View Poll Results: 2.0 LSJ ONLY: What intake do you have?
Voters: 1084. You may not vote on this poll
SS/SC intakes
ok dumb question, the other day i was on here checking to see what the best plugs to get for my 07 ss/sc and found a post of it and what not, today i cant find the same thread and could use some help as to what plugs to get, ive heard colder ones, so can someone help me out witht he brand and type so i can order them, thanks
if u want to do teh airbox mod.. just get a 3.5" AEM or K&N (preferably the dryflow) cone filter. dont cut the airbox at all and just slip it on the lip and tighen and keep the bottom off. to top it all off, the bottom fits with the cone filter so if u want to take it to the dealer u can keep ur filter on just screw the bottom back on. this is what i did on mine, and u can def hear it whine. no CEL, no problems, no cutting.
Yes, this is the best airbox mod, no cutting, and prevents water
I bought a Intake looks exactly like te injen, I put it on and It makes my car misfire from 4800 to redline. took it off no misfire with stock airbox. No Mods, stock. put the intake on as a start and it makes it miss, ??????? HHHHHEEEEEEELLLLPPPPPP!!!!!!
Does anyone know why the aem cold air intake for the supercharged only is the fukin bottom part and the air filter?? and why it doesnt replace the whole stock rubber/plastic intake from were it comes out of the supercharger all the way down to the air box intake like all the other intakes ive seen??
so your saying you simply want the look of having an intake? id rather have the aem which i do personally. Metallic materials suffer from heat absorbtion, with the aem using the stock intake piping you dont have that problem as plastic does not have the heat absorbtion that aluminum ( most intake piping ) does.
I'm about to install the K&N intake that the previous owner had on the car before he traded it in. I've read in a few places that cold air intakes tend to lean out the the air/fuel ratio, which can cause detonation. Is this totally true? Wouldn't the O2 sensors be able to compensate? Any info would be greatly appreciated, cause I don't want to do any damage to the engine.
how much more do you expect to get? 1-maybe 2 horsepower? an intake is an intake is an intake. its like an exhaust. its all just piping with a different muffler on the end. most people just end up paying for the name in the end.
