Official Turbo LSJ thread!!!
ask the locals that have riden in my car how my 6262 spools. You guys will be surprised. Then for that tenth of a second you jump out, im pulling the paint off your car when i come by
That 12ish idle is way too rich. Not sure but it may wash down the walls of the cylinder and remove oil from your rings over time.
Stoich is 14.7 for gas, I am at 9.8 stoich for E85 in my tune. My afr gauge at idle, cruise, and low rpm acceleration reads 14.2-14.7 on my wideband (even with E as lamda is the same on the afr gauge controller).
Sounds like a boost leak, boost controller, or a tune.
I make 338 whp at 15 psi and over 400 at 22 psi. With my boost leak I was only seeing 10psi and the car felt horrible. Mine was in my sheetmetal intake. Got it welded up by a race car builder with beefier welds. Good to go.
So, I have a few questions:
I picked up myself a rebuilt Saab 9-3 Turbo lastnight, With a manifold. Now, I need to know what else I need, I have a buddy of mine building my charge pipes, hot and cold, And I picked up myself a new Intercooler as well, I also have all of the oil lines and such.
My car is currently Supercharged, Do I need to retune my car once I swap everything over? My buddies tell me I don't have to (One has a turbo Cavalier pushing 400HP that he built) and the other is a GM mechanic.
Just want to shed some insight!
Kris
Kris
psssht no, you dont need a tune. Once you get everything installed you just need to reset the computer by opening up on the highway to WOT. You car computer will then reset to the new calibration.
Kris
Kris
I've got a friend who has tons of steel expirence. He recently started working with alum. Said he can make it look great
Also, the turbo kit I bought came with a weird wastegate. Brand name wyntonM ? And its hugee
Last edited by i944scania; Jun 20, 2013 at 01:25 PM. Reason: Automerged Doublepost
