternator? Or what kind do I need? Please help cars running though and everything sounds great!' Ill post pics later today
Old Feb 12, 2013 | 01:53 PM
  #4011
Gotta weld lsj alternator. I have one if you want it. 50 shipped.
Old Feb 12, 2013 | 04:10 PM
  #4012
just do a compression test
Old Feb 12, 2013 | 04:43 PM
  #4013
nsmith89's Avatar
because we all got tired of the m62s lol. too much work to make good power. As of now we have 4 Turbo LSJs in the squad
true that lol. and what tensioner are you using?
check out *removed*
Old Feb 12, 2013 | 04:45 PM
  #4014
how about no.
Old Feb 12, 2013 | 05:04 PM
  #4015
Cmyler34's Avatar
Originally Posted by nsmith89
check out *removed*
5*
Old Feb 12, 2013 | 05:08 PM
  #4016
jonathan923's Avatar
what the hell happened there? lol^^^
  #4017
spammin links. did it in another thread too
Old Feb 12, 2013 | 07:21 PM
  #4018
klutch814's Avatar
got new ecm in. tried crank relearn with tech 2 but the car wont even run on stock tune lol. hpt it runs fine idle is jumpy but im still on base file..
Old Feb 12, 2013 | 07:29 PM
  #4019
Cmyler34's Avatar
Mean to tag you in the 5* turbo LSjs lol
Old Feb 12, 2013 | 07:57 PM
  #4020
I have like 5 tunes for various configurations. I can email you a good toon to get you started.
Old Feb 12, 2013 | 08:03 PM
  #4021
nwss's Avatar
I has the not running tune lol...hope the zzp canned tune is good for at least 340whp
Old Feb 12, 2013 | 08:34 PM
  #4022
klutch814's Avatar
will crank relearn matter? the car drives fine. but i have 2 codes for it.
Old Feb 12, 2013 | 08:40 PM
  #4023
Cmyler34's Avatar
Cars almost done
Old Feb 12, 2013 | 09:17 PM
  #4024
Nope u copy and paste tables into your vins hpt file. You won FCOTM without a running car. Lol. Smh
Old Feb 12, 2013 | 09:25 PM
  #4025
Billig ss/sc's Avatar
Hey guys, my LSJ-T is starting to spew black smoke really bad once I get into boost. I'm thinking tune, thoughts?
I'm going to try to get a video whenever it's not snowing/raining here.
