Official Turbo LSJ thread!!!
Old Jun 15, 2013 | 11:05 AM
  #5751
c130aviator's Avatar
5558 is my next turbo, but it wont be anytime soon...
Old Jun 15, 2013 | 01:17 PM
  #5752
zrated89's Avatar
ask the locals that have riden in my car how my 6262 spools. You guys will be surprised. Then for that tenth of a second you jump out, im pulling the paint off your car when i come by
Old Jun 15, 2013 | 02:00 PM
  #5753
574's Avatar
574
Thought you said 5862?
Old Jun 15, 2013 | 02:16 PM
  #5754
Good catch I meant 5862... I read his post and as I was typing I must have regurgitated the wrong number. LOL
Old Jun 15, 2013 | 03:49 PM
  #5755
EXsoccer1921's Avatar
the 6262 has a smaller wheel than the one he linked.
Old Jun 15, 2013 | 07:30 PM
  #5756
MP Cobalt's Avatar
That 12ish idle is way too rich. Not sure but it may wash down the walls of the cylinder and remove oil from your rings over time.
Stoich is 14.7 for gas, I am at 9.8 stoich for E85 in my tune. My afr gauge at idle, cruise, and low rpm acceleration reads 14.2-14.7 on my wideband (even with E as lamda is the same on the afr gauge controller).
Sounds like a boost leak, boost controller, or a tune.
I make 338 whp at 15 psi and over 400 at 22 psi. With my boost leak I was only seeing 10psi and the car felt horrible. Mine was in my sheetmetal intake. Got it welded up by a race car builder with beefier welds. Good to go.
Yeah I know my idle is jacked and he won't change it. He thinks its my o2 sensor which I ain't. I don't know how I could have a boost leak. I have every pipe in the couple least 2 inches and the t bolt clamps as tight as the go.
Old Jun 15, 2013 | 07:31 PM
  #5757
MP Cobalt's Avatar
I'm do another boost leak test on an actual compressor not at get-go tire station hahaha.
Old Jun 18, 2013 | 08:55 PM
  #5758
mexi_loco's Avatar
In the words of Lil' Jon:
Old Jun 18, 2013 | 09:10 PM
  #5759
nwss's Avatar
Well 9.5" wide +35 wide wheels barely fit.....haha
Old Jun 18, 2013 | 10:02 PM
  #5760
I drop the car off for a tune on Thursday. Gonna see what just the BRFPS will let me set my MBC to. I think I should be able to have it dyno tuned on Saturday.
Old Jun 19, 2013 | 05:57 PM
  #5761
CannonBalt's Avatar
So, I have a few questions:
I picked up myself a rebuilt Saab 9-3 Turbo lastnight, With a manifold. Now, I need to know what else I need, I have a buddy of mine building my charge pipes, hot and cold, And I picked up myself a new Intercooler as well, I also have all of the oil lines and such.
My car is currently Supercharged, Do I need to retune my car once I swap everything over? My buddies tell me I don't have to (One has a turbo Cavalier pushing 400HP that he built) and the other is a GM mechanic.
Just want to shed some insight!
Kris
Old Jun 19, 2013 | 06:07 PM
  #5762
psssht no, you dont need a tune. Once you get everything installed you just need to reset the computer by opening up on the highway to WOT. You car computer will then reset to the new calibration.
Old Jun 19, 2013 | 06:14 PM
  #5763
nwss's Avatar
Kris
Just stay sc lol
Old Jun 19, 2013 | 07:58 PM
  #5764
574's Avatar
574
You would need a tune. You sure they are true friends? Lol
Old Jun 19, 2013 | 10:40 PM
  #5765
CannonBalt's Avatar
That's why I am asking you guys.
Old Jun 20, 2013 | 12:48 PM
  #5766
i944scania's Avatar
Is there any specific location for oil return bung to be welded? Or just the front of the pan so the return line can reach
Old Jun 20, 2013 | 01:01 PM
  #5767
nwss's Avatar
I have mine welded above the oil drain plug.
Old Jun 20, 2013 | 01:06 PM
  #5768
rivaladore's Avatar
Back of the pan
http://s3.amazonaws.com/zzpstorage/i...structions.pdf
Old Jun 20, 2013 | 01:17 PM
  #5769
i944scania's Avatar
I have read through this document before. I haven't pulled the pan off yet so the picture was unclear. Above the plug sounds good thanks
Old Jun 20, 2013 | 01:19 PM
  #5770
nwss's Avatar
Just make sure the welder does a good job, it was hard to find a welder who wanted to weld cast aluminum
Old Jun 20, 2013 | 01:25 PM
  #5771
i944scania's Avatar
I've got a friend who has tons of steel expirence. He recently started working with alum. Said he can make it look great
Also, the turbo kit I bought came with a weird wastegate. Brand name wyntonM ? And its hugee
Last edited by i944scania; Jun 20, 2013 at 01:25 PM. Reason: Automerged Doublepost
Old Jun 20, 2013 | 01:40 PM
  #5772
nwss's Avatar
I'm sure he can weld...but you don't just weld cast aluminum haha
Old Jun 20, 2013 | 01:43 PM
  #5773
armcclure's Avatar
It's a pita for sure. Dual and single passes suck. Best bet is laying down a bead on max cleaning where you want the weld to go, grind the surface off, then Tri to do it normally.
Old Jun 20, 2013 | 02:43 PM
  #5774
i944scania's Avatar
Idk how to weld very well! But he said he knows alum now. So we'll see what happens.
Old Jun 21, 2013 | 10:53 AM
  #5775
nwss's Avatar
Does the zzp downpipe bolt up to a precision ? Plan is to buy a 5858 .63 and vband
