Official TVS Thread!!!
Old Mar 20, 2014 | 04:50 PM
  #8351
Tjolley's Avatar
Originally Posted by Hockeyman
RSFS ordered for my upcoming build finally.
I need help picking out a pump, I want something that requires the least amount of modification to fit and that will provide all my fueling needs. I keep hearing the 044 will be good. Any other options?
Setup will be:
TVS w/2.6 and ATI, head/cams, E85, RSFS, fic1200
The aem fuel pumps recuire no major mod.
Just cut the stock fuel line off and use the short pice they supply
Originally Posted by 100% METH
few?! Lol
Which blower you want?
M62, mp90, Tvs, Lysholm 1.6?
Tvs 2300 ftw!!!!!
Old Mar 20, 2014 | 04:51 PM
  #8352
JapEatr's Avatar
South Central *********
gonna need 340lph +
Old Mar 20, 2014 | 05:09 PM
  #8353
Tjolley's Avatar
Originally Posted by JapEatr
gonna need 340lph +
The aem is 320lph
Old Mar 20, 2014 | 05:12 PM
  #8354
TStone's Avatar
Well that doesn't meet japs standards trolley!!!!!
Old Mar 20, 2014 | 05:13 PM
  #8355
JapEatr's Avatar
i laugh a little on the inside, but not out loud
Old Mar 20, 2014 | 05:17 PM
  #8356
TStone's Avatar
Hash tag sorry
Old Mar 20, 2014 | 05:18 PM
  #8357
Hockeyman's Avatar
I'd like to get a pump that exceeds my requirements, if the AEM is 320lph it may be maxed out already judging by Japs car.
Old Mar 20, 2014 | 05:22 PM
  #8358
TStone's Avatar
Well well well. Get a surge tank. Hashtag jk
Walbro 450 is a possibility.
Heard some not so positive things lately about them with e85 doe
Old Mar 20, 2014 | 05:23 PM
  #8359
JapEatr's Avatar
hashtag Powell surge tank
Old Mar 20, 2014 | 05:25 PM
  #8360
TStone's Avatar
Japs got the right idea
Old Mar 20, 2014 | 05:27 PM
  #8361
InfraRedline's Avatar
Setup will be:
It's a fun setup, I know from experience
AEM 320 E85 pump should be enough as long as you can keep the canister full of fuel. I never had an issue with my 255 and re-wire, even when I revved to 8100 at the track, although i wouldn't recommend the 255 or DW300 when better options are available which will leave you enough headroom. Personally I've seen better things about the AEM 320 over the Walbro 450. I had a walbro 450 die as well.
Old Mar 20, 2014 | 05:59 PM
  #8362
Hockeyman's Avatar
surge tank is currently not in the budget...I saw Japs bill from JP
LOL
Old Mar 20, 2014 | 06:02 PM
  #8363
Hockeyman's Avatar
How do you think my stock short block will hold up to the shenanigans?
Old Mar 20, 2014 | 06:13 PM
  #8364
Mine held up for 3 years and I still daily drive that motor, just with an M62 on it.
Old Mar 20, 2014 | 11:40 PM
  #8365
Tjolley's Avatar
The fuel in the canister is only to cool the pump. It has nothing to do with feeding the pump. Unless its been moded
Old Mar 21, 2014 | 08:25 AM
  #8366
armcclure's Avatar
False
Old Mar 21, 2014 | 08:37 AM
  #8367
Tjolley's Avatar
False
How so??
I know my canister will hold fuel and if I turn the pump on it dosnt pump fuel out.
This is with putting it in a 5 gallon bucket full of fuel and holding it above.
Old Mar 21, 2014 | 08:47 AM
  #8368
mrbelvedere's Avatar
not completely false the main purpose of the canister is to cool the pump if the canister was the main means for fuel pickup then it would have only 1 sock and it would be on the inside of the canister and no way to pull fuel from the outside of the canister well its not like that its main feed comes from the tank sump and it is restricted so it will pull very very little fuel from the canister to keep cooler fuel circulating around the pump that is why is has a filter sock on the inside bottom of the canister that is the only reason I could come up with for the pump needing to filter socks
Old Mar 21, 2014 | 08:54 AM
  #8369
armcclure's Avatar
Originally Posted by Tjolley
How so??
As John said, it draws from both but the bottom of the canister is restricted.
If what you said was true, Taylor drilling hole in his canister would have made no change, and zzp would be liars about Matt's setup.
Old Mar 21, 2014 | 09:00 AM
  #8370
Tjolley's Avatar
Maybe the restrictor was plugged on mine. Idk.
I know that mine holds fuel
Ill definitly check this out wen I have steves canister out tomarrow
Old Mar 21, 2014 | 10:01 AM
  #8371
Also 04-05 and 06-07 canisters are different. 06-07's (at least the one in my 07) has the pump hook up to the bottom of the can with the filter on the bottom exterior of the canister. My 05 the filter sits inside the canister with only that screen (restrictor) to allow fuel into the can.
Old Mar 21, 2014 | 10:55 AM
  #8372
armcclure's Avatar
The restrictor is also a check valve.
Old Mar 21, 2014 | 05:42 PM
  #8373
SSfamilywagon's Avatar
Where exactly is the restrictor or check vakve on the pumps and what does it look like?
I wonder if that's causing part my issue. I've dropped the tank several times and wonder if I overlooked this
Old Mar 24, 2014 | 08:10 AM
  #8374
armcclure's Avatar
Looks like a small washer with a thin rubber seal underneath. The "restrictor" is a through hole in the middle, probably 1/4".
Old Mar 24, 2014 | 10:49 AM
  #8375
Hockeyman's Avatar
So me and Jap put the TVS on.
IDC is 100% at 4K - and that's with a 2.8 on it. Too funny.
