Snow Performance Meth
I was looking into getting the Snow performance meth injection kit but i was looking around and i have so many questions on it... I want to run it in my trunk. E85 is not available in Jacksonville Florida.
1. Is the pump strong enough to pump meth from my trunk up to my throttle body? If not do i need that solenoid upgrade?
2. Where is the best place for meth to be injected? Throttle body or after supercharger?
3. Where is the best place to install the tank and pump if the pump is not strong enough to reach?
4. Is meth injection safe? Everything i read a lot does say it is safe but then there are a few people that post it is bad for the charger.
Recommendations on brands if anything is better than snow? Thanks for the help
1) Yes
2) Post TB pre supercharger
3) When I ran meth I put the pump behind the right headlight and tapped into my washer tank for less plumbing. But it's not necessary.
4) It's safe as long as it doesn't quit and you don't catch it. Taking precautions like a pressure switch and setting an Interceptor to KR so you can keep an eye on it definitely help. I ran meth for 4 years and never had any supercharger issues. I like Devilsown systems myself.
Thanks for the help. Did you get the 2.5 bar stage 2 kit? or the DVC-30 stage two? I did see pictures you had posted on how you did that but you can use meth injection as a windshield washer fluid as well? Do you make your own out of windshield washer fluid and a couple bottles of heet or just buy the pre made stuff?
The search button is your friend.
https://www.cobaltss.net/forums/2-0l...th-kit-293777/
https://www.cobaltss.net/forums/2-0l...kit-me-293695/
https://www.cobaltss.net/forums/2-0l...ection-287402/
https://www.cobaltss.net/forums/2-0l...arched-284326/
https://www.cobaltss.net/forums/2-0l...roller-282452/
https://www.cobaltss.net/forums/2-0l...ection-279354/
https://www.cobaltss.net/forums/2-0l...tion-s-276990/
https://www.cobaltss.net/forums/2-0l...th-kit-276916/
https://www.cobaltss.net/forums/2-0l...-users-272034/
https://www.cobaltss.net/forums/2-0l...s-here-215307/
https://www.cobaltss.net/forums/2-0l...ssible-256726/
https://www.cobaltss.net/forums/2-0l...s-noob-251444/
https://www.cobaltss.net/forums/2-0l...-heads-254786/
https://www.cobaltss.net/forums/2-0l...estion-255116/
https://www.cobaltss.net/forums/2-0l...oughts-253265/
Thanks for the help. Did you get the 2.5 bar stage 2 kit? or the DVC-30 stage two? I did see pictures you had posted on how you did that but you can uIse meth injection as a windshield washer fluid as well? Do you make your own out of windshield washer fluid and a couple bottles of heet or just buy the pre made stuff?
1) Yes
I'm not blue but i'll give you my input......
There's no reason for it to kick on when you're not in boost... It's gonna be rich as hell. Not a very good thing. Kind of depends how long it was spraying to determine if it could have hurt anything
Im having a hard time finding the post earlier that i had saw bluelighting post. When you drill a hole in the bottom of the windshield wiper tank what did you use to put inside that hole like connector and what kind of sealant did you use on that? I cant seem to find that post now
Self Sealing Bulk Head
Josh will lap your valves after he's done porting it for a good seal.
With an engine that's running you could spray that kit 100% of the time and not hydro lock it. Let it spray when the engine is not running and all bets are off. In fact you can rev an engine then hit it full blast with a garden hose to break up the carbon and it won't hurt it. It really freaks people out to see it done but it works great. Old trick that works but the naysayers scare most away. When you do the math there is not much water that makes it in each cylinder when it's reved.
Lol tell that to people that have hydro locked their motors driving through puddles with CAI's or air box mod. If you aren't at wot and your pump is running it will shut down the motor. I've had it happen. No damage though.
Enough water to completely block all airflow to the engine long enough for vacuum to be held on the water all the way up to the intake
does in no way equal
5-7 gallons per hour of finely atomized, (read it would most likely fit through your air filter finely atomized) water being sprayed.
I've had three gallons per hour of spray running on a 8.5:1 660cc engine with a MAP sensor sensing full boost and dumping fuel, without stalling or bending anything.
At least 3 liters made it in.
Would fit through our air filter finely atomized? We don't run pre air filter. It's usually pre throttle body, post throttle body, post supercharger or direct port injection. No kidding it wouldn't flood your motor going through an filter first. And 3gph is nothing to spray. I sprayed 14gph in my supercharger set up post throttle body. And yes you can hydro lock a motor with meth.
https://www.cobaltss.net/forums/2-0l...rolock-269484/
Ya you're right they make hydro shields for our cars for fun. Search on here and you will see it happens more than you think.
