Official Turbo LSJ thread!!!
Old Oct 2, 2013 | 08:58 AM
  #6801
574's Avatar
574
Originally Posted by Jeff876
Alright sorry to jump into this thread again in the middle of a bunch of discussions i barely comprehend lol.
Just have a couple questions .
1) How much would the turbo kit go down/what would be my chances of getting one with the discount or whatever? It won't be this black friday, but if I waited until say next black friday, would it be best to wait (buying the full ZZP kit) or would I just be pissed b/c I didn't get the sale and wasted a bunch of time?
I think I have seen as low as 50% off before. However the likelyhood you will be able to snag it... slim.
2) If I go turbo, what would be better catback wise? ZZP 3" Resonated/catted, or catless/no resonator?
Catless for sure. I run an exhaust cut out personally. I'd get the res too.
3) (not turbo related really) Are there any good coilovers for our cars? I know of the variant 2's , but are they really almost 2 grand? Are they "worth it" in terms of a smooth ride + the low?
In my view you can only afford a race car or a show car. Coils or turbo swap. If you get both, you are just a big baller and seeing figure "1)" I'm going to guess you aren't. So no they aren't worth it, buy the turbo kit.
all i can think of for now
glad I could help
Old Oct 2, 2013 | 10:15 AM
  #6802
InfraRedline's Avatar
Last year they had $1,000 off turbo kits for the first buyer, $800 for the 2nd, $600 for the 3rd, and $400 off all day I believe.
And yes, cobalts have many coilover options. You can get a few of them for about $1,000-1,000. I wish the redline had options. I wanted the pedders but they were discontinued I guess, looking for B&G, but lots of places say they don't have them. I'll look into it more this winter. It sucks when you can't find the parts you want lol. If I find em maybe I should just order a set for both cars right away.
Old Oct 2, 2013 | 11:34 AM
  #6803
bmxracerchamp12's Avatar
the ones with the adjustable endlink mount?
Old Oct 2, 2013 | 12:01 PM
  #6804
I'm not even sure to be honest. I have heard of people breaking the end link mounts off of the B&G's so I'd probably just weld and reinforce it.
Old Oct 2, 2013 | 12:37 PM
  #6805
1fastSSBalt's Avatar
I am looking at purchasing an STS turbo. I've been trying to collect what information I can and what I've gathered is: STS turbo t3/t4 38 T4b Stage 3 JAB (s-trim) sts t-31( turbine housing .36 AR and compressor housing .60 AR). I've read a few things, not specific to this turbo, that the .36 turbine could be to small.
I am a newb and still doing what research I can but I am wondering if this turbo is suitable to make my goal power 375-385. Any insight on this is greatly appreciated.
Old Oct 2, 2013 | 12:42 PM
  #6806
those are the ones. why not some kw2's? those were going to be my option if i did decide to
Old Oct 2, 2013 | 12:47 PM
  #6807
armcclure's Avatar
I'm not a fan of sts type setups for out cars. No good pipe routing path and they need that small ar to keep from being too laggy.
A normal setup still has tons of options to suit your desired characteristics.
Old Oct 2, 2013 | 12:55 PM
  #6808
You have a sedan, different suspension than coupes.
Old Oct 2, 2013 | 01:26 PM
  #6809
574's Avatar
574
Poppin mollys
Old Oct 2, 2013 | 01:36 PM
  #6810
armcclure's Avatar
You need an intake son
Old Oct 2, 2013 | 01:42 PM
  #6811
574's Avatar
574
Lol I have one, its just out of sight
Old Oct 2, 2013 | 02:07 PM
  #6812
same mounting and all though. i have run fe3 and am on fe5 now
Old Oct 2, 2013 | 02:08 PM
  #6813
mrbelvedere's Avatar
you need to rotate your pcm
Old Oct 2, 2013 | 02:09 PM
  #6814
armcclure's Avatar
The clamping flange does not count as an intake lol
Old Oct 2, 2013 | 02:10 PM
  #6815
armcclure's Avatar
Good eye john.
Nick, When that Hahn cracks once we hit 30psi ill buy it from you for double scrap price
Old Oct 2, 2013 | 03:24 PM
  #6816
When you say a normal set-up I assume you mean like the bw s252?
Old Oct 2, 2013 | 03:49 PM
  #6817
armcclure's Avatar
No I meant a typical log style, turbo mounted right behind the motor.
Old Oct 2, 2013 | 06:51 PM
  #6818
Powell Race Parts's Avatar
they will still break. the coil overs that break the end link mount are just demonstrating the el cheapo characteristics; a Torrington bearing on the top of the spring under the top spring plate will help. Its ridiculous to have shim as a bearing on a coil over at the front.
this is a huge thread jack btw.
Old Oct 2, 2013 | 06:54 PM
  #6819
how is it different other than spring rates and bushing durometer? wondering.
Old Oct 3, 2013 | 09:37 AM
  #6820
It's ok, I approve of the thread jack lol. I have put an email in to Pedders just to see if there is any way I can still get the parts to make their coilovers redline compatible. I really haven't looked into any alternative options other than the solution they offer yet. The B&G's just make me hesitant, and it seems like I am for good reason.
Again, haven't looked into it much. That is the only difference? I really don't know much at all about sedans.
Old Oct 3, 2013 | 10:17 AM
  #6821
they still offer the conversion and will assist you if you call. kw2's will work but the back has a terrible drop.
that is the only difference between them. most of the stuff will bolt from one to another.
Old Oct 3, 2013 | 10:26 AM
  #6822
You and Powell just made my day!!
Old Oct 3, 2013 | 10:43 AM
  #6823
c130aviator's Avatar
Good eye john.
That Hahn will hold for about two weeks over 20 psi then it will start to separate on the front lower and rear lower welds.
Old Oct 3, 2013 | 11:15 AM
  #6824
armcclure's Avatar
I just need a flange and most of the ones I find don't have the proper pcv hole for lsj.
Old Oct 5, 2013 | 03:39 PM
  #6825
zrated89's Avatar
oh HAI this forum still lives eh?
