Tvs 1900 lsj build
Old Jan 26, 2012 | 04:05 PM
  #176
mrbelvedere's Avatar
is it the great **** in which i think it is
Old Jan 26, 2012 | 04:07 PM
  #177
thedubsack85's Avatar
Originally Posted by 100% METH
You better get that ban hammer ready for what I'm going to post up soon.
Your going to post the pics you showed me huh? Im gonna need new pants AGAIN!
Old Jan 26, 2012 | 04:12 PM
  #178
Blowncavy's Avatar
Post it meth
Old Jan 26, 2012 | 04:22 PM
  #179
InfraRedline's Avatar
They the pics ive seen?
Old Jan 26, 2012 | 04:29 PM
  #180
100% METH's Avatar
Euthanasia is slowly working on it... I'm in no hurry to put it together.
The lysholm is taking priority
Old Jan 26, 2012 | 04:32 PM
  #181
100% METH's Avatar
it's the holy **** of #$^#@&@$*$*%&... soon to be revealed
Old Jan 26, 2012 | 04:40 PM
  #182
Bluelightning's Avatar
Got Bewst?
I see euthanasia is looking for an OTTP long tube. Is it going to be part of your build by chance? Or just something he wants to play with?
Old Jan 26, 2012 | 04:49 PM
  #183
I would hope so! lol this is going to be ALOT of fun to watch!
Old Jan 26, 2012 | 04:56 PM
  #184
100% METH's Avatar
Something he wants to play with
I have a CIA MID LENGTH header w/ 3" dp (3" cut out) to 2.5" stock bolt in exit
Old Jan 26, 2012 | 04:57 PM
  #185
rcorona8's Avatar
Way to go steve
Old Jan 26, 2012 | 08:35 PM
  #186
ebristol's Avatar
Bump!
Old Jan 26, 2012 | 09:31 PM
  #187
SunburstSS's Avatar
Hey how do u think a TVS 2300 would do on this setup lol ?
Old Jan 26, 2012 | 09:33 PM
  #188
ecotecturbo's Avatar
Even a 1900 is pushing it but 23 that is to big.
Old Jan 26, 2012 | 09:38 PM
  #189
RooTBeeR's Avatar
mp2300 + built le5 = awesomesauce
Old Jan 26, 2012 | 10:22 PM
  #190
lol i wouldent say that
Old Jan 26, 2012 | 11:17 PM
  #191
Its a huge blower for a 4 cylinder
Old Jan 26, 2012 | 11:31 PM
  #192
so the blower or the engine dosent care whats on it or being put on
Old Jan 27, 2012 | 12:36 AM
  #193
100% METH's Avatar
Exactly
As long as you can get the blower to work in its efficiency range it doeant matter.
He doesn't know the magnitude of this build yet
Old Jan 27, 2012 | 01:58 AM
  #194
euthanasia's Avatar
Case in point 8.3L Whipple twin screw on a 5.4L mod motor.
Old Jan 27, 2012 | 01:59 AM
  #195
Mendomar06's Avatar
SUB'D! And Good luck bro
Old Jan 27, 2012 | 02:46 AM
  #196
Leafydialupking's Avatar
Exactly
But with our head flow, that getting into the range of very hard. Which means we get to the point where to get more in you really have to just run crazy pressure ratios. Trouble with roots blowers is that once you get over a pressure ratio of 2 (aka 15 psi of boost) efficiency normally tanks because the boost starts to leak between the two rotors. The tvs has a higher threshold because of the helix angle on the rotors and some other stuff. Even the normal m62 is higher than that because of the coating and close tolerance on the rotors. That said to really push the pressure ratios you can run it has to be a twin screw, or something I havent seen done before, dual stage. Which would be 1 blower feeding a 2nd blower allowing for a total pressure ratio of 4, though cooling becomes an issue wish this.
Old Jan 27, 2012 | 04:15 AM
  #197
BlkWdoSS's Avatar
suspense is killer lol
l8r,
PD
Old Jan 27, 2012 | 04:42 AM
  #198
100% METH's Avatar
Again, your basing this off a stock/mild cammed LSJ with either a gasket matched/smoothed exhaust ports. I don't blame you though, since I havn't shown you anything.
When I ran the TVS 1900 on a box stock LSJ, with a stock exhaust manifold, 2.5" catted dp, and stock catback with a stock intake. I was on a 3.6" pulley boosting 24-25 psi by 7000 rpm.
This placed the tvs 1900 far out of it's efficiency island... spinning it to a mere 12,600 rpm and robbing easily 100hp per the chart below.
I'll leave you with this for now, and let you think about it.
When all is said and done, the m62 on 2.5 pulley (typically 19-21 psi on a stock head and cams) will be 10 psi, most likely less.
and for the 1900:
8000 rpm x 6.78 crank (ati dampener) / 3.6 = 15.066xxxx S/C RPM
Old Jan 27, 2012 | 07:15 AM
  #199
Staged07SS's Avatar
Administrator
Administrator
^It's the new Area47....
Riddles and suspense, haha.
Old Jan 27, 2012 | 10:24 AM
  #200
No, riddles and I'm not saying the 1900 wont work, just that I think thats the limit we could really use based on what we can actually flow though the head. After seeing these graphs I changed by backup plan from m90 to this if I dont get 350hp on my theoretical build, like the engine builder program says I will. I should see if I saved that engine because it would be real easy to pop this blower on it so we can start guessing power for realz. Based on the 2nd graph there, I'm guessing you're going to somehow see the pr1 to pr1.1 area for boost.
