Official TVS Thread!!!
Old Mar 24, 2014 | 09:13 PM
  #8401
TStone's Avatar
You can't have 100% idc and go lean if it's the tune's fault.
It doesn't work that way.
Something else is definitely up with delivery pre injector though. Filter is a good easy place to start.
physics doesn't always work
Old Mar 24, 2014 | 09:29 PM
  #8402
ThexGovenor's Avatar
doesnt it though? Weird. I didnt hit 100% till about 6.5k on almost the exact same setup. I would check what the others have suggested
Old Mar 24, 2014 | 11:13 PM
  #8403
JapEatr's Avatar
South Central *********
Yup
Old Mar 25, 2014 | 02:01 AM
  #8404
100% METH's Avatar
In the process of dialing my setup
FIC 1200cc Split streams (injector data from Alan)
BRFS return style - 43.5 Base pressure
AEM E85 320 pump
keep hitting a massive lean spike at 6100
afr holds steady at 11AFR on the wideband, cruising is normal.
IPW is 16.1-16.3 the entire pull until the spike where it hits 10.3
advance is spiking 25 for some odd reason
Old Mar 25, 2014 | 08:32 AM
  #8405
Josh@ottp's Avatar
Have you checked your fuel pressure when this happens?
Old Mar 25, 2014 | 10:06 AM
  #8406
100% METH's Avatar
No I havnt
I don't have a gauge to monitor it in car
I've had a couple conversations and we think it's maf sensor related.
When it lean spikes at wot, maf/lb drops
G/cyl kicks goes back into the higher cruising cells (explains the 25*)
Old Mar 25, 2014 | 10:32 AM
  #8407
noorj's Avatar
I was gonna say maf but the lean spike appears to happen first
Old Mar 25, 2014 | 10:36 AM
  #8408
Josh@ottp's Avatar
Originally Posted by 100% METH
No I havnt
I noticed that also but it could be that the maf drops out because it falls on its face. Use a regular snap-on or any brand fuel pressure gauge. Run the hose out of the hood so it won't kink and duct tape the gauge to the windshield so you can watch it while driving.
Old Mar 25, 2014 | 10:01 PM
  #8409
100% METH's Avatar
New maf didnt solve the problem
the massive lean spike now occurs at 5k at part throttle or wot.; the gas tank has less fuel in it too
Old Mar 26, 2014 | 07:24 AM
  #8410
Tjolley's Avatar
I was Just telling steve that. Lol
I'm almost sure its the stock canister sock that is cauzing a restriction to the pump at higher loads.
We will just have to do another mod to the canister to allow us to run the supplied sock that came with the pump.
Old Mar 26, 2014 | 07:28 AM
  #8411
Tjolley's Avatar
Well looks like we need to plan another weekend. I should have my moded injectors by then. We can hit 2 birds with 1 stone.
Old Mar 26, 2014 | 08:11 AM
  #8412
armcclure's Avatar
Is your return still dumping into the canister?
Filter sock restriction wouldn't really cause it to vary rpm based on fuel level.
I really don't see how fuel restriction can cause THAT much of a maf drop since on a blower car airflow is determined by rpm and tps...
Old Mar 26, 2014 | 02:24 PM
  #8413
Tjolley's Avatar
Well steve was telling my that the lower the tank gets the worse it becomes. He can't get over 5000 rpm now.
Yes the return dumps right into the canister. I pulled the ball and spring out and put the cover back on it.
Old Mar 26, 2014 | 03:07 PM
  #8414
SSfamilywagon's Avatar
I don't think the sock is your big restriction at all either. Sounds like the pump is getting starved and air pockets getting in the line. Willing to bet, because the lower it gets the worse it gets, the fuel is being pulled away from the pump on accel and ssloshing to the back of the tank more so on long pulls. I dont think are stock pump assembly and pick up is adequate enough to keep up with the demands needed. Stupid design putting the fuel pump and pick up at the front of the tank
Old Mar 26, 2014 | 03:20 PM
  #8415
armcclure's Avatar
That still doesn't explain the maf freq plummeting when he's still 100% throttle and map. Granted map stops approx 23psi but it would still of airflow was actually dropping as much as the maf freq claims.
Old Mar 26, 2014 | 03:23 PM
  #8416
But if the motor cuts out from fuel and drops rpm wouldn't that be a reason for the maf
Old Mar 26, 2014 | 03:41 PM
  #8417
slitterell's Avatar
You know fuel delivery is the problem right now. Fix that. See what the MAF does, go from there.
Old Mar 26, 2014 | 04:10 PM
  #8418
armcclure's Avatar
Rpm, tps, and map all stay level.
Old Mar 26, 2014 | 04:26 PM
  #8419
I didn't catch that. I thought he said the motor cuts out. I see it in the logs now. Interesting how idc's are totally different as well.
One could be causing the other. I could have swore I read something like this while I was looking up fuel data. Maybe I can find it again
Old Mar 26, 2014 | 09:57 PM
  #8420
Sunburstcruze's Avatar
Would somebody please tell the rookie...(myself) what TVS stands for ? Lol
Old Mar 26, 2014 | 10:08 PM
  #8421
TStone's Avatar
Twin Vortices Series
Old Mar 27, 2014 | 03:03 AM
  #8422
RooTBeeR's Avatar
stock blower
Eaton M62
Eaton housing/case
Eaton Gen-V 3-lobe 60* twist rotor pack
"TVS"
Harrop HTV1320 LSJ
Harrop housing/case
Eaton TVS(Twin Vortices Series) 4-lobe 160* twist rotor pack
tvs is just a more efficient design
and then theres the "unicorn" H62(High Helix)
eaton basically took an m62 housing, and altered the outlet(it was a whole new cast case design, not a modded m62) and then put the TVS rotors in it.
Staged07SS is the only one that ive heard of in probably the last 5 years or more that has one
Old Mar 27, 2014 | 03:20 AM
  #8423
RooTBeeR's Avatar
I'm a fan of his car
skip to 1:09
Old Mar 27, 2014 | 07:24 AM
  #8424
Staged07SS's Avatar
Administrator
Administrator
skip to 1:09
H62 High Helix Supercharger Drive Way #2 - YouTube
That is an old video.... wait till u see her now!
Old Mar 27, 2014 | 07:52 AM
  #8425
Powell Race Parts's Avatar
