Official Turbo LSJ thread!!!
Old Jun 12, 2013 | 09:17 PM
  #5726
EXsoccer1921's Avatar
Originally Posted by MP Cobalt
That's how I have it. the end is attach to the nipple by the throttle body, and the side is attached to the top of the wastegate, and the bottom of the wastegate is attached to another nipple from the intake manifold.
No I have it turned all the way with a (-) sign. I have no idea wtf is wrong and it had so much pressure the damn evap blew off the intake manifold
what wastegate are you using?
i'm running the hallman pro mbc and a precision wg. vacuum line coming off the rear of the controller goes to the intake manifold. vacuum line coming off the side of the controller goes to the bottom of the wastegate. top nipple of the wastegate is left open.
Old Jun 13, 2013 | 05:17 PM
  #5727
nwss's Avatar
Is it even worth is to put the lsj tb onto the Saab mani? My "new" tb from zzp throws a code every now and again. Yes I already know what I need to do to make it work/fit.
Old Jun 13, 2013 | 05:19 PM
  #5728
nwss's Avatar
You need some real fuel first. I got the s256et with the 74/64 turbine wheel hitting 26psi at 3700rpm
I hate chu! Lolol
Old Jun 14, 2013 | 03:04 PM
  #5729
MP Cobalt's Avatar
I'm using the Tial 38mm wastegate. I got the lines all figured out but the car still feels down on power. I thought it might of been the boost controller but I'm running out of ideas.
Old Jun 14, 2013 | 03:22 PM
  #5730
nwss's Avatar
I'm using the same wg. Top of wg going to bc and side of wg going to the vacuum line going into the bc from intake manifold
Old Jun 14, 2013 | 03:30 PM
  #5731
Bad-A-SS's Avatar
Have you preformed a compression n leak down test? Also is everything tighten down? What are the new symptoms? Slower spool? Af ratio jumping all over? Anything out of the norm?
Old Jun 14, 2013 | 03:42 PM
  #5732
nwss's Avatar
Maybe he's just used to the power now.
Old Jun 14, 2013 | 07:08 PM
  #5733
c130aviator's Avatar
log the car and watch for where KPA comes in compared to RPM. Post up some data logs so we can help you out with your boost problem? Didnt you replace your valves? Did you check compression before you did that?
Old Jun 14, 2013 | 09:29 PM
  #5734
nwss's Avatar
Yup I'm liking this whole no ac and shorter belt! I know the -25 lbs didn't make the difference lol
Old Jun 14, 2013 | 09:55 PM
  #5735
is the no ac and shorter belt the same as just not turning the ac on and having it just free spool the compressor pulley. Car feels stupid fast whether its on or off to me...
Old Jun 14, 2013 | 09:58 PM
  #5736
i used to have a video of me spinning a spare compressor i had. there's actually a lot of load there even when it's off.
  #5737
i also had the weight of every component and the total weight. but that stuff is all at the other house :/
Old Jun 14, 2013 | 10:14 PM
  #5738
nwss's Avatar
Shorter belt=faster spinning. Plus without the little amount of load from the ac It's noticeable.
Old Jun 14, 2013 | 10:16 PM
  #5739
i944scania's Avatar
Anyone know the exact size of Lsj throttle body? Need to find a pipe coupler that fits
Old Jun 14, 2013 | 10:49 PM
  #5740
that makes sense. I thought about the ac nix especially since you can then use the 5 volt input for AFR strictly.
Old Jun 14, 2013 | 11:19 PM
  #5741
MP Cobalt's Avatar
I checked compression and leak down. Changed springs and now Mbc. Also nought different wheels and tires. Haven't hit the Dyno yet but the last time I was on it. It read around 330 when it should be at 400ish Haha. Couple v8 guys said could be wheels and tires. So I went to the smaller tire I Dyno before on and lighter wheels that I always wanted. Got to replace a bad left axle and see if anything changed. The spool up is good and is roughly 11.8 to 12 AFR but my idle is jacked ad like 12.5 and Tim from ZZP don't seem to think its the tune I got from him but when in flash my old tune ingot with the kit it idles at 14.3 to 15
Old Jun 15, 2013 | 12:02 AM
  #5742
That 12ish idle is way too rich. Not sure but it may wash down the walls of the cylinder and remove oil from your rings over time.
Stoich is 14.7 for gas, I am at 9.8 stoich for E85 in my tune. My afr gauge at idle, cruise, and low rpm acceleration reads 14.2-14.7 on my wideband (even with E as lamda is the same on the afr gauge controller).
Sounds like a boost leak, boost controller, or a tune.
I make 338 whp at 15 psi and over 400 at 22 psi. With my boost leak I was only seeing 10psi and the car felt horrible. Mine was in my sheetmetal intake. Got it welded up by a race car builder with beefier welds. Good to go.
Old Jun 15, 2013 | 12:07 AM
  #5743
nwss's Avatar
http://item.mobileweb.ebay.com/viewi...d=200933865552
My new turbo..nbd
Old Jun 15, 2013 | 12:15 AM
  #5744
have fun with the spool.
Old Jun 15, 2013 | 12:31 AM
  #5745
i find down shifting necessary with the 3600 rpm spool, anything over that is gonna feel like crap on a daily commute IMO. But if its the number you are chasing that Borg Warner will do it.
Old Jun 15, 2013 | 12:33 AM
  #5746
holy 5400 rpm to full spool turbo batman. I know it has a .91 ar but just looking around...
2007 STi: Twinscroll BorgWarner S300SX FMW vs Twinscroll Garrett GT4088R - NASIOC
Old Jun 15, 2013 | 01:45 AM
  #5747
Bad-A-SS's Avatar
Yeah man just go with the 5558 or even the 5858 like you said before much better choices and could still produce gobs of power
Old Jun 15, 2013 | 10:52 AM
  #5748
nwss's Avatar
Haha I'm only joking
Old Jun 15, 2013 | 10:55 AM
  #5749
phew
Old Jun 15, 2013 | 10:57 AM
  #5750
nwss's Avatar
Yeah my choices are either the 256et with the billet wheel or 5558
